Topic: Skin request! (Read 2501 times) previous topic - next topic
Skin request!
Oh. well just for us, the ones on dialup, could you please add this skin to HA:
IBP Lite
It's basically the same default without most of the graphics.
"You have the right to remain silent. Anything you say will be misquoted, then used against you."
Skin request!
If you use Opera, you can switch on/off the "Only show images from cache" button. This way, you will only have to load them once.
Some avatars and flags might not appear, but I reckon that's not a serious issue.
And if there's a pic you badly want to see, do right click -> Show image
Works very well for me when I'm at Dial-up.
Skin request!
hmmm.. I use Phoenix. Tried Opera and hated it.
Skin request!
Ok, I added this text skin. I think it still needs some tweaking though. I'll tweak it a bit later.
Also remember that when we update to ipb 1.2 in the future, we may not be able to offer every feature, like this text skin (since the skinning system changes in 1.2) immediately...
I also removed the Skytus skin since only 4 people were using it (it takes increasinly more work if the skin count rises to update every skin set template when some common modification to the templates is needed).
Juha Laaksonheimo
Skin request!
That's just lovely, Thanks JohnV
