Topic: foo_uie_lyrics3 (Read 895784 times) previous topic - next topic
0 Members and 6 Guests are viewing this topic.
foo_uie_lyrics3
Reply #1575
Does anyone know how to bypass the "local lyric already exists" false positive?
The situation: I got several versions of my audio files in different versions - mostly FLAC 44100 for "on the go" purposes, FLAC 96000 or 192000 for home listening.
However, just because I do have a .lrc for a 192k, that does not mean that I shouldn't be able to automatically save an .lrc for a different version. For a different dir, different file.
Yes, the artist-title is the same, but the directory is different, and even the filename is different. (all my FLACs are renamed to include bitrate on filename!)
All feedback appreciated.
Where do you save your files? If you keep them in the same folder, it's usually a mess. If your different files are in different folders, it's a no brainer. Just look in the "Lyric saving / Save method".
foo_uie_lyrics3
Reply #1576
Indeed, that was my first attempt, and was messy indeed. Now I save every .lrc along with the corresponding .flac file, so each dir has the flac/lrc pairing.
My current options are "Enable automatic saving", "Save Method: Save to directory same as file".
However, the problem remains: if an .lrc is found and saved for ArtistX-TitleY on my 44100 dir, when going to my 96000 dir, I get the "local lyric already exists", and it's not saved.
It seems the plugin is caching results, or something to that effect.. (really unsure about the technicalities of the code, just reporting what's happening....)
foo_uie_lyrics3
Reply #1577
I use one directory so this is theoretical but some parts should work similarly. Plugin works by association but it looks like a name overrides a path? One solution you might try: change filename format to the one that differentiates files/lyrics. Then the problem is the search pattern because it still picks the old lyrics files and there's one pattern for online and local search. So unless you figure out  compatible search/saving formats (which I didn't :-)) you'd have to crate a new association manually, choose lyrics (which I do).
foo_uie_lyrics3
Reply #1578
That really helped me to narrow down things. I converted a dir with FLACs to M4As, and did a "Download Lyrics" out of the context menu.
Surprise: only the first dir got lyrics saved. Indeed the problem lies within the search patterns.
I changed the search parameters to include codec, just to test. The good news is, it is unique, so it does try to do a search. The bad news is, obviously, no lyrics were found.
The plot thickens, but thanks for everyone's input so far..
foo_uie_lyrics3
Reply #1580
just in case some of you encountered the same problem:
i found that if either the title or the artist-name contains a dot ( . ) , the plugin will not be able to find any lyrics!
->  the problem can easily be resolved by replacing the search-parameters with:
Artist:  [$replace(%artist%,.,)]
Title:    [$replace(%title%,.,)]
foo_uie_lyrics3
Reply #1581
Does anyone know how to adjust the lyrics scrolling speed? The default one is too erratic, but I can't seem to change it through the panel preferences since half of the options are cut off for some unknown reason.
Re: foo_uie_lyrics3
Reply #1582
The plugin doesn't seem to work anymore, all i got is this anytime i try to load lyrics.
<?xml version="1.0" encoding="UTF-8" ?>
<result errmsg="Search ID or Code error!" errcode="32006"></result>
Re: foo_uie_lyrics3
Reply #1583
I have this problem too. This plugin is currently not very useful because of this. Can someone fix this?
Re: foo_uie_lyrics3
Reply #1584
Install Windows 10 yesterday and I forget to save the lyrics :(
And now it is not working. Bad luck.
Hopefully it is resolved.
Re: foo_uie_lyrics3
Reply #1585
It doesn't work in other Windows versions either, not just in Windows 10.
Re: foo_uie_lyrics3
Reply #1587
Hello! I'm trying to add more lyric servers to the component but idk how. I get stuck on the hostname [:port]
can someone give me an example?
Re: foo_uie_lyrics3
Reply #1588
lyric show panel found nothing anybody having the same problem ?
Re: foo_uie_lyrics3
Reply #1590
Same problem here. It still shows lyrics which are already stored locally (e.g. Lyrics-Tag).
But it can't find any new lyrics, no matter which search order is configured in preferences.
Most peculiar.
Update with error correction (or at least instructions for workaround) would be highly appreciated.  :-)
Re: foo_uie_lyrics3
Reply #1592
does anybody know about any ohter component that can...basically do the same as lyric show panel?
Re: foo_uie_lyrics3
Reply #1593
I can confirm it works. The Readme needs a little work (and a spellcheck).
After installing the new component and placing the 2 DLLs in the Foobar directory, Go to Preferences > Tools > Lyric Show 3 and add "www.azlyrics.com" from 'Available Sources' to 'Search Order'.
I would suggest deactivating the "Online DB: Google Search" by moving it back to 'Available Sources'.
I hope this helps clear things up.
Good work, Tripod31, I appreciate it.
still not working for me....i put "inconv.dll" and "zlib1.dll" in the main foobar directory and them "foo_lyricsource.dll" in component's diretory and them configure www.azlyric.com and nothing
Re: foo_uie_lyrics3
Reply #1594
Start working don't know how thought
Re: foo_uie_lyrics3
Reply #1595
Doesn't work here either. I'm blaming Bill Gates, I suspect he put out a Windows update that stuffed us all.
A friend has an old Win XP box, I'll give that a go and report back.
Re: foo_uie_lyrics3
Reply #1596
I also had this problem, i read the last page of this thread, installed the dll's and still no results.
Thereafter I went into the advanced options of the lyrics component and selected "always asume charset for lyrics". Mine is now "OEM 437 United States" and now the lyrics3 component is working with the azlyrics source.
Re: foo_uie_lyrics3
Reply #1597
Ok, I tried this with David Bowie's Darkstar after first checking that Azlyrics had the lyrics. It found lyrics for tracks 2 and 7. Better than nothing, but nowhere near as good as it used to be.
Hermanski, what OS are you using ? (I'm on Win 7 / 64)
Re: foo_uie_lyrics3
Reply #1599
Same here..
I thought it might be a change in Windows Firewall rolled out to everybody in a Windows Update. I checked Windows Firewall, but everything *seems* fine to me -- an exception for foobar2000 TCP and for UDP, in private domain for inbound connections (with outbound connections being allowed by default without need for exceptions). I'm definitely not very familiar with Windows Firewall though, so people are welcome to check into this more if they want...
