Topic: vegas (trial) can't open divx (xvid) files (Read 7703 times) previous topic - next topic
Hi
i 'm running windows 7
and i would like a video editor to buy
reading and surfting i found that vegas 10 is one the best video editor
better then vegas there is adobe premier
well i don't know if there is some program better the vegas but i'm running the trial version
and i can 't open , import divx file , avi extension but compressed with xvid or divx
what could i do?
could you give me some advises and feedbacks
i would appreciate them a lot
cheers
some ideas
a. maybe you could frameserve those with avisynth http://forum.doom9.org/showthread.php?t=153291
b. if it is some simple editing task virtualdub will probably cut those losslessly with direct stream enabled (cuting at keyframes only probably)
b2. or avidemux
c. convert them to something that vegas can open and edits nicely (maybe a lossless interemediate like utvideo, check http://forum.doom9.org/showthread.php?t=143624 )
All of the highly-compressed formats can be "difficult" to edit or convert.  Apparently, Vegas doesn't support Xvid/DviX at all... But, with some video editors, some Xvid/DivX/MPEG-4 files work and others fail...  So, if you have a camera that creates these formats you  should look for a video editor that works with your files.  And, you need to try  it  to make sure the software actually works with the particularXvid/DviX files from your camera.
If you are buying "the best" (Vegas Pro $600 USD)  it's probably worthwhile to upgrade to a camera with a better format.   If you download files from the Internet, you are going to run-into "problem files" once in a while...
Or, as smok3 said, you may need to convert to a different (less compressed) format.
I don't use Vegas (I use Corel Video Studio) but whenever I run into a problem format I convert it with SUPER[/u]  (FREE!!!).  I usually convert to MPEG-2, since I'm usually making DVDs.  You may want to convert to something else.    You can convert it back to Xvid/Dvix after editing, but this is lossy compression and there is theoretical quality loss with each conversion/compression.
BTW - If you download SUPER, don't get fooled by all of the ads on their confusing website...  follow the links and make sure you are downloading SUPERsetup.exe.
From the Vegas website[/u]:
Supported File Formats
Opens: AAC, AA3, AIFF, AVI, BMP, CDA, FLAC, GIF, JPEG, MP3, MPEG-1, MPEG-2, MPEG-4, MVC, OGG, OMA, PCA, PNG, RealMedia®, QuickTime®, SND, SFA, W64, WAV, WDP, WMA, WMV
Saves: AAC, AC3, AA3, AIFF, AVC, AVI, BMP, FLAC, JPEG, LPEC, MP3, MPEG-2, MPEG-4, MVC, OGG, PCA, PNG, RealMedia®, TIFF, QuickTime, W64, WAV, WDP, WMA, WMV
"AVI" is misleading because AVI is a "container" or "wrapper" format that can contain audio & video with any type of compression.    They probably mean AVI/DV, which is what you get from a MiniDV camera.
some ideas
b2. or avidemux
thanks a lot!
vegas can open these files after converting
thanks
i tried some freesoftwares , i would like to use them , but they are not so powerfull
vegas (surfing and reading around the net is one of the best and easy ) , is cheap if you can get a academic license
i like avidemux , and virtualdub but they have not so many features
it's the first time i hear about  Corel Video Studio , i know  avid , adobe premiere (i guess they are the best ) but too much expensive
i 'm not a huge vegas fan , but the academic license is tempting
thanks a lot!
cheers
if you are on windows and you can afford some learning time, check the free (soon to be OS?) editor
http://www.lightworksbeta.com/
WOW
seems amazing
is open source? and free?
can't believe...
sadly i have to register and it doesn't accept my email
a workflow example http://forum.doom9.org/showthread.php?p=1461402#post1461402 and other rants.
(honestly: if a non-working mail is stopping you, then this is not for you..., it is a LOT of work...)
Vegas opens Xvid AVIs just fine if you install the Xvid codec.
Some other times it helps if you just re-mux the video content to another container. (For MKV files, for example.)
