Topic: Track Gain calculated in Foobar v1.1.7 is different that in v1.1.6 (Read 1852 times) previous topic - next topic
After I installed the new version Foobar2000 v1.1.7, I noticed that the ReplayGain calculated were different from the calculated in the previous version v1.1.6.
For example, in the following musics that I ripped from my CDs (to FLAC codec):
INX – Need You Tonight (album Greatest Hits):
  Foobar v1.1.6 – Track Gain = -6.76 dB / Track Peak = 0.953888
  Foobar v1.1.7 – Track Gain = -5.22 dB / Track Peak = 0.953888
New Order – Regret (album The Best of New Order):
  Foobar v1.1.6 – Track Gain = -9.84 dB / Track Peak = 0.999969
  Foobar v1.1.7 – Track Gain = -11.20 dB / Track Peak = 0.999969
Is this right? The new Track Gain will be adopted from now?
My system: Windows Vista Home Premium SP2.
Components installed: File Integrity Verifier / Masstager / Playback Statistics.
The other components are the installed together with Foobar by default.
[doublepost]
http://www.foobar2000.org/changelog
1.1.6 - "ReplayGain scanner now uses libebur128 for improved accuracy."
1.1.7 - "Updated ReplayGain scanning code to the latest version of libebur128."
EDIT: redundant post
Gain calculation was updated in 1.1.7. Not sure what "adopted from now" means. It is the implementation that is currently used and I would guess will be until/ if an improvement occurs within libebur128
From the change log
