Is there a way to batch change the directory of my audio files? 2011-10-06 02:52:17 Is there a way to batch change directory on a foobar configuration?I recently switched to linux and am running foobar under wine. The hard drive path changed to a Z though whereas my old configuration was an H:.I have tons of playlists that I want to be able to automatically use again but it seems like this is not the case. Any help would be appreciated, whether it is a way to change directories, or somehow change the existing playlists to use the new directories filepath.
Is there a way to batch change the directory of my audio files? Reply #1 – 2011-10-06 03:23:28 The component foo_playlist_revive can help get your playlists back. Here is a link: http://www.hydrogenaudio.org/forums/index....showtopic=73910Hopefully it will work properly with your Linux configuration.Dennis Last Edit: 2011-10-06 03:34:01 by Dennis68
Is there a way to batch change the directory of my audio files? Reply #2 – 2011-10-06 04:39:20 For Future Reference: If you move your files with fb2k's fileops component, loaded playlists are automagically taken care of and tags don't have to be reindexed.
Is there a way to batch change the directory of my audio files? Reply #3 – 2011-10-06 08:14:04 foo_fileops does not help, if you copy a foobar2000 configuration from one machine to another. Or from Windows to Wine.
Is there a way to batch change the directory of my audio files? Reply #4 – 2011-10-06 08:53:53 Thanks everyone who replied, I will be trying foo_playlist when I can and will probably update with my results later.
Is there a way to batch change the directory of my audio files? Reply #5 – 2011-10-06 16:14:10 Have you tried adding a Z drive in Wine Configuration? Pointing it to an empty directory and soft-linking (if you don't want to move them) your music folder(s) in there should do the trick (never tried actually ).HTH.Alessandro
Is there a way to batch change the directory of my audio files? Reply #6 – 2011-10-06 16:15:33 Quote from: foosion on 2011-10-06 08:14:04foo_fileops does not help, if you copy a foobar2000 configuration from one machine to another. Or from Windows to Wine.Ahhh. Yes. Reading comprehension. I knew I forgot something.
Is there a way to batch change the directory of my audio files? Reply #7 – 2011-10-06 17:14:56 Alessandro: Wine already uses symlinks to implement drive letters. They can be edited through winecfg. If you want to check them out manually, look in "~/.wine/dosdevices". Last Edit: 2011-10-06 17:15:15 by foosion
Is there a way to batch change the directory of my audio files? Reply #8 – 2011-10-06 17:45:46 Oh nice, never bothered to explore those details, thanks for the heads up.Then the OP could directly point the new Z drive to the ~/.wine/drive_c/musicfolder, right?Still, I'd personally rather move my music library to a dedicated folder: I never liked much those "hard to find" sub-sub-sub-folders. Alessandro
Is there a way to batch change the directory of my audio files? Reply #9 – 2011-10-06 19:05:44 Yess, it worked. Added a drive letter H to the folder /media/Main and then pointed foobar to the correct drive to monitor.Thanks everyone.
