Topic: How to extract tags and covers from a WavPack file (Read 11147 times) previous topic - next topic
Title says all.
I'd like to know a few examples!
On linux or Windows or other?
If something like linux have a look at the first post here
http://www.hydrogenaudio.org/forums/index....showtopic=87245
For extracting cover art you could try something like
wvunpack -xx "Cover Art (Front)=file.jpg" -v test.wv
which in this case would extract the cover art and put in a file called file.jpg
Linux here. Thanks for the info.
Ok, here' the issue:
MP3Tag is showing ONE front cover and ONE back cover, duplicated, so it shows as 4 embedded files.
But foobar2000 is actually showing ONE front, ONE back and the ONE disc image, totalizing 3 images.
What I wanted is to extract each one of them and I can't get this done, is there a way to list the tag fields to know their names?
wvunpack -ss test.wv
lists all the tags
-ss actually display the stream information... it doesn't return tags (although help says 'including tags'). The tags here are APEv2.
It certainly does for me on Windows
C:\Music>wvunpack -ss "01 Set Guitars to Kill.wv"
WVUNPACK  Hybrid Lossless Audio Decompressor  Win32 Version 4.60.1
Copyright (c) 1998 - 2009 Conifer Software.  All Rights Reserved.
file name:         01 Set Guitars to Kill.wv
file size:         43179812 bytes
source:            16-bit ints at 44100 Hz
channels:          2 (stereo)
duration:          0:05:29.59
modalities:        lossless
compression:       25.73%
ave bitrate:       1048 kbps
encoder version:   4
original md5:      4cabc20b552e10751823d571c082f4e1
file wrapper:      44 byte RIFF header
APEv2 tag items:   7
Album:             And So I Watch You From Afar
Artist:            And So I Watch You From Afar
Genre:             Post Rock
Title:             Set Guitars to Kill
Track:             1
Year:              2009
Cover Art (Front): 128825-byte binary item
Something's wrong on my side...
edit:  it's a full image, no embedded cuesheet, and MP3Tag says it is APEv2 - and it shows the tags... weirdest thing.
If the total size of the APEv2 tag is over 1MB, then WavPack will ignore it (I think...I'm away from home/code). If other programs are showing the tags and wvunpack is not, then that would be my first guess.
If the tags were created by another program, then perhaps WavPack is just more picky about the tags being correctly formatted.
edit: spelling/typo
Thanks bryant. Yes, The images go over 1MB easily, I can see that. That's why is not returning on command line.
What program is recommended besides MP3Tag to extract the binary tags
Ok, I just realized I have a .iso.wv file which is not a true wavpack file, but a ZIP file with the wavpack file and other files. Whoever made the file this way has plenty crap on his mind. I was curious about "iso.wv", that is why I got this file...
