Topic: audacity - editing audio problems (Read 1486 times) previous topic - next topic
hey, sorry if this is in the wrong place -
i just started ripping vinyl records again, and whenever i click on the waveform to select audio to cut, the marker jumps to the next second, and it didn't the last time i used it. for example, if i click on the audio between 1.0 seconds 1.5, it will bring me up to 2 seconds instead, and this makes it hard to edit the audio, as it doesnt let me choose exactly what i want to select. is there anyway to change this so the point i click on the audio is exactly where the marker will be?
Down in the bottom right corner, next to the "Selection Start" time, there's a check box for turning snapping on or off - I'm guessing it's checked.
 i never realized i hit that button, thanks for the help!
