Topic: foo_uie_lyrics3 (Read 902658 times) previous topic - next topic
Re: foo_uie_lyrics3
Reply #2200
He wrote the code for it and it's not open-source, if that's what you mean.
I need to report a bug/crash that I found while using the plugin. Is Veksha still active on these forums?
Re: foo_uie_lyrics3
Reply #2201
Can I report a bug/crash for MultiSource Plugin on this thread? Will it be seen?
Re: foo_uie_lyrics3
Reply #2202
This would be the best place to report it.  You could also send a message to him with the report.
There isn’t much activity on LSP3 or Multi Source, so don’t expect quick responses.
Re: foo_uie_lyrics3
Reply #2203
Forwarded post from 2024-05-14
@Veksho
I'm having issues with the foo_multisource 0.56 component.
My install is foobar 2.2 x86 always newest beta running foo_ui_lyrics3 0.6. Also newest c++ runtime library versions 14.40.33810.
Lately I have increasing crash errors upon exiting foobar and almost always having visual c++ runtime errors while starting foobar which mostly only runs after trying to start 4/5 times in a row. It was kind of acceptable for me because I'm always testing (maybe less stable) stuff, but now the amount of crashes were becoming unbearable.
So today I started debugging by removing one component after another to isolate the cause for this almost constant startup bug. After having removed some 20 different components including foo_ui_lyrics3 (actually the third one I removed), I removed foo_multisource and all of a sudden I did not experience exit or startup errors anymore.
I reloaded my full skin including foo_ui_lyrics and multisource and back where the exit/startup errors.
Then I removed foo_ui_lyric3 but kept multisource ... still exit/start crashes. After removing multisource no more errors.
Reloaded full skin one more including foo_ui_lyrics and multisource and back where the exit/startup errors.
Then removed multisource but kept foo_ui_lyrics3 ... no errors.
Please investigate
