Topic: foo_flv (Read 46887 times) previous topic - next topic
foo_flv
Allows you to play Flash Video (.FLV) files on foobar2000.
This currently supports PCM, MP3, and AAC audio codecs.
Download Flash Video Decoder 0.9.0: [attachment=6371:foo_flv_090.zip]
foo_flv
Flash Video Decoder 0.9.1: [attachment=6377:foo_flv_091.zip]
  • Improved detection of AAC profiles.
  • Fixed incorrect handling of MP3 frames.
foo_flv
Flash Video Decoder 0.9.2: [attachment=6380:foo_flv_092.zip]
  • Improved streaming support. Some streaming files still don’t work.
foo_flv
Flash Video Decoder 0.9.3: [attachment=6401:foo_flv_093.zip]
  • Added tag writing and ReplayGain support.
    All of the Tag Writer Validator tests passed, but please use at your own risk.
foo_flv
Flash Video Decoder 0.9.4: [attachment=6408:foo_flv_094.zip]
  • Tag editing improvements and speed optimizations.
foo_flv
Flash Video Decoder 0.9.5: [attachment=6517:foo_flv_095.zip]
  • Minor performance improvements.
foo_flv
thank you so much for the plugin,it works on my V1.1.8
foo_flv
Thank you very much
This component work in fb 1.1.10
foo_flv
Thank you
foo_flv
Dang. Didn't know this existed. Well since I have learned to reencapsulate into mp4, I will go on doing that ...
foo_flv
Thank you.
This plugin is very userfull.
but it not work with ".f4v" Extension file.
i wish you can fix it at next update.
foo_flv
I've been looking for this for a long time. Big THX fismineur
I was losing faith that such plugin will be ever made for foobar2k...
Now I can listen all my music in foobar Woot!
foo_flv
not work on foobar2000 v1.2 beta 2
foo_flv
And it seems that it doesn't work correctly with HE-AAC encoded audio tracks.
foo_flv
Another two reasons to extract the streams and reencapsulate them in .mp4 or .m4a.
(Is there any downside to this unless you depend on having the precise original file? Assuming that the streams fit the MP4 container, that is? (Could foo_flv play those which cannot?))
foo_flv
Flash Video Decoder 0.9.6: [attachment=7267:foo_flv_096.zip]
  • Added support for foobar2000 v1.2.
    The previous versions of foo_flv can not decode AAC audio with foobar2000 v1.2.
foo_flv
Thanks for update
foo_flv
I downloaded the file, it tells me that it is damaged, why?
foo_flv
Just redownload it. If problem persist use other browser (IE if you are normally using FF or other way round).
BTW:
Thank you fismineur for this component so much. When combined with Converter component it allows to do everything with audio from YT...
foo_flv
BTW:
Thank you, I already got it.
