Topic: Crash at the end of the installer (Read 2442 times) previous topic - next topic
Beta 3 and 4 crashed on install, but otherwise seem to function normally.
Core (2011-05-22 12:14:08 UTC)
    foobar2000 core 1.1.7 beta 4
foo_abx.dll (2009-06-07 18:25:26 UTC)
    ABX Comparator 1.3.4
foo_ac3.dll (2010-04-13 12:00:12 UTC)
    AC3 decoder 0.9.5
foo_albumlist.dll (2011-03-11 14:16:10 UTC)
    Album List 4.5
foo_cdda.dll (2011-05-22 12:12:40 UTC)
    CD Audio Decoder 3.0
foo_comserver2.dll (2006-07-31 19:13:20 UTC)
    COM Automation server 0.7 alpha 6
foo_converter.dll (2011-05-22 12:12:44 UTC)
    Converter 1.5
foo_dop.dll (2011-03-06 18:19:07 UTC)
    iPod manager 0.6.8.9
foo_dsp_std.dll (2011-03-11 14:16:10 UTC)
    Standard DSP Array 1.0
foo_facets.dll (2008-12-01 00:36:31 UTC)
    Facets 2008-02-25
foo_fileops.dll (2011-03-11 14:14:46 UTC)
    File Operations 2.1.3
foo_freedb2.dll (2011-05-22 12:11:22 UTC)
    freedb Tagger 0.6.4
foo_input_alac.dll (2011-02-26 16:53:14 UTC)
    ALAC Decoder 1.0.7
foo_input_monkey.dll (2011-04-27 18:39:42 UTC)
    Monkey's Audio Decoder 2.1.5
foo_input_std.dll (2011-05-22 12:12:20 UTC)
    Standard Input Array 1.0
foo_jesus.dll (2010-09-23 06:34:06 UTC)
    Autosave & Autobackup 10
foo_masstag.dll (2009-09-18 14:01:36 UTC)
    Masstagger 1.8.4
foo_playcount.dll (2011-04-27 18:39:44 UTC)
    Playback Statistics 3.0.1
foo_pqview.dll (2008-03-11 23:02:54 UTC)
    Playback Queue Viewer 0.2
foo_random_pools.dll (2010-09-11 17:02:12 UTC)
    Random Pools 0.0.2.3
foo_rgscan.dll (2011-05-22 12:12:16 UTC)
    ReplayGain Scanner 2.1.2
foo_textdisplay.dll (2008-07-08 23:45:26 UTC)
    Text Display UI Element 1.0 RC 3
foo_texttools.dll (2010-08-24 13:49:52 UTC)
    Text Tools 1.0.5
foo_ui_std.dll (2011-05-22 12:12:52 UTC)
    Default User Interface 0.9.5
Much better.
For what it's worth, this version did not crash on installation for me, while betas 3 and 4 crashed at the end of installation.
Fair enough.  I'd just note that the only crashes I can recall (at least several months) have been installing betas 3 and 4, and even then the crashes didn't interfere with the install so far as I could tell. Hard to troubleshoot something that's so rare.  I suppose the issue with problematic components is that problems can be erratic.
thanks
Do you auto-submit your crash reports? I see only one entry matching your current IP, submitted 3 days ago. It looks like a problem with iTunes libraries invoked by foo_dop. If you have other reports that you wish me to look at but did not auto-submit them, feel free to zip them up and post them in the uploads forum.
Reproduced the issue with iPod manager/Apple libraries. It doesn't seem to get triggered on 64-bit OSes, but it's some kind of race condition I think. Anyway, I'm looking into a fix or workaround..
I've put up version 0.6.9.4 with a workaround.
It would be good if you could verify the problem is fixed: if you close foobar2000 and run "foobar2000 /quiet" several times before updating iPod manager, it should crash on some of the runs, but that should stop after updating to 0.6.9.4.
foobar2000 /quiet does not crash on repeated tries.  I run foobar at least once a day and I can't remember the last time it crashed, other than at the end of the installation of beta 3 and beta 4.  At this point I'd think the problem is more random fluctuations in the force than anything reproducible.
As suggested by shakey_snake and the troubleshooter, I had removed comserver2.
Anything else I should check or info I should provide?
I can post the earlier crash log, if you or Peter think it would be helpful.  As Peter noticed, I submitted for beta 4 but not 3.
Not unreproducible if it happened twice on installation? The installer silently launches foobar2000 in a similar way, but perhaps the preceding installation operations had an influence in your case. The problem is just ill-written Apple libraries, in this case calling two functions with a particular short time interval in-between them results in this nonsense. It should be fixed anyway.
