Topic: foo_uie_lyrics3 (Read 900353 times) previous topic - next topic
foo_uie_lyrics3
Reply #875
Hey
I have...
- a request:
I'm using the plugin in a panel which can be activated by clicking on the tab "lyrics". (so the plugin searches lyrics for EVERY song i listen to)
Isn't it possible to enable and disable the lyrics search per context menu? (always adding and removing the several databases in preferences is no option for me)
- an issue:
i let the plugin save lyrics in a subfolder of the filepath of the song. (i set custom folder "$directory_path(%path%)\lyrics")
Since i updated from version 0.2.3 to 0.3.5.2 it doesn't anymore.
When i open properties dialog of Associations search I can see the sources are saved as "C_\%blabla..the path of music%\%lyric file%"
So an "_" instead of ":"
foo_uie_lyrics3
Reply #876
I'm getting "load failed" on TIMESTAMPED 1 server. Haven't tested the others yet, so I'll be back when I have done so.
edit #1: lyricswikia loads lyrics just fine.
foo_uie_lyrics3
Reply #880
Have you tried loading one? We don't have problems finding them, but loading them. Try to load one and you should get "load failed" in the "Results:" field.
foo_uie_lyrics3
Reply #881
Only TIMESTAMPED 1 shows nothing here (whithout "load failed" as you said).
Disabled. Goodbye Timestamped 1. Needs only one second.
foo_uie_lyrics3
Reply #882
Hello
First of all - thank you for creating this useful plugin! It's awesome and makes using foobar better. I've only started using it, and I was wondering about one thing - is it (or going to be) possible to exclude some tracks from the lyrics search? Or maybe temporary disabling the online search with one click/ckeckbox? The thing is that I often listen to classical music or ambient tracks, movie soundtracks, and it ends up generating all those requests to the websites that are unnecessary (since the songs have no lyrics).
Anyway, once again, thank you for all the work you're putting into creating this plugin
foo_uie_lyrics3
Reply #883
Once again:
To those who asked about disabling the online search - I am considering it. An interim solution would just be to disable the internet sources in lyrics3 preferences.
foo_uie_lyrics3
Reply #884
The server behind the TimeStamped 1 database is accessible form time to time.
It seems like either they are reworking their pages last days, or having some troubles with domain name.
The server's search engine remain unchanged, so in case the server is working I get no "load failed" message in v.0.3.4, and lyrics are loaded.
foo_uie_lyrics3
Reply #885
The Timestamped 1 site is officially "Under Construction".
foo_uie_lyrics3
Reply #886
Why would I want to disable it?
foo_uie_lyrics3
Reply #887
Agreed.  erich_2, just because the music YOU listen to has lyrics plastered on multiple servers, doesn't mean the music we listen to has LRC files generally available on any source other than Server 1.  Try to even think for one second before posting something so useless.
foo_uie_lyrics3
Reply #888
Heh, so not only are thousands of people presumably leeching lyrics from it without permission, but moreover it’s not even officially opened yet.
foo_uie_lyrics3
Reply #889
Timestamped 1 server is back.
foo_uie_lyrics3
Reply #890
Download here: http://www.foobar2000.org/components/view/foo_uie_lyrics3
Current version: 0.3.5.2
Thanks for you update Lyric Show Panel 3 again and again.
I like your update so much.
I have posted a question in here.
But I think you didn't see it,
or my suggest is stupid. XD
So you didn't answer me.
Would you tell me how do you think about my suggest?
Sorry for bother you.
foo_uie_lyrics3
Reply #891
thanks, working fine so far.
foo_uie_lyrics3
Reply #892
@The vern
I have one annoyance here
when the lyrics panel width is smaller than 30 pix the background turns black.
normally you don't set the width so small and there is no problem but i have one DUI config where i have made panel collapser with the help of WSH panel and when I collapse lyrics panel to 1 pix, then there always remains that annoying black line.
If you get some time please fix this, thanks.
And thanks for your hard work with this panel.
foo_uie_lyrics3
Reply #893
Hi everybody! How can I enter the row of title, album in foo_uie_lyrics3? Thankyou!
foo_uie_lyrics3
Reply #894
You can enter this in the fallback text in panel preferences on the right click menu. Each line of fallback text is displayed on a separate line in the panel. If a lyric is found the fallback text is not shown - but you have the info in the title bar anyway or you could use another plug-in if you wanted to show both within the layout. The plug-in comes already configured with a fallback text option which you can change.
foo_uie_lyrics3
Reply #895
Thankyou so much!
foo_uie_lyrics3
Reply #896
You can enter this in the fallback text in panel preferences on the right click menu...
For example:
Artist: %artist%
Title: %title%
Album: %album%
:: %search_state% [ %search_progress%'%'] ::
foo_uie_lyrics3
Reply #897
Hellp to all.
I have a problem. When my foobar searches for lyrics, it sometimes doesn't find the lyrics for my songs, tho I found the lyrics on google (rapgenius.com). I tried to put rapgenius in custom url searches in foobar, but as far as i went was only to the lyrics page not the lyrics itself.
example - (eminem is just an example)
If anyone can figure out the URL for rapgenius search, or to just tell me how to open the first lyric in the search bar, I would be very gratefull. Thanks in advance.
foo_uie_lyrics3
Reply #898
I don't know bug or not.
I using portable foobar2000 to play my music, sometime my portable drive assign to letter F, sometime assign to letter G, if assign letter F, association of lyric location will F:\xxx\xxx.lrc, but if sometime windows assign me with letter G, then foobar2000 will automatic download the lyric and replace my lyric, some of lyric i manually edit, sudden change all my lyric, really panic.
i not save lyric into tag, only save to lrc format.
foo_uie_lyrics3
Reply #899
You can assign your drive a single and unique letter on every computer/Windows the first time you connect such drive preventing Windows from changing whenever it's already in use. Just set this by acceding to Disk management.
Doing so you can tell foobar a single library path and for lyrics I suggest file directory.
