Topic: Banana splits (Read 5385 times) previous topic - next topic
Banana splits
I have five William Burroughs lectures/readings/ramblings that are all over ninety-minutes long. All the aforementioned chap does is talk, cough, ramble and light a cigarette every so often. I've tried to split one-hundred minute tracks into two fifty-minute ones, etc, with dismal results. 'Wave Editors', 'File-Splitters' a-go-go: nix!
Anyone with any info -- I have the Hydrogen Auto Cue Tool to work in conjunction with the totally excellent E.A.C. bit-of-kit: I can't even split a banana with the thin.
Now then, I'm no computer maven, but usually just find out what I have to do to and, erm, do it; however, I've hit a rather large brick wall with this one.
I'd be grateful for any and all advice stated simply for a poor Non-Geek in Geeksville.
I've just found out that, in this twenty-first of centuries, one is not able to buy a CD-R 120...
        Okus dokus.
Banana splits
The task is not difficult, but may be tedious if you want to edit the content. However, you have not given any hints about what impedes you. What are the specifications of your sources? What kind of system are you working on? What particular problems are you encountering? Do you simply want to break the audio files into shorter lengths or also accomplish something more?
Banana splits
If the files were compressed in FLAC then you could use the --skip=mm:ss.ss and --until=mm:ss.ss to extract chunks of the file (and re-encode fairly easily).
lossyWAV -q X -a 4 -s h -A --feedback 2 --limit 15848| FLAC -5 -e -p -b 512 -P=4096 -S-
Banana splits
If one has enough RAM memory (at least 2GB for 90+ minutes), even the simple Windows Sound Recorder can do what the OP wants.
I do it all the time.
I load a 900 MB WAV file (standard 44/16/2) which is about 90 minutes long into Windows Sound Recorder.  Then you move the slider to the position where you want to "cut" the audio.  Then choose Edit->Delete After Current Position.
Save the resulting trimmed audio to a new WAV file, like "First-Part.wav"
Repeat on original WAV file and choose Edit->Delete Before Current Position instead.
Save to WAV file named something like "Second-Part.wav"
Banana splits
A .cue file can be (mis)used to do this too. Use foobar2000 to play the cue, and convert the "tracks" to .wav. (can be done all at the same time).
But probably a more visual way than a .cue is needed here, so using an audio editor is preffered.
Of course you can.. you can buy a single layer DVD of 4.7GB, you can buy a dual layer DVD 8.5GB, you can buy a blu-ray 25GB or 50GB.... (one could even buy an HD-DVD of 30GB before the format was killed).
Oh, and of course then there is SD, microSD, USB pen drive....
In other words, you cannot get something old and magically made it work as if it was something new.
Banana splits
[quote author=[JAZ] link=msg=747932 date=1299941206]
[/quote]
Q) When is a CD-R not a CD-R? A) When some supercilious prick turns it into a DVD
If you need to record for 120 minutes you need to split your recording onto two CDs. Or you need to record a DVD Audio disc which is not compatible with a CD player and may not be compatible with all DVD players.
Source(s):
CD-R explained:
Banana splits
Many CD players will play a CD with mp3 files. This could increase the capacity to several hours.
Banana splits
You may not like my answer, but telling me such thing doesn't make your point any better.
A Red Book CD (Audio CD) is defined for two physical sizes: 8cm or 12cm of diameter (you can't put a bigger one on a CD player), and the physical dimensions of the data, and how is this data interpreted is defined by the standard and is unchangeable: http://en.wikipedia.org/wiki/Red_Book_%28CD_standard%29
So, now, tell me how can you have a Red Book CD that still has 12cm of diameter, still conforms to the Red Book CD standard in terms of physical size of the data in this disc, and actually have more data?
I gave you the answer to this question: It is not possible, you have to change the standard (like DVD and Blu-ray)
Banana splits
Just get a sound editor. I have Sony Sound Forge (my favorite and the best), Audacity (great for recording audio from computer), and Magix Music Maker (least favorite, just in case).
Foobar 2000 1.01
Banana splits
It's the best because it is your favorite, or it is your favorite because it is the best?
Please stop with the subjective nonsense already!
