Topic: Winamp won't play WavPack files (Read 17519 times) previous topic - next topic
just to mention, i just installed XP and had the same problem.
solved installing the older plugin version.
You can also just use the plugin in the Essentials Pack, assuming you're using a recent Winamp.
The one in the EP is the newest version of the plugin and has the manifest removed that was causing the problems with fresh XP installs (I just haven't updated the one on the WavPack website yet).
