Topic: AudioCoding MP4 winamp plugin (Read 5231 times) previous topic - next topic
Just wanted to tell you that it crashes with an access violation when trying to run it on a multiprocessor. I had to "imagecfg -u winamp.exe", so that it runs on one CPU only to get it working (setting affinity in the taskmgr everytime sucks  ). You should check that sometime.
Cheers
(Hope this was the right forum)
--edit--
Forgot to mention... the normal FAAD winamp plugin works fine in on multiprocessor.
Could you ty again with the latest code in CVS?
I think it should work fine now.
Menno
oke, gonna install CVS then and try it out.
what compiler do i need? i'm running VS.NET since a week, so i dont know if it will work 100% in there.
Never tried that
MSVC and Intel CPP compiler work ine
Menno
Where is the CVS? Either i'm blind or there is no info on your homepage. :confused:
