Topic: oggdropXPd bug (Read 5895 times) previous topic - next topic
oggdropXPd bug
Hi.
I believe I've found a bug in oggdropXPd, but I'm not sure to whom or how to report it.  I googled and searched rarewares to no avail.
Does anyone have any information on filling a bug report for oggdropXPd??
oggdropXPd bug
Post the bug here so other people can confirm it.
oggdropXPd bug
And so I can look into it if it is real.
oggdropXPd bug
Great!  Here is the problem I'm having.  I'm a classical music fan (and no that isn't the problem ) and I have been using the unicode character for sharp (♯) and flat (♭) in my flac filenames when appropriate.  When I use oggdropXPd (oggdropXPd V.1.9.0 using aoTuVb6.02) and drag-n-drop a flac file whose name contains one of these characters, I get this error "Cannot open input file "<filename>'  error is Invalid argument (22)".
If I rename the file, removing the sharp or flat character, oggdropXPd works fine.
oggenc2 from the command line doesn't have this problem, so that has been my workaround.  But I would really like it if oggdropXPd could handle flac filenames with these characters.
Thanks for looking into this!
oggdropXPd bug
Great!  Here is the problem I'm having.  I'm a classical music fan (and no that isn't the problem ) and I have been using the unicode character for sharp (?) and flat (?) in my flac filenames when appropriate.  When I use oggdropXPd (oggdropXPd V.1.9.0 using aoTuVb6.02) and drag-n-drop a flac file whose name contains one of these characters, I get this error "Cannot open input file "<filename>'  error is Invalid argument (22)".
OK, thanks for the info. I'll look into this, but unless I find a resolution in the next couple of days, it'll have to wait until after I return on 2 May from an Easter trip to France.
Edit: This is a unicode issue and will not be trivial to resolve, so it will not happen until some time during the first half of May, at the earliest.
oggdropXPd bug
Wonderful.  Don't hurry for a fix on my part...oggenc2 is working fine.
Thanks for all of your work on these ogg tools!
