Topic: Replaygain for DVDA and SACD ISOs (Read 2525 times) previous topic - next topic
Storing and playback of DVDA and SACD ISOs using respective playback components are becoming quite popular (especially recently for SACDs....).  However, replaygain won't work with it, as it requires tags.  ISOs can't be tagged.  Is there a way to make replaygain store a text file with metadata about the ISOs?  Can this be added?
Starmanj
For DVD-A it already works, foo_input_dvda stores the value in an xml metatag.
And you are indeed right.  Just checked a DVDA track's properties and...there it is, replaygain data.  Maybe we need Maxim to add this bit of code into the SACD decoder...
