foo_keep_queue Reply #75 – 2014-04-14 04:58:24 Quote from: EpicForever on 2014-02-08 07:26:44Does anyone tries to maintain this project using sources shared by Qtax in his first post?Are there some problems with this plugin? If so I could probably look into it.I see some old posts about issues, but without much details, so I couldn't reproduce.In case of any issues steps to reproduce the problem with a clean install of foobar2000 would be helpful.(I haven't had any problems, altho I'm on default UI with not too many plugins.)
foo_keep_queue Reply #76 – 2014-04-14 15:42:54 In my case the problem looks like this:I populate queue. Queue works as intended - when i play manually something else from regular playlist, then queue is not flushed. But when I search for something via Album List and play anything from search results - then queue is flushed. I use foobar v 1.2.9 with Default User Interface.
foo_keep_queue Reply #77 – 2014-04-15 07:35:51 Quote from: EpicForever on 2014-04-14 15:42:54In my case the problem looks like this:I populate queue. Queue works as intended - when i play manually something else from regular playlist, then queue is not flushed. But when I search for something via Album List and play anything from search results - then queue is flushed. I use foobar v 1.2.9 with Default User Interface.Could reproduce with 1.3.1, thanks. I'll see what can be done about this when I have some more time.
