Topic: Error Code (0x8889000A) (Read 13478 times) previous topic - next topic
Keep getting Error Code (0x8889000A) message and foobar2000 v1.17 won't play.....any suggested solutions?
oldandintheway: Please run the troubleshooter, and post a list of components, as stated in the support forum rules. Also try whether using DirectSound (DS) output will fix your problem, if you do not already use it.
Figured it out....I had to switch audio devices in Control Panel...I sometimes use Total Recorder and that has a separate driver to select in conjunction with speaker playback.....Thanks.
