Topic: EAC problems writing (Read 1957 times) previous topic - next topic
I've read through forum info on writing with EAC, but can't find anything that addresses this problem.
For some reason, EAC doesn't actually burn when I set up some .wav files, and "Make it so".  The 'Track', 'CD' and 'Buffer' status bars move along, but the LED on the CD-R drive doesn't indicate that it's being written to.  Once all 3 indicater bars reach 100%, the indicated write time just keeps getting longer and longer, and the process never stops.
The same thing happens when I go into the settings, and run the 'Detect Write Features' option.  The 'CD Write Simulation' reaches 100%, and 'Done' appears next to the status bar, but the window never reports the process being complete.  The simulation window's 'Cancel' button remains as long as I let it run.
Anyone have any idea what's going on here?
Thanks,
Shel
Geopoliticus Child Watching the Birth of the New Man
Try using nero's aspi.
"You have the right to remain silent. Anything you say will be misquoted, then used against you."
