Topic: Default UI (Read 3112 times) previous topic - next topic
Default UI
Think this must be simple, but I am stymied: How does one remove an element in the Default UI?  I have picked "Visualization + Cover Art + Tabs" from the Quick Setup, and now just want to get rid of the Visualization box, at lower right.  I must have done it before (had to reconfigure after a recent mysterious crash), but can't now.  Have tried the splitter, and everything else obvious.
Thanks in advance...
N.
Default UI
View>Layout>enable edit mode.
Right click and add / delete / change
Default UI
Thanks much for your attention..  Actually, I solved the problem after I posted this, after finding a thread here from 2008 (I would post a link, but now I can't find it).  The problem was not deleting the element (Visualization), per se, but rather getting rid of the resultant empty box.
The solution: with layout editing mode enabled, find the "unlock pane" menu option that comes up only when one right clicks while hovering on the pane rule (so that you have a double-headed arrow).  One can then adjust the relative sizes of the panes (reducing one to nothing, in effect, if desired).
Default UI
I have to point out that adjusting the layout in the manner you just did results in an unnecessary separator being present:
The way to fix that is to right click the playlist view, select cut, and paste it over the separator:
http://i.imgur.com/m3df2.png
http://i.imgur.com/U4EiN.png
And you would have a layout that's free of unnecessary elements:
http://i.imgur.com/twckA.png
Default UI
Thanks very much.  Most helpful.  I'll do it.
