Topic: foo_uie_lyrics3 (Read 636824 times) previous topic - next topic
Re: foo_uie_lyrics3
Reply #1900
Is it possible to automatically save the lyric .lrc/txt to folder immediately after a successful search?
Select, context menu, Download lyrics will batch download and save them. Although with separate window and more steps.
Re: foo_uie_lyrics3
Reply #1901
Do you mean by manually left click in the lyric panel and click save? I don't need this, I need the process to be fully automated, because I don't use the panel itself only it's fetch function...
In ESLyric there is a option ( Foobar -> Tools -> ESLyric ) called: Lyric save scheme: Save when loaded. I need the same option also in Lyric Show 3. That's what I am looking for.
Re: foo_uie_lyrics3
Reply #1902
I have a SMP script you may find useful.
It runs the command "View/Lyrics Show 3/Save" at a interval (1sec) until Lyric Show 3 downloads the lyrics.
It then reloads ESLyric and kills the timer.
"use strict";
window.DefinePanel('LS3 File Saver', {
    author: 'zeremy'
let esl;
let eslyric;
if (utils.CheckComponent("foo_uie_eslyric")){
    eslyric = true;
    esl = new ActiveXObject("ESLyric");
let artist;
let title;
function on_playback_new_track(metadb) {
    ls3_save(metadb);
function on_playback_dynamic_info_track() {
    ls3_save(fb.GetNowPlaying());
function ls3_save(metadb) {
    if (!metadb)
        return;
    let timer = setInterval(() => {
            let path = fb.TitleFormat('$if2(%__@%,%path%)').EvalWithMetadb(metadb);
            if (path.startsWith('http') || path.startsWith('mms')) {
                artist = fb.TitleFormat("[%artist%]").Eval().replace(/[<>:"/\\|?*]/g, "_");
                title = fb.TitleFormat("[%title%]").Eval().replace(/[<>:"/\\|?*]/g, "_");
            } else {
                artist = fb.TitleFormat("[%artist%]").EvalWithMetadb(metadb).replace(/[<>:"/\\|?*]/g, "_");
                title = fb.TitleFormat("[%title%]").EvalWithMetadb(metadb).replace(/[<>:"/\\|?*]/g, "_");
            let filename_lrc = fb.ProfilePath + "lyrics\\" + artist + " - " + title + ".lrc";
            let filename_txt = fb.ProfilePath + "lyrics\\" + artist + " - " + title + ".txt";
            if (utils.FileExists(filename_lrc) || utils.FileExists(filename_txt)) {
                if (eslyric) esl.RunPanelContextMenu("Reload Lyric");
                clearInterval(timer);
            else {
                fb.RunMainMenuCommand("View/Lyrics Show 3/Save");
        }, 1000);
Re: foo_uie_lyrics3
Reply #1903
Thank you so much @zeremy !
I have modified your code and it works beautiful! Will credit you for sure =).
Re: foo_uie_lyrics3
Reply #1904
No, not lyrics panel, you select a list of tracks in playlist view, right click - Download lyrics - batch lyric search window appears, lyrics are downloaded and saved for selected tracks.
Re: foo_uie_lyrics3
Reply #1905
It's been a little while since my last message. I know that veksha has done since a much more elaborated work with more sources packaged in an all-in-one component, but as I previously said, I wanted anyway to backport my JS code to retrieve MusixMatch lyrics into a fb2k component... And I've finally find some time this week to finish a fully working version that I'm sharing here. :)
I had to spend a lot of time to fix crashes when dealing with MusixMatch results sometimes not structured as expected. I think I nuked now any possible case, but if you give my component a try and still encounter such a crash, please let me know with which artist and track it happens. ;)
As a little bonus, it should not be necessary with my version to mess with the user token as it automatically attempts to generate a fresh one. But if for some reasons, you need to reset it or just want to use a custom one, you can access it in foobar's advanced config, under Tools then MusixMatch source.
Re: foo_uie_lyrics3
Reply #1906
Thank you cedricpc for this plugin!  It complements Veksha's work, good to have both.  I hope you will consider making one for this site too:
http://www.songlyrics.com/
