Topic: WAV to lossywv via LossyWAV not working (Read 4235 times) previous topic - next topic
For some reason, I'm having major problems using LossyWAV to convert pure WAV files into lossywv files. Every time I attempt it, I get this error message:
1 out of 1 tracks converted with major problems.
Source: "C:\Documents and Settings\Default User\My Documents\My Music\1987 - Dirty Dancing\01 - (I've Had) The Time of My Life.wav"
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "C:\Documents and Settings\RKA\My Documents\My Music\1987 - Dirty Dancing\01 - (I've Had) The Time of My Life.lossy.wv"
  Additional information:
  Encoder stream format: 44100Hz / 2ch / 16bps
  Command line: "C:\Windows\System32\cmd.exe" /d /c C:\"Program Files"\bin\lossywav - --standard --silent --stdout|C:\"Program Files"\bin\wavpack -hm --blocksize=512 --merge-blocks -i - "01 - (I've Had) The Time of My Life.lossy.wv"
  Working folder: C:\Documents and Settings\RKA\My Documents\My Music\1987 - Dirty Dancing\
  Conversion failed: The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters
I've checked the parameters, and they're the one's that've been posted:
Encoder: c:\windows\system32\cmd.exe
Extension: lossy.wv
Parameters: /d /c c:\"program files"\bin\lossywav - --standard --silent --stdout|c:\"program files"\bin\wavpack -hm --blocksize=512 --merge-blocks -i - %d
Format is: lossless or hybrid
Highest BPS mode supported: 24
Correction: This happened in foobar2000, and with WavPack
Nevermind. Figured out foobar2000 didn't know where to look for LossyWAV or Wavpack.
