Topic: foo_lastfm_radio not working w/ my new fb2k; how to remove/deactivate? (Read 1750 times) previous topic - next topic
Hello. I have a layout of Ibiza and foo_lastfm_radio.dll. This component is not compatible with my fb2k in version 1.0.3. May know where in the files can manually remove the component that was not used? Because from what I know is the newest of this component is not there. So it's probably the only solution or disable it somewhere in the preferences.
I don't recall if 1.0.3 had the new components system, but if it does, just remove the component through the options. If you don't know how to do that, you should read foobar2000's documentation.
I found new componet and work!
