Topic: Using LossyWAV encoder with portable foobar2000 (Read 7823 times) previous topic - next topic
Is there any way to use lossywav encoder with portable foobar and save full portability?
(I have no problems with other encoders+portable foobar and no problems with lossywav+normal foobar installation)
I use lossyWAV (unsurprisingly.... ) with foobar2000 using a portable installation.
Are you having trouble pointing to the lossywav executable?
Yes. For other encoders I just place exe file to folder where foobar2000.exe is. But for lossywav it does't work.
Here my settings. lossywav.exe and flac.exe in the same folder where foobar2000.exe:
Is there an error message from either foobar2000, cmd.exe, or lossyWAV; what does it say; etc.
Error mesage from foobar says:
1 out of 1 tracks converted with major problems.
Source: "D:\1\white noise.wav"
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "D:\1\white noise.lossy.flac"
  Additional information:
  Encoder stream format: 44100Hz / 2ch / 16bps
  Command line: "c:\windows\system32\cmd.exe" /d /c lossywav.exe - -q X --silent --stdout|flac.exe - -b 512 -8 --ignore-chunk-size -o "white noise.lossy.flac"
  Working folder: D:\1\
  Conversion failed: The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters
If in "Parameters" I write full (not relative) path to lossywav.exe and flac.exe (
/d /c d:\foobar2000\lossywav.exe - -q X --silent --stdout|d:\foobar2000\flac.exe - -b 512 -8 --ignore-chunk-size -o %d
instead of
), then everything works.
Searching "portable" in the foobar2000 support forums seems to indicate that this is an outstanding issue with fb2k in portable mode - it does not seem to find other executables in its main directory.
LossyFLAC portable
Files paths
foobar folder\@.bat
foobar folder\encoders\flac.exe
foobar folder\encoders\lossywav.exe
@.bat
"%~dp0encoders\lossywav.exe" "%~dp1%~nx1" -q %3 --silent --stdout|"%~dp0encoders\flac.exe" - -b 512 -%4 -f -o "%~dp1%~nx2"
Foobar2000 coverter
Encoder: @.bat
Extension: lossy.flac
Parameters: %s %d preset compression
Format is: lossless or hybrid
Highest BPS mode supported: 24
*preset = I, E, H, S, C, P, X
*compression = 0-8
