Topic: lossyWAV quality parameter (Read 4643 times) previous topic - next topic
http://wiki.hydrogenaudio.org/index.php?title=LossyWAV says:
-q, --quality <t>    where t is one of the following (default = standard):
    I, insane        highest quality output, suitable for transcoding;
    E, extreme      higher quality output, suitable for transcoding;
    H, high          high quality output, suitable for transcoding;
    S, standard      default quality output, considered to be transparent;
    C, economic      intermediate quality output, likely to be transparent;
    P, portable      good quality output for DAP use, may not be transparent;
    X, extraportable lowest quality output, not fully transparent.
lossyWAV 1.1.0c says:
-I, --insane        highest quality output, suitable for transcoding;
-E, --extreme      high quality output, also suitable for transcoding;
-S, --standard      default quality output, considered to be transparent;
-P, --portable      good quality output for DAP use. Not considered to be fully transparent, but considered fit for its intended purpose.
Are the additional parameters listed in the wiki deprecated?
If yes, maybe someone should delete them from the wiki?
Look at the box to the right - it says "Stable release: 1.3.0". That should answer your question. The additional parameters were introduced with version 1.2.0 and 1.3.0.
sorry, I missed that. I don't know how I ended up with an old version.
is there any description of the --zero parameter somewhere?
EDIT:
OK, I found out. The wiki page quoted above says (in the box @ top/right):
"Website: http://www.hydrogenaudio.org/forums/index....st&p=577042"
which points to the 1.1.0c version.
Thanks for reporting that; I’ve replaced the link to the outdated thread with those for the 1.3.0 ones.
thank you, db1989.
what about the --zero parameter?
It's mentioned in the table here but not in the help/usage.
Done! Thanks for spotting those. Would anyone be interested in signing up for the Knowledgebase?  You could PM myself or another known wiki-type if you see anything else that needs changed on any page—but preferably just the relatively drastic stuff, I think, so we’re not deluged with recommendations of minor changes! It would be great for more users—and those with specific knowledge of the topics, as in this case—to register for editing privileges; perhaps the necessity of being validated puts people off, but it really takes almost no time.
