Topic: foobar i/o error (Read 5891 times) previous topic - next topic
foobar i/o error
foobar (v1.0.3 and v1.1) has suddenly started giving me I/O errors on CD playback.
On attempting to load cd data:
Could not load info (I/O error (win32 #1117)) from:
"cdda://00E77E79" / index: 10
"cdda://00E77E79" / index: 8
On attempting playback:
Unable to open item for playback (Disc not available):
"cdda://01E53611" / index: 6
"cdda://01E53611" / index: 7
This initially happened on v1.0.3 so I upgraded but still recieved the same problem. Not sure where the problem lies as I've tried a few cds and it happened with each one. The cds pass read test with nero CD-DVD Speed, CD's also will play in Windows Media Player 11 and will rip with Easy CD-DA. I've made sure nothing is running that could be accessing the drive when foobar is active. I'm out of ideas to try and fix this issue.
foobar i/o error
Anyone with any ideas?
foobar i/o error
An Internet search for "I/O error win32 #1117" gives some hits with possible solutions.
Your post should fulfil the Support Forums Rules in order to get help. Without some more concrete information by you a more precise answer isn't possible.
foobar i/o error
I had already done a search and found nothing very helpful, hence the post here.
Ok I did miss stuff out and whoops ok... more details that I didn't add.
Operating System: Windowx XP Pro SP3
foobar details:
Core (2010-08-21 11:42:56 UTC)
    foobar2000 core 1.1
foo_albumlist.dll (2010-08-21 11:41:12 UTC)
    Album List 4.5
foo_audioscrobbler.dll (2008-05-13 14:36:16 UTC)
    Audioscrobbler 2.3.1
foo_cdda.dll (2010-08-21 11:41:04 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2010-08-21 11:40:42 UTC)
    Converter 1.5
foo_dsp_std.dll (2010-08-21 11:41:12 UTC)
    Standard DSP Array 1.0
foo_fileops.dll (2010-08-21 11:39:48 UTC)
    File Operations 2.1.3
foo_freedb2.dll (2010-08-21 11:40:00 UTC)
    freedb Tagger 0.6.2
foo_input_std.dll (2010-08-21 11:40:42 UTC)
    Standard Input Array 1.0
foo_rgscan.dll (2010-08-21 11:40:44 UTC)
    ReplayGain Scanner 2.0.9
foo_ui_std.dll (2010-08-21 11:41:10 UTC)
    Default User Interface 0.9.5
foo_unpack.dll (2010-08-21 11:40:10 UTC)
    ZIP/GZIP/RAR Reader 1.6
I will again point out that the cds play on various other media players, will rip using other soft, will pass read tests nero
