Topic: foo_dsp_effect (Read 157404 times) previous topic - next topic
Re: foo_dsp_effect
Reply #425
beta 5 out,
Hopefully the final stuff done to this component now is just bugfixes/maintenance (hoping to finish at 0.40 final). I really want this component finished and feature-complete in my eyes, since I desperately want to work on other projects that need my time.
Re: foo_dsp_effect
Reply #426
Hello Mudlord, I would understand if this component would be used to make a DSP-based X-Over and Phase adjust.
Can I used it to take a stereo input (2 ASIO in) and to make a 3-way x-over (6 ASIO out) and then for each of the output set a delay?
PS: I am now using Thuneau Allocator (VST plug-in), however, it is not anymore maintained and I would look for another solution.
Regards, Andrea
Re: foo_dsp_effect
Reply #427
That's completely out of the scope of this component.
This component is just for special effects. Nothing else.
Besides, its now in feature-freeze because it fulfills all my needs.
Re: foo_dsp_effect
Reply #428
Hi Mudlord, thanks for your reply.
Do you know any "good" component (or solution) for my need?
Regards, Andrea
Re: foo_dsp_effect
Reply #429
You might be able to achieve the channel doubling with Matrix Mixer and then user further effects with some other plugin.
Re: foo_dsp_effect
Reply #430
Hi Sandrine, thanks for you kind reply. However, this component (Matrix Mixer) looks not maintained (last release in 2008).
Regards, Andrea
Re: foo_dsp_effect
Reply #431
You may have looked, but what did you hear?
Re: foo_dsp_effect
Reply #432
Regards, Andrea
I've been using the Matrix Mixer for years. There's really nothing to maintain as such, because it does what it's designed to do.
Re: foo_dsp_effect
Reply #433
Hello Mudlord. Thank you for your work. I use the IIR Filters parametric EQ. Unfortunately the GUI makes it impossible to adjust some frequencies e.g. 35Hz with the slider.  Is there any chance to get this fixed? I use Windows 7. The lowest value I can adjust is 212Hz :/
Furthermore I would like to know, if this single band filter is the same like a peaking filter? For example in Equlizer APO. I really would like to use Foobar instead of Equliizer APO.
Thank you.
Re: foo_dsp_effect
Reply #434
Saw your email. Noted, will get around to it when I can or when I feel like. Either way its not a unreasonable request at all.
Its indeed a peaking EQ. Single band.
I seen some public domain code around for a better EQ than the current foobar2000 1st party component. Might go about implementing that in the effect DSP. Ideally I wanted 0.40 to be the last release of the effect DSP as I think its quite feature complete.
