Topic: foo_dsp_xgeq (Read 200207 times) previous topic - next topic
foo_dsp_xgeq
Reply #50
Hey Xnor!
Thanks for this great equalizer!
One thing for your to-do-list: What I'm really missing is that there's no way to see the values I actual set for each band. Would it be possible to make them visible? (Just like the value for the master gain slider.)
foo_dsp_xgeq
Reply #51
Does anyone actually need the full range of +-18 dB? Cause I'd like to reduce the steps from .5 to .1 dB which would result in 360 slider positions.
"I hear it when I see it."
foo_dsp_xgeq
Reply #52
Under wine it seems impossible to use this component: If I try to adjust any slider, it pops on top (+18dB) and can't be dragged or anything.
It looks like implemented 'draw on sliders' feature may be the cause.
foo_dsp_xgeq
Reply #53
Interesting. Does pressing tab to focus sliders and up/down arrow keys or page up/down work?
foo_dsp_xgeq
Reply #54
Yes, keyboard seems to handle sliders fine
foo_dsp_xgeq
Reply #55
I'm not using the full range of +/-18dB. My Sliders are all between +/-6dB. Therefore you could cut the range to, let's see, +/-12dB, which would result in 240+1 (+/-0dB  ) slider positions.
But I'm curious to know, what you're thinking about making the values visible. (As I've requested in a previous post.) If you're changing the steps to 0.1 dB, then it would be also helpful to make it possible to set the values via Keyboard. Some kind of input box, for example, would do that.
foo_dsp_xgeq
Reply #56
Yeah I think an edit box with the selected band's gain should do.
foo_dsp_xgeq
Reply #57
Are you making any progress on implementing saved presets? I really would like to used this EQ, but
1. It resets to zero on a cold start of my computer.
2. When I change speakers, I have to start from zero.
I see that you are putting a lot of effort on your crossfeed plug-in. Perhaps you could spend a little time here?
Thanks,
Bob
foo_dsp_xgeq
Reply #58
You're right, I spent most of the time on the crossfeed but there's definitely progress going on with the EQ. Just need to put it into a releasable state.
Regarding presets, do the DSP chain presets (DSP Manager configuration page) also get lost? That'd be strange.
foo_dsp_xgeq
Reply #59
xnor, are you doing a crossfeed plugin? Could you link it, please?
foo_dsp_xgeq
Reply #61
The DSP manager configuration remains intact. xgeg reappears in the chain at system restart, but the graph is zero'd out. If I simply close and reopen f2k, the graph remains as last set.
BTW, in my installation, f2k forgets where my presets are for the default equalizer.
Bob
foo_dsp_xgeq
Reply #63
This is weird and should not happen.
Anyway, I've added a simple import/export feature now. Version 0.2.0 released.
foo_dsp_xgeq
Reply #64
xnor- grus dich
i am using some modded drivers for my old soundcard that improve the sound quality, but i notice that the overall volume is a bit lower than with the manufacturer's drivers- can i use this equalizer to boost the volume a bit by increasing the master gain +1 db? i don't know much about this stuff
great plugin by the way!
foo_dsp_xgeq
Reply #65
chrome_waves, I don't know why the modded drivers have lower output volume so it's difficult to give advice.
Modern recordings touch 0 dBFS regularly so even a 1 dB volume boost will most likely degrade sound quality. So all I can suggest is to double check the Windows Mixer, playback device properties and soundcard control panel for anything that could attenuate the signal.
foo_dsp_xgeq
Reply #66
Can you extend the frequency range of the dsp to 10HZ - 30KHz?
So i can use it to equalize perfectly my headphone using headroom frequency response graph like this.
foo_dsp_xgeq
Reply #67
touccer, I don't really see the point. The frequency response of the EQ extends beyond the first and also last band, to be precise down to 0 Hz and up to sampling rate / 2 (e.g. 22.05 kHz for 44.1 kHz audio).
foo_dsp_xgeq
Reply #68
i'm using the pax drivers for the old soundblaster live! /audigy cards
http://www.hardwareheaven.com/pax-drivers/
foo_dsp_xgeq
Reply #69
Hey Xnor!
Thanks for making the band values visible. Although I had it's realization a bit different in mind. But it works and this is all I need.
foo_dsp_xgeq
Reply #70
How can i apply a gain to the 10 Hz band for example?
foo_dsp_xgeq
Reply #71
It has the same gain as the 20 Hz band.
Roll-off at the frequency extremes is normal, don't fight it.
foo_dsp_xgeq
Reply #72
Just installed it yesterday, and it works fine!
And, in contrast to the default EQ, even gapless playback works fine with FLAC, mp3, so far tested.
Is it possible to ad graphic equalizer into the "View" menu in order to open it faster?
cu
jgro
foo_dsp_xgeq
Reply #73
I think so, but the fb sdk is imo not documented properly so I'll have to bother some of the other devs about it.
foo_dsp_xgeq
Reply #74
Hopefully someone can help you.
Would be great for quick dis-/enabling graphic equalizer.
cu
jgro
