Topic: How to normalize streams (Read 1570 times) previous topic - next topic
Hi everybody ! Happy Easter !
I'm sure that this is not caused by the different streaming format. It's just a case of bad luck. However, how to deal with this issue ? Is there something out there like a component which pre-amplifies certain streams to a specified volume ?
Why do you use foo_input_mslive?
Lets read the change log before ask here
Are you referring to the fact that foo_input_mslive has been updated/renamed to foo_input_msl.dll ? Well, that one's not working here. All I get is an error message telling me that "The specified procedure could not be found". This may be due to the fact that I'm using an outdated version of foobar, which is compatible to some certain skin & dll stuff.
However, if I got you wrong, please explain.
