Topic: Foo dsp delta (Read 4222 times) previous topic - next topic
Foo dsp delta
i read about this interesting plugin on this page http://www.neowin.net/forum/topic/290673-n...000-plugin/.But i found out that it's not compatible with the new version of foobar.is there a new version or can somebody update this so it works with the new version?
Foo dsp delta
Used noise sharpener as the terms in the search box and found the following. I believe it works just fine in the current foobar.
http://foosion.foobar2000.org/components/
Foo dsp delta
Thank you for the fast reply.it worked
