Topic: foo_dsp_xgeq (Read 196001 times) previous topic - next topic
Re: foo_dsp_xgeq
Reply #200
When I use the integrated EQ:
Move the Bar up --> Plus db --> increase the chosen frequenz --> more bass for example
Move the Bar down --> Minus db --> decrease the chosen frequenz
When I use this more detailed plug-in Graphic EQ:
Move the Bar up --> Plus db --> decrease the chosen frequenz --> less bass for example
Move the Bar down -->Minus db --> increase the chosen frequenz
Plus and Minus interchanged?
Re: foo_dsp_xgeq
Reply #201
Definitely not seeing that here, works as expected.  Move higher freq silders down, less higher freqs.
Re: foo_dsp_xgeq
Reply #202
Please allow me to post by machine translation
I am trying to output the equalizer settings for this plug-in at AutoEQ (https://github.com/jaakkopasanen/AutoEq)
The frequency list is
--fc 20, 25, 31.25, 40, 50, 62.5, 80, 100, 125, 160, 200, 250, 315, 400, 500, 630, 800, 1000, 1250, 1600, 2000, 2500, 3150, 4000, 5000, 6300, 8000, 10000, 12500, 16000, 20000
or
--fc 19.69, 24.8, 31.25, 39.37, 49.6, 62.5, 78.75, 99.21, 125, 157.49, 198.43, 250, 314.98, 396.85, 500, 629.96, 793.7, 1000, 1259.92, 1587.4, 2000, 2519.84, 3174.8, 4000, 5039.68, 6349.6, 8000, 10079.37, 12699.21, 16000, 20158.74
which one is correct
Re: foo_dsp_xgeq
Reply #203
What does the Auto button do?  When checked, it seems to invert the slider (up means it cuts the band).  Reset returns the Auto button to selected.
Re: foo_dsp_xgeq
Reply #204
A "bypass" button would be great.
