Topic: LAME 4.0 alpha 6 (Read 48010 times) previous topic - next topic
LAME 4.0 alpha 6
You can download this from here: http://homepage.ntlworld.com/jfe1205/lame4.0a6.zip.
This is compiled from Takehiro's experimental branch so, BEWARE!! I've only made this available for people to try for fun, it's not ready for general consumption. It sounds reasonable, but it's main claim to fame is that it is about 4 - 5 times faster than the current encoder!
Please note, it's not likely that Takehiro is looking for any feedback at this time, but any comments may be of general interest.
Let me make this quite clear again, this is NOT for use for archival purposes, it's only to give an idea of the direction that LAME may be going.
LAME 4.0 alpha 6
4 to 5 times faster? Damn! Gotta try this when I get home.
Just a little curious on what Takehiro's experimental branch will accomplish when it is ready other then speed. The same quality as the current recommended compile or will the quality be better?
iTunes 10 - Mac OS X 10.6
256kbps AAC VBR
iPhone 4 32GB
LAME 4.0 alpha 6
You bet I'll play.
Thanks for the release, John.
LAME 4.0 alpha 6
jesus.
LAME 4.0 alpha 6
Its fast alright!!!
file size is also a little bigger:
lame3.9 @ alt preset standard was around 180k
lame4.0 @ alt preset standard is around 194k
With my really cheap speakers, I cant tell the difference between the two!!!
LAME 4.0 alpha 6
How many alpha branches of LAME is there? There's 3.90.3, 3.95 and now 4.0? How many of the features of 3.90.3 and 3.95 are incorporated into 4.0? What about -Z and -Y switches?
LAME 4.0 alpha 6
3.90.x - Hydrogenaudio Branch; based on version 3.90
3.94 - Next stable official LAME version
4 - Takehiro's new experimental lame branch, which will become the next generation some day
LAME 4.0 alpha 6
LAME v4.0!!! Yea!!! I can't wait until I get home to try this out.
LAME 4.0 alpha 6
Hmm I wonder whether it's due to x86 specific optimizations (SSE, SSE2, 3DNow!, etc.) like Gogo uses.
LAME 4.0 alpha 6
Just encoded 700Mb of wav files (whole CD) with --alt-preset standard in 3 minutes 29 seconds !!!
It was going well over 22x
Encoded the same CD with lame3.90.2 and it took 22 minutes 48 seconds !!!!
Thats nearly 7 times faster
by the way, I have an xp1900+
LAME 4.0 alpha 6
Wonder why they start with alpha6 or 7, why not alpha1?
LAME 4.0 alpha 6
maybe we're just too late ?
LAME 4.0 alpha 6
Just doing some comparison encodes right now. These results are on a wav file that is approximately 73 mins long. The performance improvements are amazing. No difference between alt-preset standard and alt-preset fast standard (giving practically identical results when binary compared so option does nothing).
lame --alt-preset standard Test.wav newlame.mp3
LAME version 4.0 MMX, 3DNow!(alpha 6, May  9 2003 16:14:24) (http://www.mp3dev.org/)
CPU features: i387, MMX (ASM used), 3DNow! (ASM used), SIMD
Using polyphase lowpass  filter, transition band: 18671 Hz - 19205 Hz
Encoding Test.wav to newlame.mp3
Encoding as 44.1 kHz VBR(q=3) j-stereo MPEG-1 Layer III (ca. 8.2x) qval=5
    Frame          |  CPU time/estim | REAL time/estim | play/CPU |    ETA
169823/169827(100%)|    2:37/    2:37|    2:37/    2:37|  28.203x|    0:00
32 [  825] %*
40 [    1] *
48 [    9] %
56 [    11] %
64 [    30] %
80 [  675] %
96 [  5055] %******
112 [ 16935] %********************
128 [ 28530] %%*********************************
160 [ 54157] %%%%**************************************************************
192 [ 29247] %%**********************************
224 [ 19122] %%**********************
256 [  8940] %%*********
320 [  6290] %%******
average: 170.7 kbps  LR: 9829 (5.788%)  MS: 159998 (94.21%)
lame --alt-preset fast standard Test.wav newfastlame.mp3
Encoding Test.wav to newfastlame.mp3
169823/169827(100%)|    2:40/    2:40|    2:40/    2:40|  27.748x|    0:00
32 [  825] %*
40 [    1] *
48 [    9] %
56 [    11] %
64 [    30] %
80 [  675] %
96 [  5055] %******
lame392 --alt-preset standard Test.wav oldlame.mp3
LAME version 3.92 MMX  (http://www.mp3dev.org/)
Encoding Test.wav to oldlame.mp3
Encoding as 44.1 kHz VBR(q=2) j-stereo MPEG-1 Layer III (ca. 7.3x) qval=2
169824/169826(100%)|  15:24/  15:24|  15:25/  15:25|  4.7996x|    0:00
32 [  825] %*
128 [ 22507] %%%%***************************
160 [ 49357] %%%%%%%%%%%%%%****************************************************
192 [ 40464] %%%%%%%%%%%%%%*****************************************
224 [ 27555] %%%%%%%%%%%%%%***********************
256 [ 18292] %%%%%%%%%%%**************
320 [ 10827] %%%%%%*********
average: 193.7 kbps  LR: 44849 (26.41%)  MS: 124978 (73.59%)
LAME 4.0 alpha 6
there is no difference between the fast and none fast standard, because there is no vbr-old anymore. the formerly known vbr-mtrh is the only vbr code now.
LAME 4.0 alpha 6
VERYYYYYYYYYYYY FAAAAAAAAAAAAAAAAAAAAAAAAAAAST!!!
I hope quality its OK?!
First TEST...
CU
Bobby Black
LAME 4.0 alpha 6
This is interesting. I could use high speed + high quality to transcode my mpcs for my portable. If the quality is mediocre... no harm done.
How alpha is this version? Should we rather ensure a proper 3.94 final or start testing v4? Would testing at this early stage be usefull?
LAME 4.0 alpha 6
IMHO, 4.0alpha6 is for quick test only, no harm if doing something not require quality.
It's really amazing fast, but I'll still wait for the official 3.94.
Hong Kong - International Joke Center (after 1997-06-30)
LAME 4.0 alpha 6
The --nogap option is nice, but I am unclear on what this means:
Note: Disabling VBR Xing/Info tag since it interferes with --nogap
What does the VBR Xing/Info tag do for me? Will I miss it?
Is there a distinction between --preset standard and --alt-preset standard?
LAME 4.0 alpha 6
The speed improvements are not because of x86 assembly but mainly because of Takehiro's brain.
(btw think about how fast a Gogo based on this could be!)
LAME 4.0 alpha 6
does lame 4.0 also include gabriel's development (3.94...) or are 4.0 and 3.94 two independent developments ?
LAME 4.0 alpha 6
Ha ha ha on my machine it encodes even faster than MPC, at 7x-8x and even 9x
It only lacks of gapless playback and blah blah blah. I've also noticed that the algorithm used is q3 instead of q2 (did Takehiro tweak q3?)
LAME 4.0 alpha 6
Speed is excellent (ca 15x on my Athlon TB 1333).
A quick test revealed problems with an Autechre track (no real surprise there) titled "Eidetic Casein". Right at the beginning there are some extremely short bursts of noise which I'd expect to cause smearing. However what first caught my attention was the slightly sound in the background (that "ding - ding - ding"). In the original the frequency is stable, in the mp3 it has a vibrato. No need to abx, damn obvious. My mother also noticed it right away over my pc speakers. The noisy reverb of the ding-ding sound is also shorter in the mp3.
First 6 seconds FLACed
edit: 3.90.2 aps sounds much better; would need abx for which I have no time now. Also worth mentioning are the bitrates for the short sample (no typo):
3.90.2 - 161
4.0a6 - 116
LAME 4.0 alpha 6
The quality seems to have taken a turn for the worse, at least in --preset standard using the fatboy sample. This is a super earley alpha, so this is to be expected though. I have very high hopes for v4.0 when it matures. FAST is an understatement!
LAME 4.0 alpha 6
whoah fast speeds  even on aps. I haven't tested lame since 3.94 alpha something and I have to say this is amazingly fast! LAME is definitely cleaning up the slow speeds, and lag on machines when encoding is gone.
4.77 mb - for the new alpha
4.37 mb - for 3.90.2
both are --alt-preset standard  this makes me":angry:" because it is CONSIDERABLY higher, this makes me angry as either lames new compile is made to trick you into thinking its fast and more accurate while it could just randomly be picking bitrates and stumbling across encodes.
3.90.2 - 19 -128, 25 -160, 28 -192, 14 -224, 8 -256, 6 -320 average bitrate: 189
3.4 alpha whatever (the one you just linked  )  - 83 -192, 4 -224, 3 - 256, 9 -320
...used EncSpot as always!!!
My final guess (or conclusion either way you look at it)- It seems that LAME's speeds are  a fluke. Sure they are significantly faster than 3.90.2 and may foul many of you but, comparing bitrates shows that its more like a non-variable bitrate, as most of them are 192. And you already get good speeds with 192 on 3.90.2. In other words, 3.4's aps ripping is a RIP and stick with 3.90.2 because I think thats the best compile we'll EVER find of LAME.
Lame 4.0 alpha whatever's alt-preset standard is a cheap, defective 192 kbps encode setting practically! If you want 192 or GOOD aps stick with --alt-preset standard.
LAME 4.0 alpha 6
Used --alt-preset fast extreme for encoding both files.
Lame 4.0 alpha6:
MPEG-1 Layer 3
286 Kbit VBR (with Xing header)
44.1 Khz Joint stereo
Artist: Mazzy Star - Tell Me Now
File size 8.983MB
Encoding time for this was approx: 19 seconds (Info from external compressor window)
Lame3.93:
MPEG-1 Layer 3
256 Kbit VBR (with Xing header)
Filesize: 8.063MB
Maybe should have used extreme or standard for both (tomorrow). In any case, they both sound passable, but it is late here and music is not very loud right now. Not much speed difference on this machine using this particular preset. Filesizes are little different and so are bitrates. Bitrate # from Media Center, which I think takes an overall average for the bitrates.
Pretty good though for an alpha version.
edit: cleaned pasted info up
