Topic: foo_dsp_effect (Read 147263 times) previous topic - next topic
Re: foo_dsp_effect
Reply #402
Like the previous post, I would like to thank you for all your work
Personally I dream that you can see an interest to integrate foo_dsp_centercut and make it a bit more adjustable
Re: foo_dsp_effect
Reply #403
Whats that filter? What needs to be more adjustable in it? Is it a simple stereo seperation effect ala Amiga?
Re: foo_dsp_effect
Reply #404
I mean a wet/dry mixer instead of today on/off mode
Re: foo_dsp_effect
Reply #405
Will have to see what it actually does.
Uploaded beta 1 of 0.40. Hopefully works okay and fixes the current issues in the UI elements.
Re: foo_dsp_effect
Reply #406
I see on beta, by just changing IIR Filter Type will enable it even without check the Enabled
Re: foo_dsp_effect
Reply #408
It's fixed. :)
Re: foo_dsp_effect
Reply #409
Any other bugs I should know about?
Re: foo_dsp_effect
Reply #410
It's not bug but just cosmetic. Chorus and Echo have same description on status bar.
Re: foo_dsp_effect
Reply #411
I'll fix that when beta 3 comes.
Re: foo_dsp_effect
Reply #412
Beta 3 up, hopefully the remaining bugs with the other effects are fixed before merging in the new unreleased effects.
Re: foo_dsp_effect
Reply #413
Thanks mudlord, incredible plugin, can't wait to try the unreleased effects!
Re: foo_dsp_effect
Reply #414
My priority atm is ironing out the last bugs that are in there before adding in the other stuff that I worked on in a unreleased component. It would be nice to know if there is still any left. The obvious ones I see should be gone now at least.
