Topic: Volume quiets after hibernation/sleep? (Read 5245 times) previous topic - next topic
I don't know if this is a bug on foobar's part or windows, but after I wake up my computer from hibernation (not sleep, hibernation, there is a setting in the power options in cp) the volume on foobar is quieter than it started with. The volume control in foobar is still set at the same setting, but what you actually hear is quieter. When you click on the volume control tab/bar, the volume jumps back to where the tab is again. I know this probably isn't a big deal, but just thought I would post it anyways.
I have been able to reproduce this bug, I have foobar2000 v1.1.7 open, I pause the current song, and tell my 64bit Windows 7 machine to hibernate. After waking it back up, and playing the song, the volume is quieter and after clicking on the volume control tab/bar in foobar, the volume jumps back. Keep in mind, I can click so the bar/tab goes lower, but the volume still increases, so it must be set to a default value or something when the computer is turned back on. Again, maybe it's windows fault or something...
Hello,
I'd like to report a rather minuscule bug with Foobar2k. It may not be Foobar's fault, but I believe it can be worked around in Foobar2k. The issue is, when I put my computer to sleep during playback (I assume it would occur only if the device was open when the computer was put to sleep) and wake it up, the volume is at a different level in Foobar. The slider remains in the correct position. Moving the volume slider down a bit and back up causes it to return to normal levels. Even though this bug is minuscule and probably not Foobar's fault, I have a feeling Foobar could work around it anyways.
Just to justify, and I don't mean to unnecessarily lengthen this post, the reason I have been sleeping/waking up with playback on is to work around a bug in my Synaptics touchpad driver. It likes to start placing the cursor in the upper righthand corner of the screen and the only known solution is to downgrade the driver... or, as I have found, go to sleep and back. But I digress.
Some system information (in case it matters:)
Summary
    Operating System
      MS Windows 7 Enterprise 64-bit SP1
    CPU
      Intel Core i5  @ 2.27GHz  47 °C
      Arrandale 32nm Technology
    RAM
      4.00 GB Dual-Channel DDR3 @ 533MHz (7-7-7-20)
    Motherboard
      PEGATRON CORPORATION G60JX (Socket 989)  55 °C
    Graphics
      HSD160PHW1 (1366x768@60Hz)
      NVIDIA GeForce GTS 360M
    Hard Drives
      488GB Seagate ST9500420AS ATA Device (SATA)  40 °C
    Optical Drives
      TSSTcorp CDDVDW TS-L633C ATA Device
    Audio
      High Definition Audio Device
Operating System
  Installation Date: 08 July 2011, 14:22
  Serial Number: xxxxx-xxxxx-xxxxx-xxxxx-xxxxx
    Windows Security Center
      User Account Control (UAC)  Enabled
      Notify level  2 - Default
      Firewall  Enabled
    Windows Update
      AutoUpdate  Enabled
    Windows Defender
      Windows Defender  Enabled
    TimeZone
      TimeZone  GMT -5 Hours
      Language  English
      Country  United States
      Currency  $
      Date Format  M/d/yyyy
      Time Format  h:mm:ss tt
    Power Profile
      Active power scheme  Home/Office Desk
      Hibernation  Enabled
    Scheduler
      7/24/2011 3:25 PM  GoogleUpdateTaskUserS-1-5-21-1110497808-2201788196-704580570-1000Core
      7/24/2011 3:25 PM  GoogleUpdateTaskUserS-1-5-21-1110497808-2201788196-704580570-1000UA
    Hotfixes
      7/22/2011  Definition Update for Windows Defender - KB915597 (Definition 1.109.116.0)
      7/19/2011  Definition Update for Windows Defender - KB915597 (Definition 1.107.2067.0)
      7/15/2011  Definition Update for Windows Defender - KB915597 (Definition 1.107.1837.0)
      7/14/2011  Update for Windows (KB958488)
      7/13/2011  Security Update for Microsoft .NET Framework 4 on Windows XP, Windows Server 2003, Windows Vista, Windows 7, Windows Server 2008, Windows Server 2008 R2 for x64-based Systems (KB2518870)
      7/13/2011  Security Update for Windows 7 for x64-based Systems (KB2507938)
      7/13/2011  Update for Windows 7 for x64-based Systems (KB2529073)
      7/13/2011  Security Update for Windows 7 for x64-based Systems (KB2532531)
      7/13/2011  Security Update for Windows 7 for x64-based Systems (KB2555917)
      7/13/2011  Update for Windows 7 for x64-based Systems (KB982018)
      7/13/2011  Update for Windows 7 for x64-based Systems (KB2533623)
      7/12/2011  Definition Update for Windows Defender - KB915597 (Definition 1.107.1567.0)
      7/12/2011  Security Update for Microsoft .NET Framework 4 on Windows XP, Windows Server 2003, Windows Vista, Windows 7, Windows Server 2008, Windows Server 2008 R2 for x64-based Systems (KB2478663)
      7/12/2011  Security Update for Microsoft .NET Framework 4 on Windows XP, Windows Server 2003, Windows Vista, Windows 7, Windows Server 2008, Windows Server 2008 R2 for x64-based Systems (KB2446708)
      7/11/2011  Microsoft .NET Framework 4 Client Profile for Windows 7 x64-based Systems (KB982670)
      7/9/2011  Security Update for .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2518869)
      7/9/2011  Security Update for Windows 7 for x64-based Systems (KB2425227)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2552343)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2505438)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2533552)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2515325)
      7/9/2011  Security Update for Windows 7 for x64-based Systems (KB2479943)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2547666)
      7/9/2011  Security Update for Windows 7 for x64-based Systems (KB2503665)
      7/9/2011  Security Update for Internet Explorer 8 for Windows 7 for x64-based Systems (KB2544521)
      7/9/2011  Security Update for Windows 7 for x64-based Systems (KB2536276)
      7/9/2011  Cumulative Security Update for ActiveX Killbits for Windows 7 for x64-based Systems (KB2508272)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2511250)
      7/9/2011  Security Update for Windows 7 for x64-based Systems (KB2525694)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2545698)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2534366)
      7/9/2011  Cumulative Security Update for Internet Explorer 8 for Windows 7 for x64-based Systems (KB2530548)
      7/9/2011  Security Update for Windows 7 for x64-based Systems (KB2510531)
      7/9/2011  Security Update for .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2478662)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2522422)
      7/9/2011  Security Update for Windows 7 for x64-based Systems (KB2506212)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2492386)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2524375)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2484033)
      7/9/2011  Security Update for Windows 7 for x64-based Systems (KB2507618)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2541014)
      7/9/2011  Security Update for Windows 7 for x64-based Systems (KB2509553)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2488113)
      7/9/2011  Security Update for Windows 7 for x64-based Systems (KB2536275)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2506014)
      7/9/2011  Security Update for Windows 7 for x64-based Systems (KB2476490)
      7/9/2011  Atheros Communications Inc. - Network - Atheros AR9285 Wireless Network Adapter
      7/9/2011  Security Update for .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2446710)
      7/9/2011  Update for Windows 7 for x64-based Systems (KB2506928)
      7/9/2011  Security Update for Windows 7 for x64-based Systems (KB2491683)
      7/9/2011  Security Update for Windows 7 for x64-based Systems (KB2544893)
      7/9/2011  Security Update for Windows 7 for x64-based Systems (KB2511455)
      7/8/2011  Update for Windows (KB971033)
      7/8/2011  Definition Update for Windows Defender - KB915597 (Definition 1.107.1308.0)
      7/8/2011  Atheros Communications Inc. - Network - Atheros AR9285 Wireless Network Adapter
      7/8/2011  ATK - Input - ATK0100 ACPI UTILITY
    Battery
      AC line  Offline
      Battery full time  Unknown
      Battery Charge %  54 %
      Battery State  Unknown status
      Amount of time remaining (sec)  0 : 47
    Services
      Running  Application Experience
      Running  Application Information
      Running  Application Management
      Running  Background Intelligent Transfer Service
      Running  Base Filtering Engine
      Running  CNG Key Isolation
      Running  COM+ Event System
      Running  Cryptographic Services
      Running  DCOM Server Process Launcher
      Running  Desktop Window Manager Session Manager
      Running  DHCP Client
      Running  Diagnostic Policy Service
      Running  Diagnostic Service Host
      Running  Distributed Link Tracking Client
      Running  DNS Client
      Running  Extensible Authentication Protocol
      Running  Function Discovery Provider Host
      Running  Function Discovery Resource Publication
      Running  Group Policy Client
      Running  HomeGroup Provider
      Running  IP Helper
      Running  Multimedia Class Scheduler
      Running  NetDrive Service
      Running  Network Connections
      Running  Network List Service
      Running  Network Location Awareness
      Running  Network Store Interface Service
      Running  NVIDIA Display Driver Service
      Running  NVIDIA Stereoscopic 3D Driver Service
      Running  Offline Files
      Running  Peer Name Resolution Protocol
      Running  Peer Networking Identity Manager
      Running  Plug and Play
      Running  Power
      Running  Print Spooler
      Running  Program Compatibility Assistant Service
      Running  Protected Storage
      Running  Remote Procedure Call (RPC)
      Running  RPC Endpoint Mapper
      Running  Scrybe Updater
      Running  Security Accounts Manager
      Running  Security Center
      Running  Server
      Running  Shell Hardware Detection
      Running  Software Protection
      Running  SSDP Discovery
      Running  Steam Client Service
      Running  Superfetch
      Running  System Event Notification Service
      Running  Tablet PC Input Service
      Running  TabletServicePen
      Running  Task Scheduler
      Running  TCP/IP NetBIOS Helper
      Running  Themes
      Running  UPnP Device Host
      Running  User Profile Service
      Running  Wacom Consumer Touch Service
      Running  Windows Audio
      Running  Windows Audio Endpoint Builder
      Running  Windows Connect Now - Config Registrar
      Running  Windows Defender
      Running  Windows Driver Foundation - User-mode Driver Framework
      Running  Windows Event Log
      Running  Windows Firewall
      Running  Windows Font Cache Service
      Running  Windows Image Acquisition (WIA)
      Running  Windows Management Instrumentation
      Running  Windows Media Player Network Sharing Service
      Running  Windows Search
      Running  Windows Update
      Running  WLAN AutoConfig
      Running  Workstation
      Stopped  ActiveX Installer (AxInstSV)
      Stopped  Adaptive Brightness
      Stopped  Application Identity
      Stopped  Application Layer Gateway Service
      Stopped  ASP.NET State Service
      Stopped  BitLocker Drive Encryption Service
      Stopped  Block Level Backup Engine Service
      Stopped  Bluetooth Support Service
      Stopped  BranchCache
      Stopped  Certificate Propagation
      Stopped  COM+ System Application
      Stopped  Computer Browser
      Stopped  Credential Manager
      Stopped  Diagnostic System Host
      Stopped  Disk Defragmenter
      Stopped  Distributed Transaction Coordinator
      Stopped  Encrypting File System (EFS)
      Stopped  Fax
      Stopped  Health Key and Certificate Management
      Stopped  HomeGroup Listener
      Stopped  Human Interface Device Access
      Stopped  IKE and AuthIP IPsec Keying Modules
      Stopped  Interactive Services Detection
      Stopped  Internet Connection Sharing (ICS)
      Stopped  IPsec Policy Agent
      Stopped  KtmRm for Distributed Transaction Coordinator
      Stopped  Link-Layer Topology Discovery Mapper
      Stopped  Media Center Extender Service
      Stopped  Microsoft .NET Framework NGEN v2.0.50727_X64
      Stopped  Microsoft .NET Framework NGEN v2.0.50727_X86
      Stopped  Microsoft .NET Framework NGEN v4.0.30319_X64
      Stopped  Microsoft .NET Framework NGEN v4.0.30319_X86
      Stopped  Microsoft iSCSI Initiator Service
      Stopped  Microsoft Software Shadow Copy Provider
      Stopped  Net.Msmq Listener Adapter
      Stopped  Net.Pipe Listener Adapter
      Stopped  Net.Tcp Listener Adapter
      Stopped  Net.Tcp Port Sharing Service
      Stopped  Netlogon
      Stopped  Network Access Protection Agent
      Stopped  Parental Controls
      Stopped  Peer Networking Grouping
      Stopped  Performance Counter DLL Host
      Stopped  Performance Logs & Alerts
      Stopped  PnP-X IP Bus Enumerator
      Stopped  PNRP Machine Name Publication Service
      Stopped  Portable Device Enumerator Service
      Stopped  Problem Reports and Solutions Control Panel Support
      Stopped  Quality Windows Audio Video Experience
      Stopped  Remote Access Auto Connection Manager
      Stopped  Remote Access Connection Manager
      Stopped  Remote Desktop Configuration
      Stopped  Remote Desktop Services
      Stopped  Remote Desktop Services UserMode Port Redirector
      Stopped  Remote Procedure Call (RPC) Locator
      Stopped  Remote Registry
      Stopped  Routing and Remote Access
      Stopped  Secondary Logon
      Stopped  Secure Socket Tunneling Protocol Service
      Stopped  Smart Card
      Stopped  Smart Card Removal Policy
      Stopped  SNMP Trap
      Stopped  SPP Notification Service
      Stopped  Storage Service
      Stopped  Telephony
      Stopped  Thread Ordering Server
      Stopped  TPM Base Services
      Stopped  Virtual Disk
      Stopped  Volume Shadow Copy
      Stopped  WebClient
      Stopped  Windows Activation Technologies Service
      Stopped  Windows Backup
      Stopped  Windows Biometric Service
      Stopped  Windows CardSpace
      Stopped  Windows Color System
      Stopped  Windows Error Reporting Service
      Stopped  Windows Event Collector
      Stopped  Windows Installer
      Stopped  Windows Media Center Receiver Service
      Stopped  Windows Media Center Scheduler Service
      Stopped  Windows Modules Installer
      Stopped  Windows Presentation Foundation Font Cache 3.0.0.0
      Stopped  Windows Remote Management (WS-Management)
      Stopped  Windows Time
      Stopped  WinHTTP Web Proxy Auto-Discovery Service
      Stopped  Wired AutoConfig
      Stopped  WMI Performance Adapter
      Stopped  WWAN AutoConfig
    Device Tree
        ACPI x64-based PC
            Microsoft ACPI-Compliant System
              System board
              Intel® Core™ i5 CPU      M 430  @ 2.27GHz
              ACPI Thermal Zone
              ACPI Lid
              ACPI Sleep Button
              ACPI Fixed Feature Button
                PCI bus
                  Intel® processor DRAM Controller - 0044
                  Intel® Management Engine Interface
                  Intel® 5 Series/3400 Series Chipset Family PCI Express Root Port 1 - 3B42
                  Intel® 5 Series/3400 Series Chipset Family PCI Express Root Port 3 - 3B46
                  Intel® 82801 PCI Bridge - 2448
                  Intel® 5 Series/3400 Series Chipset Family SMBus Controller - 3B30
                  Intel® 5 Series/3400 Series Chipset Family Thermal Subsystem - 3B32
                  Motherboard resources
                  Microsoft AC Adapter
                  Microsoft ACPI-Compliant Control Method Battery
                    Intel® processor PCI Express Root Port - 0045
                          Generic PnP Monitor
                        High Definition Audio Controller
                          NVIDIA High Definition Audio
                    Intel® 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
                        USB Root Hub
                            Generic USB Hub
                                USB Composite Device
                                  USB2.0 UVC 1.3M WebCam
                    Intel® 5 Series/3400 Series Chipset Family PCI Express Root Port 2 - 3B44
                    Intel® 5 Series/3400 Series Chipset Family PCI Express Root Port 5 - 3B4A
                      SDA Standard Compliant SD Host Controller
                      Base System Device
                      Base System Device
                      Ricoh 1394 OHCI Compliant Host Controller
                    Intel® 5 Series/3400 Series Chipset Family PCI Express Root Port 6 - 3B4C
                      Atheros AR8131 PCI-E Gigabit Ethernet Controller (NDIS 6.20)
                    Intel® 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
                        USB Root Hub
                          Generic USB Hub
                    Intel® HM55 Express Chipset LPC Interface Controller - 3B09
                      Direct memory access controller
                      Intel® 82802 Firmware Hub Device
                      High precision event timer
                      Programmable interrupt controller
                      Numeric data processor
                      System CMOS/real time clock
                      System timer
                      Synaptics PS/2 Port TouchPad
                      Keyboard Device Filter
                      Microsoft ACPI-Compliant Embedded Controller
                    Intel® 5 Series/3400 Series Chipset Family 4 Port SATA AHCI Controller - 3B29
                      ATA Channel 5
                        ATA Channel 0
                        ATA Channel 1
                PCI bus
                  QuickPath Architecture Generic Non-core Registers - 2C62
                  QuickPath Architecture System Address Decoder - 2D01
                  QPI Link 0 - 2D10
                  QPI Physical 0 - 2D11
                  Reserved - 2D12
                  Reserved - 2D13
CPU
    Intel Core i5
      Cores  2
      Threads  4
      Name  Intel Core i5
      Code Name  Arrandale
      Package  Socket 989 rPGA
      Technology  32nm
      Specification  Intel® Core™ i5 CPU M 430 @ 2.27GHz
      Family  6
      Extended Family  6
      Model  5
      Extended Model  25
      Stepping  2
      Revision  C2
      Instructions  MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, Intel 64
      Virtualization  Supported, Enabled
      Hyperthreading  Supported, Enabled
      Bus Speed  133.4 MHz
      Rated Bus Speed  2400.7 MHz
      Stock Core Speed  2266 MHz
      Stock Bus Speed  133 MHz
      Average Temperature  47 °C
        Caches
          L1 Data Cache Size  2 x 32 KBytes
          L1 Instructions Cache Size  2 x 32 KBytes
          L2 Unified Cache Size  2 x 256 KBytes
          L3 Unified Cache Size  3072 KBytes
        Core 0
          Core Speed  1333.7 MHz
          Multiplier  x 19.0
          Bus Speed  133.4 MHz
          Temperature  49 °C
            Thread 1
              APIC ID  0
            Thread 2
              APIC ID  1
        Core 1
          Multiplier  x 9.0
          Bus Speed  133.4 MHz
          Temperature  45 °C
            Thread 1
              APIC ID  4
            Thread 2
              APIC ID  5
RAM
    Memory slots
      Total memory slots  2
      Used memory slots  2
      Free memory slots  0
    Memory
      Type  DDR3
      Size  4096 MBytes
      Channels #  Dual
      DRAM Frequency  533.5 MHz
      CAS# Latency (CL)  7 clocks
      RAS# to CAS# Delay (tRCD)  7 clocks
      RAS# Precharge (tRP)  7 clocks
      Cycle Time (tRAS)  20 clocks
      Command Rate (CR)  1T
    Physical Memory
      Memory Usage  54 %
      Total Physical  3.86 GB
      Available Physical  1.80 GB
      Total Virtual  8.00 TB
      Available Virtual  8.00 TB
    SPD
      Number Of SPD Modules  2
        Slot #1
          Type  DDR3
          Size  2048 MBytes
          Manufacturer  Hyundai Electronics
          Max Bandwidth  PC3-10700 (667 MHz)
          Part Number  HMT125S6TFR8C-H9
          Serial Number  2CC1437F
          Week/year  03 / 10
          SPD Ext.  EPP
            JEDEC #4
              Frequency  685.7 MHz
              CAS# Latency  9.0
              RAS# To CAS#  9
              RAS# Precharge  9
              tRAS  25
              tRC  34
              Voltage  1.500 V
            JEDEC #3
              Frequency  609.5 MHz
              CAS# Latency  8.0
              RAS# To CAS#  8
              RAS# Precharge  8
              tRAS  22
              tRC  30
              Voltage  1.500 V
            JEDEC #2
              Frequency  533.3 MHz
              CAS# Latency  7.0
              RAS# To CAS#  7
              RAS# Precharge  7
              tRAS  20
              tRC  27
              Voltage  1.500 V
            JEDEC #1
              Frequency  457.1 MHz
              CAS# Latency  6.0
              RAS# To CAS#  6
              RAS# Precharge  6
              tRAS  17
              tRC  23
              Voltage  1.500 V
        Slot #2
          Type  DDR3
          Size  2048 MBytes
          Serial Number  2CA140AE
          Week/year  03 / 10
          SPD Ext.  EPP
            JEDEC #4
              Frequency  685.7 MHz
              CAS# Latency  9.0
              RAS# To CAS#  9
              RAS# Precharge  9
              tRAS  25
              tRC  34
              Voltage  1.500 V
            JEDEC #3
              Frequency  609.5 MHz
              CAS# Latency  8.0
              RAS# To CAS#  8
              RAS# Precharge  8
              tRAS  22
              tRC  30
              Voltage  1.500 V
            JEDEC #2
              Frequency  533.3 MHz
              CAS# Latency  7.0
              RAS# To CAS#  7
              RAS# Precharge  7
              tRAS  20
              tRC  27
              Voltage  1.500 V
            JEDEC #1
              Frequency  457.1 MHz
              CAS# Latency  6.0
              RAS# To CAS#  6
              RAS# Precharge  6
              tRAS  17
              tRC  23
              Voltage  1.500 V
Motherboard
  Manufacturer  PEGATRON CORPORATION
  Model  G60JX
  Version  1.0
  Chipset Vendor  Intel
  Chipset Model  Havendale/Clarkdale Host Bridge
  Chipset Revision  12
  Southbridge Vendor  Intel
  Southbridge Model  HM55
  Southbridge Revision  06
  System Temperature  55 °C
    BIOS
      Brand  American Megatrends Inc.
      Version  204
      Date  12/25/2009
Graphics
    Monitor
      Name  HSD160PHW1 on NVIDIA GeForce GTS 360M
      Current Resolution  1366x768 pixels
      Work Resolution  1366x728 pixels
      State  enabled, primary
      Monitor Width  1366
      Monitor Height  768
      Monitor BPP  32 bits per pixel
      Monitor Frequency  60 Hz
      Device  \\.\DISPLAY1\Monitor0
      Memory  1024 MB
      Memory type  2
      Driver version  8.17.12.7533
Hard Drives
      Manufacturer  Seagate
      Form Factor  2.5"
      Cache Size  16MB
      Heads  16
      Cylinders  16383
      SATA type  SATA-II 3.0Gb/s
      Device type  Fixed
      ATA Standard  ATA8-ACS
      48-bit LBA  Supported
      Serial Number  5VJ3212W
      Interface  SATA
      Capacity  488GB
      Real size  500,107,862,016 bytes
        S.M.A.R.T
          01 Read Error Rate  117 (099 worst) Data 00081A3711
          03 Spin-Up Time  098 (097) Data 0000000000
          04 Start/Stop Count  099 (099) Data 00000004DA
          05 Reallocated Sectors Count  100 (100) Data 0000000007
          07 Seek Error Rate  074 (060) Data 000A872A6A
          09 Power-On Hours (POH)  093 (093) Data 0000001962
          0A Spin Retry Count  100 (100) Data 0000000000
          0C Device Power Cycle Count  099 (037) Data 00000004B5
          B8  100 (100) Data 0000000000
          BB  100 (100) Data 0000000000
          BC  100 (099) Data 0000000018
          BD High Fly Writes (WDC)  100 (100) Data 0000000000
          BE Temperature Difference from 100  060 (046) Data 0029280028
          BF G-sense error rate  100 (100) Data 0000000009
          C0 Power-off Retract Count  100 (100) Data 0000000043
          C1 Load/Unload Cycle Count  059 (059) Data 00000144BE
          C2 Temperature  040 (054) Data 0000000028
          C3 Hardware ECC Recovered  051 (046) Data 00081A3711
          C5 Current Pending Sector Count  100 (100) Data 0000000000
          C6 Uncorrectable Sector Count  100 (100) Data 0000000000
          C7 UltraDMA CRC Error Count  200 (200) Data 0000000000
          F0 Head Flying Hours  100 (253) Data 0000001884
          F1  100 (253) Data 00727A5304
          F2  100 (253) Data 009DC034EC
          FE Free Fall Protection  100 (100) Data 0000000000
          Temperature  40 °C
          Temperature Range  ok (less than 50 °C)
          Status  Good
        Partition 0
          Partition ID  Disk #0, Partition #0
          Size  200 MB
        Partition 1
          Partition ID  Disk #0, Partition #1
          Size  93.1 GB
        Partition 2
          Partition ID  Disk #0, Partition #2
          Disk Letter  C:
          File System  NTFS
          Volume Serial Number  6A05EEEF
          Size  93GB
          Used Space  48GB (52%)
          Free Space  45GB (48%)
        Partition 3
          Partition ID  Disk #0, Partition #3
          Size  260 GB
Optical Drives
      Media Type  DVD Writer
      Name  TSSTcorp CDDVDW TS-L633C ATA Device
      Availability  Running/Full Power
      Capabilities  Random Access, Supports Writing, Supports Removable Media
      Config Manager Error Code  Device is working properly
      Config Manager User Config  FALSE
      Drive  D:
      Media Loaded  FALSE
      SCSI Bus  1
      SCSI Logical Unit  0
      SCSI Port  1
      SCSI Target Id  0
      Status  OK
Audio
    Sound Cards
    Playback Devices
      Speakers (High Definition Audio Device)  (default)
      Digital Audio (S/PDIF) (High Definition Audio Device)
    Recording Devices
      Microphone (High Definition Audio Device)  (default)
      Line In (High Definition Audio Device)
    Speaker Configuration
Peripherals
      Device Kind  Keyboard
      Device Name  Keyboard Device Filter
      Location  plugged into keyboard port
        Driver
          Date  7-20-2009
          Version  1.0.0.3
          File  C:\Windows\system32\DRIVERS\kbfiltr.sys
          File  C:\Windows\system32\DRIVERS\i8042prt.sys
          File  C:\Windows\system32\DRIVERS\kbdclass.sys
      Device Kind  Mouse
      Device Name  Synaptics PS/2 Port TouchPad
      Location  plugged into PS/2 mouse port
        Driver
          Date  3-31-2011
          Version  15.2.20.0
          File  C:\Windows\system32\DRIVERS\SynTP.sys
          File  C:\Windows\system32\SynTPAPI.dll
          File  C:\Windows\system32\SynCOM.dll
          File  C:\Windows\system32\SynCtrl.dll
          File  C:\Program Files\Synaptics\SynTP\SynTPRes.dll
          File  C:\Program Files\Synaptics\SynTP\SynTPCpl.dll
          File  C:\Program Files\Synaptics\SynTP\SynCntxt.rtf
          File  C:\Program Files\Synaptics\SynTP\SynZMetr.exe
          File  C:\Program Files\Synaptics\SynTP\SynMood.exe
          File  C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
          File  C:\Program Files\Synaptics\SynTP\SynTPEnhPS.dll
          File  C:\Program Files\Synaptics\SynTP\SynTPCOM.dll
          File  C:\Program Files\Synaptics\SynTP\Tutorial.exe
          File  C:\Program Files\Synaptics\SynTP\InstNT.exe
          File  C:\Program Files\Synaptics\SynTP\SynISDLL.dll
          File  C:\Program Files\Synaptics\SynTP\SynUnst.ini
          File  C:\Program Files\Synaptics\SynTP\SynTPHelper.exe
          File  C:\Program Files\Synaptics\SynTP\StaticImg.html
          File  C:\Program Files\Synaptics\SynTP\StaticImg.png
          File  C:\Program Files\Synaptics\SynTP\SynSysDetect.js
          File  C:\Program Files\Synaptics\SynTP\Syn2FingerScrolling.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn3FingerFlick.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn4FingerFlick.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn4FingerFlickUpDown.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn4FingerFlickUpDownNB.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn3FingerPress.wmv
          File  C:\Program Files\Synaptics\SynTP\SynEdgeMotion.wmv
          File  C:\Program Files\Synaptics\SynTP\SynLinearScrolling.wmv
          File  C:\Program Files\Synaptics\SynTP\SynMomentum.wmv
          File  C:\Program Files\Synaptics\SynTP\SynMomentumScrolling.wmv
          File  C:\Program Files\Synaptics\SynTP\SynPinchZoom.wmv
          File  C:\Program Files\Synaptics\SynTP\SynPivotRotate.wmv
          File  C:\Program Files\Synaptics\SynTP\SynTwistRotate.wmv
          File  C:\Program Files\Synaptics\SynTP\SynCoverGesture.wmv
          File  C:\Program Files\Synaptics\SynTP\SynChiralRotate.wmv
          File  C:\Program Files\Synaptics\SynTP\SynReverseScrolling.wmv
          File  C:\Program Files\Synaptics\SynTP\SynChiralScrolling.wmv
          File  C:\Program Files\Synaptics\SynTP\SynCoastingScrolling.wmv
          File  C:\Program Files\Synaptics\SynTP\SynPointing.wmv
          File  C:\Program Files\Synaptics\SynTP\SynPalmCheck.wmv
          File  C:\Program Files\Synaptics\SynTP\SynSensitivity.wmv
          File  C:\Program Files\Synaptics\SynTP\SynWindowConstrained.wmv
          File  C:\Program Files\Synaptics\SynTP\SynSlowMotion.wmv
          File  C:\Program Files\Synaptics\SynTP\SynConstrainedMotion.wmv
          File  C:\Program Files\Synaptics\SynTP\SynTapping.wmv
          File  C:\Program Files\Synaptics\SynTP\SynButtons.wmv
          File  C:\Program Files\Synaptics\SynTP\SynTouchStykSelect.wmv
          File  C:\Program Files\Synaptics\SynTP\SynTouchStykButton.wmv
          File  C:\Program Files\Synaptics\SynTP\SynTouchStykSensitivity.wmv
          File  C:\Program Files\Synaptics\SynTP\SynEdgeMotionDragging.wmv
          File  C:\Program Files\Synaptics\SynTP\SynEdgeMotionFixedSpeed.wmv
          File  C:\Program Files\Synaptics\SynTP\SynEdgeMotionPointing.wmv
          File  C:\Program Files\Synaptics\SynTP\SynEdgeMotionPressure.wmv
          File  C:\Program Files\Synaptics\SynTP\SynNoButtons.wmv
          File  C:\Program Files\Synaptics\SynTP\SynTapZones.wmv
          File  C:\Program Files\Synaptics\SynTP\SynLinearHScrolling.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn2FingerHScrolling.wmv
          File  C:\Program Files\Synaptics\SynTP\SynTapHoldToDrag.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn1FingerClickNB.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn1FingerClickDrag.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn2FingerFlickNB.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn2FingerHScrollingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn2FingerScrollingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn3FingerFlickNB.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn3FingerPressNB.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn4FingerFlickNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynButtonsNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynChiralRotateNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynChiralScrollingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynCoastingScrollingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynConstrainedMotionNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynCoverGestureNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynEdgeMotionDraggingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynEdgeMotionFixedSpeedNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynEdgeMotionNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynEdgeMotionPointingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynEdgeMotionPressureNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynLinearHScrollingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynLinearScrollingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynMomentumNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynMomentumScrollingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynPinchZoomNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynPivotRotateNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynReverseScrollingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynSensitivityNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynSlowMotionNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynTapHoldToDragNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynTapZonesNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynTwistRotateNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynPointingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynPalmCheckNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynWindowConstrainedNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynTappingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn2FingerMomentumVHScrolling.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn2FingerMomentumVHScrollingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn2FingerVHCoasting.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn2FingerVHCoastingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynMomentumVHScrolling.wmv
          File  C:\Program Files\Synaptics\SynTP\SynMomentumVHScrollingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\SynVHCoasting.wmv
          File  C:\Program Files\Synaptics\SynTP\SynVHCoastingNB.wmv
          File  C:\Program Files\Synaptics\SynTP\Syn2FingerScrolling.html
          File  C:\Program Files\Synaptics\SynTP\Syn2FingerFlick.html
          File  C:\Program Files\Synaptics\SynTP\Syn3FingerFlick.html
          File  C:\Program Files\Synaptics\SynTP\Syn4FingerFlick.html
          File  C:\Program Files\Synaptics\SynTP\Syn4FingerFlickUpDown.html
          File  C:\Program Files\Synaptics\SynTP\Syn3FingerPress.html
          File  C:\Program Files\Synaptics\SynTP\SynEdgeMotion.html
          File  C:\Program Files\Synaptics\SynTP\SynMomentum.html
          File  C:\Program Files\Synaptics\SynTP\SynPinchZoom.html
          File  C:\Program Files\Synaptics\SynTP\SynRotating.html
          File  C:\Program Files\Synaptics\SynTP\SynTwistRotate.html
          File  C:\Program Files\Synaptics\SynTP\SynCoverGesture.html
          File  C:\Program Files\Synaptics\SynTP\SynAccessibility.html
          File  C:\Program Files\Synaptics\SynTP\SynButtons.html
          File  C:\Program Files\Synaptics\SynTP\SynClicking.html
          File  C:\Program Files\Synaptics\SynTP\SynMultiFingerGestures.html
          File  C:\Program Files\Synaptics\SynTP\SynPalmCheck.html
          File  C:\Program Files\Synaptics\SynTP\SynPointing.html
          File  C:\Program Files\Synaptics\SynTP\SynScrolling.html
          File  C:\Program Files\Synaptics\SynTP\SynSensitivity.html
          File  C:\Program Files\Synaptics\SynTP\SynTapping.html
          File  C:\Program Files\Synaptics\SynTP\SynTouchStykButton.html
          File  C:\Program Files\Synaptics\SynTP\SynTouchStykSelect.html
          File  C:\Program Files\Synaptics\SynTP\SynTouchStykSensitivity.html
          File  C:\Program Files\Synaptics\SynTP\OEMDefault.syn
          File  C:\Program Files\Synaptics\SynTP\OEMPointingAndClickingOnly.syn
          File  C:\Program Files\Synaptics\SynTP\OEMDefaultWithMomentum.syn
          File  C:\Windows\SysWOW64\SynCOM.dll
          File  C:\Windows\SysWOW64\SynCtrl.dll
          File  C:\Windows\SysWOW64\SynTPCOM.dll
          File  C:\Windows\SysWOW64\SynTPEnhPS.dll
          File  C:\Windows\system32\DRIVERS\mouclass.sys
          File  C:\Windows\system32\SynTPCo9.dll
          File  C:\Windows\system32\WdfCoInstaller01009.dll
    Wacom Mouse
      Device Kind  Mouse
      Device Name  Wacom Mouse
      Location  Wacom Virtual Hid Driver
        Driver
          Date  6-29-2009
          Version  1.2.2.0
          File  C:\Windows\system32\DRIVERS\wacommousefilter.sys
          File  C:\Windows\system32\DRIVERS\mouhid.sys
    USB Video Device
      Device Kind  Camera/scanner
      Device Name  USB Video Device
      Vendor  Unknown
      Comment  USB2.0 UVC 1.3M WebCam
      Location  0000.001a.0000.001.006.000.000.000.000
        Driver
          Date  6-21-2006
          Version  6.1.7601.17514
          File  C:\Windows\system32\drivers\usbvideo.sys
Network
  You are connected to the internet
  Connected through  Atheros AR9285 Wireless Network Adapter
  IP Address  192.168.1.108
  Subnet mask  255.255.255.0
  Gateway server  192.168.1.1
  Preferred DNS server  8.8.8.8
  Alternate DNS server  8.8.4.4
  Alternate DNS server  64.233.217.2
  Alternate DNS server  64.233.217.3
  Alternate DNS server  192.168.1.1
  DHCP  Enabled
  DHCP server  192.168.1.1
  External IP Address  96.27.15.96
  Adapter Type  IEEE 802.11 wireless
  NetBIOS over TCP/IP  Enabled via DHCP
  NETBIOS Node Type  Hybrid node
  Link Speed  0 kbps
    Computer Name
      NetBIOS Name  NMN-PC
      DNS Name  nmn-PC
      Domain Name  nmn-PC
    Remote Desktop
        Console
          State  Active
          Domain  nmn-PC
    WinInet Info
      LAN Connection
      Local system uses a local area network to connect to the Internet
      Local system has RAS to connect to the Internet
    Wi-Fi Info
      Using native Wi-Fi API version  2
      Available access points count  1
        Wi-Fi (linksch)
          SSID  linksch
          Frequency  2412000 kHz
          Channel Number  1
          Name  No name
          Signal Strength/Quality  78
          Security  Enabled
          State  The interface is connected to a network
          Dot11 Type  Infrastructure BSS network
          Network  Connectible
          Network Flags  Currently Connected to this network
          Cipher Algorithm to be used when joining this network  WEP cipher algorithm with a cipher key of any length
          Default Auth used to join this network for the first time  IEEE 802.11 Open System authentication algorithm
    WinHTTPInfo
      WinHTTPSessionProxyType  No proxy
      Session Proxy
      Session Proxy Bypass
      Connect Retries  5
      Connect Timeout  60000
      HTTP Version  HTTP 1.1
      Max Connects Per 1.0 Servers  INFINITE
      Max Connects Per Servers  INFINITE
      Max HTTP automatic redirects  10
      Max HTTP status continue  10
      Send Timeout  30000
      IEProxy Auto Detect  No
      IEProxy Auto Config
      IEProxy
      IEProxy Bypass
      Default Proxy Config Access Type  No proxy
      Default Config Proxy
      Default Config Proxy Bypass
    Sharing and Discovery
      File and Printer Sharing  Disabled
      Media Sharing  Disabled
    Adapters List
          IP Address  0.0.0.0
          Subnet mask  0.0.0.0
          Gateway server  0.0.0.0
        VirtualBox Host-Only Ethernet Adapter
          IP Address  192.168.56.1
    Network Shares
      No network shares
(slightly modified, from Piriform Speccy)
My Foobar components (I doubt it's useful, but just in case:)
Core (2011-06-05 09:16:20 UTC)
    foobar2000 core 1.1.7
foo_albumlist.dll (2011-06-05 09:14:24 UTC)
    Album List 4.5
foo_cdda.dll (2011-06-05 09:14:20 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2011-06-05 09:13:50 UTC)
    Converter 1.5
foo_dsp_std.dll (2011-06-05 09:14:22 UTC)
    Standard DSP Array 1.0
foo_freedb2.dll (2011-06-05 09:13:14 UTC)
    freedb Tagger 0.6.4
foo_input_std.dll (2011-06-05 09:13:58 UTC)
    Standard Input Array 1.0
foo_rgscan.dll (2011-06-05 09:13:54 UTC)
    ReplayGain Scanner 2.1.2
foo_ui_minilyrics.dll (2011-07-18 16:10:50 UTC)
    MiniLyrics 1.0
foo_ui_std.dll (2011-06-05 09:14:24 UTC)
    Default User Interface 0.9.5
foo_unpack.dll (2011-06-05 09:13:24 UTC)
    ZIP/GZIP/RAR Reader 1.6
Thanks for reading (and thanks for Foobar, the only sane music players in active development...)
Whoops, this appears to be a duplicate... I couldn't find the forum search feature at first but now that I have, I found I wasn't the only one to report this.
http://www.hydrogenaudio.org/forums/index....showtopic=89213
I apologize. I'm used to the search feature in vBulletin being hidden in a dropdown at the top, as opposed to the bottom of the forum...
I’ve merged the topics. But both the IPB and Google searches are at the top of the page…or have I been living a lie? Oh, and we incurable pedants are mouthing at the screen: foobar2000.
Okay, I'm not sure why I missed search the first time around now that I look again. If I had realized it was an IP.Board, maybe I wouldn't have been searching for the vBulletin dropdown  Oh well...
As far as the name goes, I understand that. I just have a habit of not being consistent with stylization of names...
edit: Okay, that's irritating... Somehow, I managed to double-submit... Not off to a great start with this board
Have there been any solutions worked out for this problem? My volume in foobar2000 seems to decrease in the manner described above, but occurs at random times instead of just after hibernation/sleep. I'm running foobar2000 v1.1.6 on Windows 7 SP 3 and have the freedb Tagger and Discogs Tagger components installed.
