Topic: [TOS #10] From: Use the design of "v0.9.3.1" in the newest v (Read 647 times) previous topic - next topic
What exactly are you missing in the new version that is in the screenshot above? It is a very minimalistic setup, with just playlist tabs and a playlist and the normal controls on top. You can replicate that in some minutes. If you don't like the new columns based playlist, you can just create a wide column with all information, too. That is to say you can quite easily replicate the UI in the screenshot with 1.1.x..
zum Glück von D
Also ich möchte die neue Version von Foobar exakt so aussehen lassen wie die oben als screenshot gepostete. Genau die gleichen Symbole usw.
Geht das vll. in dem ich bestimmte Dateien von der alten Foobar Version auf die neue Übertrage? z.B. die "theme.fth" ? Oder bringt die neue Version von Foobar
das alles mit ?
danke
