Topic: Please fix foo_psf.dll (Read 4487 times) previous topic - next topic
I use the last 2.0.19 version of the Highly Experimental
with .PSF files = no problem
but when I play .minipsf the tempo i too fast,and the problem isn't with their lib files,because i tryed them with the last Winamp PSF plugin,and everything is OK there!
So please recompile that version for Foobar2000.
I cannot reproduce your issue, my PSF and MINIPSF files all play at the correct tempo. Post a link to a rip which does not and I'll look into the issue.
I'm having the same problem with a rip of Crash Bandicoot 2. I have no idea if it runs better in other players, but I have become almost dependent on foobar2000 so to find a new player would handicap me.
http://dl.dropbox.com/u/1274793/CrashBandicoot2_psf.zip
I would be thankful if you could take a look at this!
Yes,that is the rip that i have too.With Crash Bandicoot 3 - same problem : http://www.zophar.net/download_file/18078
because it's .MINIPSF again.
Crash bandicoot 1 plays normaly because there are .PSF files.
And another thing...
I can play .PSF files with foobar2000 well,but in Winamp sounds better,with more bass,just like it's in the game!
.PSF plays with normal tempo in foobar2000,but something isn't completely right!
for example: Crash Bandicoot 1 http://www.zophar.net/download_file/19016
play it with both players and see what I mean...
the difference it's audible on every song ,but i hear it most on the beginning of the 003 track.
The plugin for winamp is perfect in the current state,just needs version for foobar2000!
The emulator core is identical, with the addition of changes to implement missing functionality which are probably not used by any known rips.
The only exception is that I use my own PSF loader to shove the PSFs into the emulator.
I have not only fixed support for _refresh tags in PSFLIB files, but also implemented _refresh tag support in the UPSE input as well, so now they both support these bloody PAL rips properly.
As for your bass response, I can't hear any difference. Make sure you haven't turned off the "Simulate frequency response" feature. (Of course, I'm comparing with XMPlay, not Winamp, but the component is the same. The only difference is that XMPlay is probably playing the files a lot quieter than Winamp is by default. If I'm going to install Winamp, it will be inside a VM, because I don't want to infect my primary operating system with that mess.)
Was it only a tag issue?
I'm surprised you solved the issue so easily, kode! Thanks for fixing it!
UPSE read the tags from the top level file, and not the psflibs, just like foo_psf did, but it didn't actually do anything with the values. I changed the emulated timer component to support configurable refresh rate and adjusted the PSF1 loader to use it, and also apply the values from PSFLIB tags. (But not actually accumulate those values into the file info read for the player. Otherwise, all the tags would accumulate and get written out to the main minipsf on any tag update operation.)
Thank you so much!I now use only,foo_psf.dll , tempo is OK ,and the frequency responce is just like in the winamp plugin (just like in the game).
So that's what I need.I tried with foo_psf.dll , foo_input_upse.dll(more thin)  individualy and then both together,and the best variant for me is only with foo_psf.dll.Thank You!
Both together is unpredictable, since they don't negotiate over which will get to handle the file. If both components are present, which one handles the file is randomized every program start.
My problems was gone with Version 2.0.20
I see that you have written even a newer version and I just want to report you,that with Version 2.0.22 the problem with the tempo appears again!
I have no problem stain with 2.0.20 ,but you just need to look that next time you debug it.
[PSF] Mark Mothersbaugh, Josh Mancell - [Crash Bandicoot 2: Cortex Strikes Back] Jetski (0:15/3:31)
Sounds fine to me, using foo_psf.dll version 2.0.22. The only changes I made affect loading tags from files for the player, not actual playback.
Try Crash Bandicoot 3
Same, sounds identical to in_psf.dll.
goota be some temp bug,because now it's ok,sorry for that,but that really happen,but now it's OK,i don't know what cause it!
Do you have multiple copies of the component installed, or an old copy of foo_input_upse installed? The component service list order is randomized every startup, so if you have two PSF inputs installed, you may get a different one every time you start the program.
no,i don't.i have removed foo_input_upse.dll since you publish 2.0.20 of foo_psf.dll.And now i have only foo_psf.dll 2.0.22 in the components folder.I can't explain it,but let it go,i tried so many times now and the plugin is working great!
