Topic: Seeking unaltered conversion of .ogg to .wav (Read 1982 times) previous topic - next topic
Hello!
I have a TON of 24-bit, 44.1 kHz .ogg files to batch convert into .wavs for a sound collage project I'm working on. My problem is that everytime I convert the .oggs into uncompressed .wavs (while maintaining the same sample rate and bit-depth in the conversion process) there are changes to the waveforms and sound.
Granted, these changes are generally somewhat subtle, but sometimes they can significantly change the sound in terms of its attack and overall sonic character. I've A/B'd this dozens of times with Audioease's Snapper 2, switching back and forth between views of the pre and post-converted files (both the original .ogg and the .wav version), and it's definitely not just a one-off error. Furthermore, this change in the sound happens regardless of which audio conversion tool I'm using, whether it's NCH's Switch, Hoot Tech's WAVMP3 converter, or the demo version of Barbabatch.
Any ideas on why the waveform of a sound file would be altered during a "lossless" file conversion process? Any feedback at all would be greatly appreciated!
When you play a .ogg file, its decoded basically to WAV (or something similar).  Some what you're doing is comparing one WAV to another.  If they're not identical, then you're probably doing something wrong, or at least different when you convert one file verses the other.
What difference are you seeing in the waveforms?
If Snapper sounds different than everything else, maybe it's doing something different, or maybe it's defective???
Or, the only thing I can think of that would affect the sound during decoding would be ReplayGain.  I suppose ReplayGain could kick-in during playback, but be ignored when the file is transcoded to WAV.  That would give you two different volumes, but that would require a rather specific set of circumstances.
And, you must also decompress to display the waveform...    You can plot the raw data from an uncompressed WAV/AIFF/PCM file and you will see the waveform.  But, if you plot the raw-uncompressed data from an OGG (or other compressed) file, it's going to look like noise, and since it's compressed there aren't as many data points so the "waveform" would be much shorter (assuming the same number of samples/data-points per-inch/cm).
