Here is a collection of Filter Panel Fields:
(Note: You may want to remove the color codes ($RGB...); In my CUI Filter panel, I'm rendering the text in white over a dark brown background).
(Note: The code "$char(8195)" is "Unicode space, extra wide" --- see: _http://en.wikipedia.org/wiki/Space_%28punctuation%29
User Stats — Artist-Track
$char(8195)$rgb(255,255,41)$if($stricmp($date(%last_played%),),<NO_DATE>,$date(%last_played%)) $time(%last_played%) $char(8195) %artist%' ' ' '—' ' ' '%title% $char(8195)$char(8195) '(' $if($ext($if3(%__referenced_file%,%filename_ext%)),'.'$lower($ext($if3(%__referenced_file%,%filename_ext%))),$if($stricmp(%codec%,'mp3'),'.mp3',)) ')'
User Stats — Directory
$char(8195)$rgb(255,255,41)$if($stricmp($date(%last_played%),),<NO_DATE>,$date(%last_played%)) $char(8195) $directory_path(%path%) $char(8195)$char(8195)$char(8195) '(' $if($ext($if3(%__referenced_file%,%filename_ext%)),'.'$lower($ext($if3(%__referenced_file%,%filename_ext%))),$if($stricmp(%codec%,'mp3'),'.mp3',)) ')'
User Stats — Play Count
$char(8195)$rgb(255,255,41)%play_count%
User Stats — Ratings
$char(8195)$rgb(255,255,41)$puts(rating,' ♦ ' )$if(%rating%,$repeat($get(rating),$ifgreater(%rating%,5,5,%rating%)),$ifgreater($div(%play_count%,10),4,,$repeat($get(rating),$div($mod(%play_count%,10),5)))$repeat($get(rating),$min($div(%play_count%,10),5)))
Library Stats — File Types and Encoding Qualities (lossy or lossless)
$rgb(255,255,41)$padcut('.'$ext(%path%),12)$padcut($if($ext($if3(%__referenced_file%,%filename_ext%)),$UPPER($ext($if3(%__referenced_file%,%filename_ext%))),$if($stricmp(%codec%,'mp3'),'.mp3',)),12)$rgb(255,255,255)$pad($directory_path(%path%),20)' ' —————— ' '$rgb(25,255,41)$padcut($info(encoding),12)$padcut('('[%codec%]$if(%bitrate%, %bitrate% Kbs,)$if(%__extrainfo%, VBR,)$if(%codec_profile%, %codec_profile%,)')',35)))
Library Stats — File Type [.CUE] exists in directory
$rgb(255,255,41)$ifequal($stricmp($ext(%path%),cue),1,$directory_path(%path%),)
Library Stats — Length of Time (of files)
$char(8195)$rgb(255,255,41)$left('00:00:00',$sub(8,$len(%length%)))%length%
Library Stats — ReplayGain status (of files)
$char(8195)$if(%__replaygain_album_gain%,$if(%__replaygain_album_gain%,$rgb(0,153,0)YES - AlbumGain is applied to these tracks,$rgb(204,51,0)AlbumGain = NO),$if(%__replaygain_track_gain%,$rgb(0,153,0)YES - TrackGain only is applied to these tracks,$rgb(204,51,0)NO - These tracks have no ReplayGain applied)))
Library Stats — Size of Files (in Mb)
$char(8195)$rgb(255,255,41)$if($strstr([$upper($ext(%path%))],CUE),CUE,$div(%filesize%,1048576)'.'$substr($muldiv(%filesize%,100,1048576),2,3)' Mb'))
Library Stats — Technical Profile (of files)
$char(8195)$rgb(255,255,41)%__channels% $ifgreater(%__channels%,1,'Channels','Channel') $char(8195) %codec% $char(8195) %samplerate%' Hz' $char(8195) $if($stricmp(%codec%,'mp3'),$caps(%__mp3_stereo_mode%),$if($stricmp(%codec%,'Musepack'),$replace(%__codec_profile%,'',),$if($stricmp(%codec%,'Vorbis'),,$if($stricmp(%codec%,'Monkey'$char(39)'s Audio'),%__codec_profile% %__bitspersample%' Bits',$if($stricmp(%codec%,'FLAC'),%__bitspersample%' Bits',$if($stricmp(%codec%,'Windows Media Audio v7/v8'),,$if($stricmp(%codec%,'Windows Media Audio V9 (Lossless Mode)'),,$if($stricmp(%codec%,'PCM'),%__bitspersample%' Bits',$if($stricmp(%codec%,'ATSC A/52'),)))))))))
TAG String Exists: Artist Name — [RED=NO] [GREEN=YES]
$if($meta(artist),$rgb(0,255,0)$puts(va_string,'VA')$if($stricmp($meta(va),'1'),$puts(va,1))$if($stricmp($meta(various),'1'),$puts(va,1))$if($stricmp($meta(various artists),'1'),$puts(va,1))$if($stricmp($meta(album artist),'va'),$puts(va,1))$if($stricmp($meta(album artist),'various'),$puts(va,1))$if($stricmp($meta(album artist),'various artists'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va-'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va '),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va_'),$puts(va,1))$if($strstr($lower(%path%),'\va\'),$puts(va,1))$if($strstr($lower(%path%),'\various\'),$puts(va,1))$if($strstr($lower(%path%),'\various artists\'),$puts(va,1))$if($strstr($lower(%path%),'\_va\'),$puts(va,1))$if($strstr($lower(%path%),'\_various\'),$puts(va,1))$if($strstr($lower(%path%),'\_various artists\'),$puts(va,1))$if(%tracknumber%,$if(%album%,$if($stricmp($get(va),1),$get(va_string),$upper($if2($meta(album artist),%artist%)) ) [' ? '%date%][' ? '%album%], $replace(%path%,%filename_ext%,)), $replace(%path%,%filename_ext%,)) [%totaldiscs%'CD']' ' ' ' ' ' ' ' '|||' ' ' ' ' ' ' ' '%path%,$rgb(255,0,0)$puts(va_string,'VA')$if($stricmp($meta(va),'1'),$puts(va,1))$if($stricmp($meta(various),'1'),$puts(va,1))$if($stricmp($meta(various artists),'1'),$puts(va,1))$if($stricmp($meta(album artist),'va'),$puts(va,1))$if($stricmp($meta(album artist),'various'),$puts(va,1))$if($stricmp($meta(album artist),'various artists'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va-'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va '),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va_'),$puts(va,1))$if($strstr($lower(%path%),'\va\'),$puts(va,1))$if($strstr($lower(%path%),'\various\'),$puts(va,1))$if($strstr($lower(%path%),'\various artists\'),$puts(va,1))$if($strstr($lower(%path%),'\_va\'),$puts(va,1))$if($strstr($lower(%path%),'\_various\'),$puts(va,1))$if($strstr($lower(%path%),'\_various artists\'),$puts(va,1))$if(%tracknumber%,$if(%album%,$if($stricmp($get(va),1),$get(va_string),$upper($if2($meta(album artist),%artist%)) ) [' ? '%date%][' ? '%album%], $replace(%path%,%filename_ext%,)), $replace(%path%,%filename_ext%,)) [%totaldiscs%'CD']' ' ' ' ' ' ' ' '|||' ' ' ' ' ' ' ' '%path%)
TAG String Exists: Track Title — [RED=NO] [GREEN=YES]
$if($meta(title),$rgb(0,255,0)$puts(va_string,'VA')$if($stricmp($meta(va),'1'),$puts(va,1))$if($stricmp($meta(various),'1'),$puts(va,1))$if($stricmp($meta(various artists),'1'),$puts(va,1))$if($stricmp($meta(album artist),'va'),$puts(va,1))$if($stricmp($meta(album artist),'various'),$puts(va,1))$if($stricmp($meta(album artist),'various artists'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va-'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va '),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va_'),$puts(va,1))$if($strstr($lower(%path%),'\va\'),$puts(va,1))$if($strstr($lower(%path%),'\various\'),$puts(va,1))$if($strstr($lower(%path%),'\various artists\'),$puts(va,1))$if($strstr($lower(%path%),'\_va\'),$puts(va,1))$if($strstr($lower(%path%),'\_various\'),$puts(va,1))$if($strstr($lower(%path%),'\_various artists\'),$puts(va,1))$if(%tracknumber%,$if(%album%,$if($stricmp($get(va),1),$get(va_string),$upper($if2($meta(album artist),%artist%)) ) [' ? '%date%][' ? '%album%], $replace(%path%,%filename_ext%,)), $replace(%path%,%filename_ext%,)) [%totaldiscs%'CD']' ' ' ' ' ' ' ' '|||' ' ' ' ' ' ' ' '%path%,$rgb(255,0,0)$puts(va_string,'VA')$if($stricmp($meta(va),'1'),$puts(va,1))$if($stricmp($meta(various),'1'),$puts(va,1))$if($stricmp($meta(various artists),'1'),$puts(va,1))$if($stricmp($meta(album artist),'va'),$puts(va,1))$if($stricmp($meta(album artist),'various'),$puts(va,1))$if($stricmp($meta(album artist),'various artists'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va-'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va '),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va_'),$puts(va,1))$if($strstr($lower(%path%),'\va\'),$puts(va,1))$if($strstr($lower(%path%),'\various\'),$puts(va,1))$if($strstr($lower(%path%),'\various artists\'),$puts(va,1))$if($strstr($lower(%path%),'\_va\'),$puts(va,1))$if($strstr($lower(%path%),'\_various\'),$puts(va,1))$if($strstr($lower(%path%),'\_various artists\'),$puts(va,1))$if(%tracknumber%,$if(%album%,$if($stricmp($get(va),1),$get(va_string),$upper($if2($meta(album artist),%artist%)) ) [' ? '%date%][' ? '%album%], $replace(%path%,%filename_ext%,)), $replace(%path%,%filename_ext%,)) [%totaldiscs%'CD']' ' ' ' ' ' ' ' '|||' ' ' ' ' ' ' ' '%path%)
TAG String Exists: Album Title — [RED=NO] [GREEN=YES]
$if($meta(album),$rgb(0,255,0)$puts(va_string,'VA')$if($stricmp($meta(va),'1'),$puts(va,1))$if($stricmp($meta(various),'1'),$puts(va,1))$if($stricmp($meta(various artists),'1'),$puts(va,1))$if($stricmp($meta(album artist),'va'),$puts(va,1))$if($stricmp($meta(album artist),'various'),$puts(va,1))$if($stricmp($meta(album artist),'various artists'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va-'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va '),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va_'),$puts(va,1))$if($strstr($lower(%path%),'\va\'),$puts(va,1))$if($strstr($lower(%path%),'\various\'),$puts(va,1))$if($strstr($lower(%path%),'\various artists\'),$puts(va,1))$if($strstr($lower(%path%),'\_va\'),$puts(va,1))$if($strstr($lower(%path%),'\_various\'),$puts(va,1))$if($strstr($lower(%path%),'\_various artists\'),$puts(va,1))$if(%tracknumber%,$if(%album%,$if($stricmp($get(va),1),$get(va_string),$upper($if2($meta(album artist),%artist%)) ) [' ? '%date%][' ? '%album%], $replace(%path%,%filename_ext%,)), $replace(%path%,%filename_ext%,)) [%totaldiscs%'CD']' ' ' ' ' ' ' ' '|||' ' ' ' ' ' ' ' '%path%,$rgb(255,0,0)$puts(va_string,'VA')$if($stricmp($meta(va),'1'),$puts(va,1))$if($stricmp($meta(various),'1'),$puts(va,1))$if($stricmp($meta(various artists),'1'),$puts(va,1))$if($stricmp($meta(album artist),'va'),$puts(va,1))$if($stricmp($meta(album artist),'various'),$puts(va,1))$if($stricmp($meta(album artist),'various artists'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va-'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va '),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va_'),$puts(va,1))$if($strstr($lower(%path%),'\va\'),$puts(va,1))$if($strstr($lower(%path%),'\various\'),$puts(va,1))$if($strstr($lower(%path%),'\various artists\'),$puts(va,1))$if($strstr($lower(%path%),'\_va\'),$puts(va,1))$if($strstr($lower(%path%),'\_various\'),$puts(va,1))$if($strstr($lower(%path%),'\_various artists\'),$puts(va,1))$if(%tracknumber%,$if(%album%,$if($stricmp($get(va),1),$get(va_string),$upper($if2($meta(album artist),%artist%)) ) [' ? '%date%][' ? '%album%], $replace(%path%,%filename_ext%,)), $replace(%path%,%filename_ext%,)) [%totaldiscs%'CD']' ' ' ' ' ' ' ' '|||' ' ' ' ' ' ' ' '%path%)
TAG String Exists: Date — [RED=NO] [GREEN=YES]
$if($meta(date),$rgb(0,255,0)$puts(va_string,'VA')$if($stricmp($meta(va),'1'),$puts(va,1))$if($stricmp($meta(various),'1'),$puts(va,1))$if($stricmp($meta(various artists),'1'),$puts(va,1))$if($stricmp($meta(album artist),'va'),$puts(va,1))$if($stricmp($meta(album artist),'various'),$puts(va,1))$if($stricmp($meta(album artist),'various artists'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va-'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va '),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va_'),$puts(va,1))$if($strstr($lower(%path%),'\va\'),$puts(va,1))$if($strstr($lower(%path%),'\various\'),$puts(va,1))$if($strstr($lower(%path%),'\various artists\'),$puts(va,1))$if($strstr($lower(%path%),'\_va\'),$puts(va,1))$if($strstr($lower(%path%),'\_various\'),$puts(va,1))$if($strstr($lower(%path%),'\_various artists\'),$puts(va,1))$if(%tracknumber%,$if(%album%,$if($stricmp($get(va),1),$get(va_string),$upper($if2($meta(album artist),%artist%)) ) [' ? '%date%][' ? '%album%], $replace(%path%,%filename_ext%,)), $replace(%path%,%filename_ext%,)) [%totaldiscs%'CD']' ' ' ' ' ' ' ' '|||' ' ' ' ' ' ' ' '%path%,$rgb(255,0,0)$puts(va_string,'VA')$if($stricmp($meta(va),'1'),$puts(va,1))$if($stricmp($meta(various),'1'),$puts(va,1))$if($stricmp($meta(various artists),'1'),$puts(va,1))$if($stricmp($meta(album artist),'va'),$puts(va,1))$if($stricmp($meta(album artist),'various'),$puts(va,1))$if($stricmp($meta(album artist),'various artists'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va-'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va '),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va_'),$puts(va,1))$if($strstr($lower(%path%),'\va\'),$puts(va,1))$if($strstr($lower(%path%),'\various\'),$puts(va,1))$if($strstr($lower(%path%),'\various artists\'),$puts(va,1))$if($strstr($lower(%path%),'\_va\'),$puts(va,1))$if($strstr($lower(%path%),'\_various\'),$puts(va,1))$if($strstr($lower(%path%),'\_various artists\'),$puts(va,1))$if(%tracknumber%,$if(%album%,$if($stricmp($get(va),1),$get(va_string),$upper($if2($meta(album artist),%artist%)) ) [' ? '%date%][' ? '%album%], $replace(%path%,%filename_ext%,)), $replace(%path%,%filename_ext%,)) [%totaldiscs%'CD']' ' ' ' ' ' ' ' '|||' ' ' ' ' ' ' ' '%path%)
TAG String Exists: Album Artist — [RED=NO] [GREEN=YES]
$if($meta(album artist),$rgb(0,255,0)$puts(va_string,'VA')$if($stricmp($meta(va),'1'),$puts(va,1))$if($stricmp($meta(various),'1'),$puts(va,1))$if($stricmp($meta(various artists),'1'),$puts(va,1))$if($stricmp($meta(album artist),'va'),$puts(va,1))$if($stricmp($meta(album artist),'various'),$puts(va,1))$if($stricmp($meta(album artist),'various artists'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va-'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va '),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va_'),$puts(va,1))$if($strstr($lower(%path%),'\va\'),$puts(va,1))$if($strstr($lower(%path%),'\various\'),$puts(va,1))$if($strstr($lower(%path%),'\various artists\'),$puts(va,1))$if($strstr($lower(%path%),'\_va\'),$puts(va,1))$if($strstr($lower(%path%),'\_various\'),$puts(va,1))$if($strstr($lower(%path%),'\_various artists\'),$puts(va,1))$if(%tracknumber%,$if(%album%,$if($stricmp($get(va),1),$get(va_string),$upper($if2($meta(album artist),%artist%)) ) [' ? '%date%][' ? '%album%], $replace(%path%,%filename_ext%,)), $replace(%path%,%filename_ext%,)) [%totaldiscs%'CD']' ' ' ' ' ' ' ' '|||' ' ' ' ' ' ' ' '%path%,$rgb(255,0,0)$puts(va_string,'VA')$if($stricmp($meta(va),'1'),$puts(va,1))$if($stricmp($meta(various),'1'),$puts(va,1))$if($stricmp($meta(various artists),'1'),$puts(va,1))$if($stricmp($meta(album artist),'va'),$puts(va,1))$if($stricmp($meta(album artist),'various'),$puts(va,1))$if($stricmp($meta(album artist),'various artists'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va-'),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va '),$puts(va,1))$if($stricmp($left(%directoryname%,3),'va_'),$puts(va,1))$if($strstr($lower(%path%),'\va\'),$puts(va,1))$if($strstr($lower(%path%),'\various\'),$puts(va,1))$if($strstr($lower(%path%),'\various artists\'),$puts(va,1))$if($strstr($lower(%path%),'\_va\'),$puts(va,1))$if($strstr($lower(%path%),'\_various\'),$puts(va,1))$if($strstr($lower(%path%),'\_various artists\'),$puts(va,1))$if(%tracknumber%,$if(%album%,$if($stricmp($get(va),1),$get(va_string),$upper($if2($meta(album artist),%artist%)) ) [' ? '%date%][' ? '%album%], $replace(%path%,%filename_ext%,)), $replace(%path%,%filename_ext%,)) [%totaldiscs%'CD']' ' ' ' ' ' ' ' '|||' ' ' ' ' ' ' ' '%path%)
