Topic: Replaygain not being applied during playback (Read 2445 times) previous topic - next topic
Hi All,
I'm having some trouble with playback of mp3-referenced cue files... basically it appears that the ReplayGain info stored in the referenced mp3 is not being applied when playing it via the cue sheet - i.e., playback is noticeably louder than simply playing the single mp3 (for which foobar correctly applies ReplayGain).  I don't recall having this problem with previous versions of foobar.  My understanding up to now was that ReplayGain info needn't be in the cue file, so long as the referenced audio file has RG values.
Any insight would be greatly appreciated.  FYI my foobar prefs are album mode / apply gain, and for reference I've pasted the properties of both the mp3 and the referencing cue sheet in the codeboxes below.
Thanks,
RS
File name : DJ-Kicks.mp3
Folder name : C:\Users\User117\Music\Mirror\Apparat\(2010) DJ-Kicks
File path : C:\Users\User117\Music\Mirror\Apparat\(2010) DJ-Kicks\DJ-Kicks.mp3
Subsong index : 0
File size : 80MB (83 920 552 bytes)
Last modified : 2011-08-12 19:44:05
Duration : 1:08:06.107 (180 197 304 samples)
Sample rate : 44100 Hz
Channels : 2
Bitrate : 164 kbps
Codec : MP3
Codec profile : MP3 VBR V4
Encoding : lossy
Tool : LAME3.98r
Tag type : id3v2.3
Track gain : -8.48 dB
Track peak : 1.169221
Album gain : -8.48 dB
Album peak : 1.169221
<ENC_DELAY> : 576
<ENC_PADDING> : 1416
<MP3_ACCURATE_LENGTH> : yes
<MP3_STEREO_MODE> : joint stereo
File name : DJ-Kicks.mp3.cue
File path : C:\Users\User117\Music\Mirror\Apparat\(2010) DJ-Kicks\DJ-Kicks.mp3.cue
Subsong index : 1
File size : 1.98KB (2 030 bytes)
Last modified : 2011-08-11 20:35:25
Duration : 3:04.307 (8 127 924 samples)
Channels : 2
Bitrate : 164 kbps
Codec : MP3
Encoding : lossy
Tool : LAME3.98r
Tag type : id3v2.3
<ENC_DELAY> : 576
<REFERENCED_FILE> : DJ-Kicks.mp3
You could load the .cue file into Foobar2000, then apply Replaygain. It will of course save the values in the .cue file.
Thanks for the reply.  I'm aware that RG values can be added to cue sheets, however the current playback behavior (i.e., ignoring the referenced file's RG) only seems to have happened as of a recent version.  Previously when I'd play a cue sheet, the output would be adjusted to the reference file's RG.
Recent as in a 1.1.8 beta version?
elevatorladylevitateme
Can anyone confirm this behavior on their foobar setup?
My results
v1.1.8.b4 , v1.1.7 , v1.1.2 , v0.9.5
- playing by cue ignores replaygain tags in mp3 file
v0.8.3
- playing by cue adjusts output according to replaygain tags in mp3 file
Wow, thanks.  Guess this behavior goes back a lot further than I remember.  Looks like I'll be scanning a whole bunch of cues!
