Topic: Different cuetools ‘verify’ results when comparing an EAC rip vs DBPow (Read 5294 times) previous topic - next topic
oh noes, title got cut off: Different cuetools ‘verify’ results when comparing an EAC rip vs DBPoweramp Rip from the same CD
Upon ripping a CD (purchased shortly after the album came out back in 2002) using EAC, and then ripping that same CD using DBPoweramp, I am getting different results when using cuetool’s verify option. I encounter no problems upon ripping the CD in either EAC or DBPoweramp; both programs report the rip as being accurate, and each track has the same confidence level on both rips. Log files indicate no problems for either program. Both programs are configured to the same offset correction, and both report the same CRC and AccurateRip CRC on each track. Everything seems as expected at this point. I’ve ripped the same CD on what I believe are identical settings on each program, so I should have two identical rips… which is why I don’t understand why cuetools is telling me DBPoweramp is giving me a bad rip. When I ‘verify’ both rips in cuetools, it reports the EAC rip as ‘rip accurate (8/59), CTDB: differs in 4855 samples, confidence 3’, but it reports the DBPA rip as ‘AR: offset -2, rip not accurate (0/4), CTDB: differs in 4855 samples, confidence 3’. Log files are attached.
EAC RIP LOG
Exact Audio Copy V0.99 prebeta 5 from 4. May 2009
EAC extraction logfile from 8. September 2010, 22:53
Papa Roach / lovehatetragedy
Used drive  : HL-DT-STDVDRAM GSA-H10A  Adapter: 5  ID: 0
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : No
Make use of C2 pointers : Yes
Read offset correction                      : 667
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Not detected, thus appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 768 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Program Files\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -6 -V -T "ARTIST=%a" -T "TITLE=%t" -T "ALBUM=%g" -T "DATE=%y" -T "TRACKNUMBER=%n" -T "GENRE=%m" -T "COMMENT=%e" %s -o %d
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  2:26.67 |        0    |    11016
        2  |  2:26.67 |  4:05.02 |    11017    |    29393
        3  |  6:31.69 |  2:58.38 |    29394    |    42781
        4  |  9:30.32 |  3:04.68 |    42782    |    56649
        5  | 12:35.25 |  3:59.27 |    56650    |    74601
        6  | 16:34.52 |  3:49.40 |    74602    |    91816
        7  | 20:24.17 |  3:29.43 |    91817    |  107534
        8  | 23:53.60 |  3:48.62 |    107535    |  124696
        9  | 27:42.47 |  4:01.53 |    124697    |  142824
      10  | 31:44.25 |  4:04.37 |    142825    |  161161
      11  | 35:48.62 |  3:13.15 |    161162    |  175651
      12  | 39:02.02 |  2:07.68 |    175652    |  185244
      13  | 41:09.70 |  3:05.72 |    185245    |  199191
      14  | 46:47.67 | 13:10.50 |    210592    |  269891
Track  1
    Filename C:\Documents and Settings\admin\My Documents\01 M-80 (Explosive Energy Movement).wav
    Peak level 99.8 %
    Track quality 100.0 %
    Test CRC 5030C456
    Copy CRC 5030C456
    Accurately ripped (confidence 9)  [E25FB883]
    Copy OK
Track  2
    Filename C:\Documents and Settings\admin\My Documents\02 Life Is a Bullet.wav
    Peak level 98.8 %
    Test CRC D3C6A1F9
    Copy CRC D3C6A1F9
    Accurately ripped (confidence 9)  [89B15BE8]
    Copy OK
Track  3
    Filename C:\Documents and Settings\admin\My Documents\03 Time and Time Again.wav
    Peak level 98.8 %
    Track quality 99.8 %
    Test CRC 6B5E524F
    Copy CRC 6B5E524F
    Accurately ripped (confidence 9)  [0C8E6274]
    Copy OK
Track  4
    Filename C:\Documents and Settings\admin\My Documents\04 Walking Thru Barbed Wire.wav
    Peak level 98.8 %
    Test CRC 9F2CEA4C
    Copy CRC 9F2CEA4C
    Accurately ripped (confidence 9)  [D6222780]
    Copy OK
Track  5
    Filename C:\Documents and Settings\admin\My Documents\05 Decompression Period.wav
    Peak level 98.9 %
    Track quality 99.9 %
    Test CRC 14AADBD1
    Copy CRC 14AADBD1
    Accurately ripped (confidence 9)  [A823E409]
    Copy OK
Track  6
    Filename C:\Documents and Settings\admin\My Documents\06 Born With Nothing, Die With Everything.wav
    Peak level 98.8 %
    Test CRC F89E64A3
    Copy CRC F89E64A3
    Accurately ripped (confidence 9)  [77FE3835]
    Copy OK
Track  7
    Filename C:\Documents and Settings\admin\My Documents\07 She Loves Me Not.wav
    Peak level 98.8 %
    Test CRC EA5FA259
    Copy CRC EA5FA259
    Accurately ripped (confidence 10)  [1CA977FE]
    Copy OK
Track  8
    Filename C:\Documents and Settings\admin\My Documents\08 Singular Indestructible Droid.wav
    Peak level 98.8 %
    Test CRC C8B715CA
    Copy CRC C8B715CA
    Accurately ripped (confidence 9)  [C8A0C533]
    Copy OK
Track  9
    Filename C:\Documents and Settings\admin\My Documents\09 Black Clouds.wav
    Peak level 99.9 %
    Test CRC 9AFE8D56
    Copy CRC 9AFE8D56
    Accurately ripped (confidence 9)  [C74B8FEE]
    Copy OK
Track 10
    Filename C:\Documents and Settings\admin\My Documents\10 Code of Energy.wav
    Peak level 99.8 %
    Test CRC BDFFCF85
    Copy CRC BDFFCF85
    Accurately ripped (confidence 9)  [5BE31C52]
    Copy OK
Track 11
    Filename C:\Documents and Settings\admin\My Documents\11 lovehatetragedy.wav
    Peak level 98.8 %
    Test CRC 32865E7E
    Copy CRC 32865E7E
    Accurately ripped (confidence 9)  [AC1B5E70]
    Copy OK
Track 12
    Filename C:\Documents and Settings\admin\My Documents\12 Gouge Away.wav
    Peak level 98.8 %
    Test CRC 617DCDC4
    Copy CRC 617DCDC4
    Accurately ripped (confidence 9)  [A496E778]
    Copy OK
Track 13
    Filename C:\Documents and Settings\admin\My Documents\13 Never Said It.wav
    Peak level 98.8 %
    Test CRC 3FA84837
    Copy CRC 3FA84837
    Accurately ripped (confidence 8)  [905ACFC7]
    Copy OK
All tracks accurately ripped
No errors occurred
End of status report
DBPA RIP LOG
dBpoweramp Release 13.5 Digital Audio Extraction Log from September 8, 2010 7:07 PM
Drive & Settings
Ripping with drive 'D:  [HL-DT-ST - DVDRAM GSA-H10A ]',  Drive offset: 667,  Overread Lead-in/out: No
AccurateRip: Active,  Using C2: No,  Cache: 1024 KB,  FUA Cache Invalidate: No
Pass 1 Drive Speed: Max,  Pass 2 Drive Speed: Max
Bad Sector Re-rip::  Drive Speed: Max,  Maximum Re-reads: 34
Encoder: FLAC -compression-level-5 -verify
Extraction Log
Track 1:  Ripped LBA 0 to 11017 (2:26) in 0:08. Filename: C:\Documents and Settings\admin\My Documents\My Music\Papa Roach\Lovehatetragedy\Papa Roach - 01 - M-80 (Explosive Energy Movement).flac
  AccurateRip: Accurate (confidence 9)    [Pass 1]
  CRC32: 5030C456    AccurateRip CRC: E25FB883    [DiscID: 013-00167af6-00e6e950-c60e0e0e-1]
Track 2:  Ripped LBA 11017 to 29394 (4:05) in 0:12. Filename: C:\Documents and Settings\admin\My Documents\My Music\Papa Roach\Lovehatetragedy\Papa Roach - 02 - Life Is A Bullet.flac
  CRC32: D3C6A1F9    AccurateRip CRC: 89B15BE8    [DiscID: 013-00167af6-00e6e950-c60e0e0e-2]
Track 3:  Ripped LBA 29394 to 42782 (2:58) in 0:08. Filename: C:\Documents and Settings\admin\My Documents\My Music\Papa Roach\Lovehatetragedy\Papa Roach - 03 - Time And Time Again.flac
  CRC32: 6B5E524F    AccurateRip CRC: 0C8E6274    [DiscID: 013-00167af6-00e6e950-c60e0e0e-3]
Track 4:  Ripped LBA 42782 to 56650 (3:04) in 0:08. Filename: C:\Documents and Settings\admin\My Documents\My Music\Papa Roach\Lovehatetragedy\Papa Roach - 04 - Walking Thru Barbed Wire.flac
  CRC32: 9F2CEA4C    AccurateRip CRC: D6222780    [DiscID: 013-00167af6-00e6e950-c60e0e0e-4]
Track 5:  Ripped LBA 56650 to 74602 (3:59) in 0:09. Filename: C:\Documents and Settings\admin\My Documents\My Music\Papa Roach\Lovehatetragedy\Papa Roach - 05 - Decompression Period.flac
  CRC32: 14AADBD1    AccurateRip CRC: A823E409    [DiscID: 013-00167af6-00e6e950-c60e0e0e-5]
Track 6:  Ripped LBA 74602 to 91817 (3:49) in 0:08. Filename: C:\Documents and Settings\admin\My Documents\My Music\Papa Roach\Lovehatetragedy\Papa Roach - 06 - Born With Nothing, Die With Everything.flac
  CRC32: F89E64A3    AccurateRip CRC: 77FE3835    [DiscID: 013-00167af6-00e6e950-c60e0e0e-6]
Track 7:  Ripped LBA 91817 to 107535 (3:29) in 0:07. Filename: C:\Documents and Settings\admin\My Documents\My Music\Papa Roach\Lovehatetragedy\Papa Roach - 07 - She Loves Me Not.flac
  AccurateRip: Accurate (confidence 10)    [Pass 1]
  CRC32: EA5FA259    AccurateRip CRC: 1CA977FE    [DiscID: 013-00167af6-00e6e950-c60e0e0e-7]
Track 8:  Ripped LBA 107535 to 124697 (3:48) in 0:07. Filename: C:\Documents and Settings\admin\My Documents\My Music\Papa Roach\Lovehatetragedy\Papa Roach - 08 - Singular Indestructible Droid.flac
  CRC32: C8B715CA    AccurateRip CRC: C8A0C533    [DiscID: 013-00167af6-00e6e950-c60e0e0e-8]
Track 9:  Ripped LBA 124697 to 142825 (4:01) in 0:08. Filename: C:\Documents and Settings\admin\My Documents\My Music\Papa Roach\Lovehatetragedy\Papa Roach - 09 - Black Clouds.flac
  CRC32: 9AFE8D56    AccurateRip CRC: C74B8FEE    [DiscID: 013-00167af6-00e6e950-c60e0e0e-9]
Track 10:  Ripped LBA 142825 to 161162 (4:04) in 0:07. Filename: C:\Documents and Settings\admin\My Documents\My Music\Papa Roach\Lovehatetragedy\Papa Roach - 10 - Code Of Energy.flac
  CRC32: BDFFCF85    AccurateRip CRC: 5BE31C52    [DiscID: 013-00167af6-00e6e950-c60e0e0e-10]
Track 11:  Ripped LBA 161162 to 175652 (3:13) in 0:06. Filename: C:\Documents and Settings\admin\My Documents\My Music\Papa Roach\Lovehatetragedy\Papa Roach - 11 - Lovehatetragedy.flac
  CRC32: 32865E7E    AccurateRip CRC: AC1B5E70    [DiscID: 013-00167af6-00e6e950-c60e0e0e-11]
Track 12:  Ripped LBA 175652 to 185245 (2:07) in 0:03. Filename: C:\Documents and Settings\admin\My Documents\My Music\Papa Roach\Lovehatetragedy\Papa Roach - 12 - Gouge Away.flac
  CRC32: 617DCDC4    AccurateRip CRC: A496E778    [DiscID: 013-00167af6-00e6e950-c60e0e0e-12]
Track 13:  Ripped LBA 185245 to 199192 (3:05) in 0:05. Filename: C:\Documents and Settings\admin\My Documents\My Music\Papa Roach\Lovehatetragedy\Papa Roach - 13 - Never Said It.flac
  AccurateRip: Accurate (confidence 8)    [Pass 1]
  CRC32: 3FA84837    AccurateRip CRC: 905ACFC7    [DiscID: 013-00167af6-00e6e950-c60e0e0e-13]
13 Tracks Ripped Accurately
EAC CUETOOLS VERIFY LOG
[CUETools log; Date: 08/09/2010 11:06:04 PM; Version: 2.0.9]
CD-Extra data track length 13:10:50.
[CTDB TOCID: HByl8ZFwV75wGyjg9JAsMuIdnv8-] found.
        [ CTDBID ] Status
        [ecb380fc] (3/3) Has no data track, Differs in 4855 samples @00:00:26,41:00:65,44:15:32-44:15:47,44:15:53
[AccurateRip ID: 00167af6-00e6e950-c60e0e0e] found.
Track  [ CRC    ] Status
 01    [e25fb883] (09/60) Accurately ripped
 02    [89b15be8] (09/61) Accurately ripped
 03    [0c8e6274] (09/61) Accurately ripped
 04    [d6222780] (09/61) Accurately ripped
 05    [a823e409] (09/61) Accurately ripped
 06    [77fe3835] (09/61) Accurately ripped
 07    [1ca977fe] (10/62) Accurately ripped
 08    [c8a0c533] (09/61) Accurately ripped
 09    [c74b8fee] (09/60) Accurately ripped
 10    [5be31c52] (09/60) Accurately ripped
 11    [ac1b5e70] (09/60) Accurately ripped
 12    [a496e778] (09/60) Accurately ripped
 13    [905acfc7] (08/59) Accurately ripped
Offsetted by -2:
 01    [4348db28] (51/60) No match but offset
 02    [639bc9af] (52/61) Accurately ripped
 03    [8928dbc8] (52/61) Accurately ripped
 04    [02cbe4a1] (52/61) Accurately ripped
 05    [d52a37c2] (52/61) Accurately ripped
 06    [9718d0ed] (52/61) Accurately ripped
 07    [3a775d16] (52/62) Accurately ripped
 08    [82a302cb] (52/61) Accurately ripped
 09    [2137dc4a] (51/60) Accurately ripped
 10    [3217b24a] (51/60) Accurately ripped
 11    [852bb35e] (51/60) Accurately ripped
 12    [130a459c] (51/60) No match but offset
 13    [f188d529] (51/59) No match but offset
Track Peak [ CRC32  ] [W/O NULL] [  LOG  ]
 --  99.9 [D488C6EC] [1F09A3BE]
 01  99.8 [5030C456] [0F1DF2C1]  CRC32
 02  98.8 [D3C6A1F9] [C18DE6F4]  CRC32
 03  98.8 [6B5E524F] [D9CB57E9]  CRC32
 04  98.8 [9F2CEA4C] [F3EF12F5]  CRC32
 05  98.9 [14AADBD1] [70E6061B]  CRC32
 06  98.8 [F89E64A3] [9F983D65]  CRC32
 07  98.8 [EA5FA259] [2B2D3C73]  CRC32
 08  98.8 [C8B715CA] [41D2384B]  CRC32
 09  99.9 [9AFE8D56] [207CA26A]  CRC32
 10  99.8 [BDFFCF85] [927E764E]  CRC32
 11  98.8 [32865E7E] [68169EEA]  CRC32
 12  98.8 [617DCDC4] [BBD63538]  CRC32
 13  98.8 [3FA84837] [C140B288]  CRC32
DBPA CUETOOLS VERIFY LOG
[CUETools log; Date: 08/09/2010 7:11:15 PM; Version: 2.0.9]
        [ CTDBID ] Status
        [ecb380fc] (3/3) Differs in 4855 samples @00:00:26,41:00:65,44:15:32-44:15:47,44:15:53
[AccurateRip ID: 001566ca-00d7cee8-b30a5f0d] found.
 01    [e25fb883] (0/4) No match
 02    [89b15be8] (0/6) No match
 03    [0c8e6274] (0/6) No match
 04    [d6222780] (0/6) No match
 05    [a823e409] (0/6) No match
 06    [77fe3835] (0/6) No match
 07    [1ca977fe] (0/6) No match
 08    [c8a0c533] (0/6) No match
 09    [c74b8fee] (0/6) No match
 10    [5be31c52] (0/6) No match
 11    [ac1b5e70] (0/6) No match
 12    [a496e778] (0/6) No match
 13    [905acfc7] (0/6) No match
Offsetted by -678:
 01    [0b6159a3] (4/4) No match but offset
 02    [28d94d36] (4/6) Accurately ripped
 03    [74b07f10] (4/6) Accurately ripped
 04    [67e365c3] (4/6) Accurately ripped
 05    [b722f850] (4/6) Accurately ripped
 06    [70ea4cc5] (4/6) Accurately ripped
 07    [1a6d5f3e] (4/6) Accurately ripped
 08    [573eb295] (4/6) Accurately ripped
 09    [db34adc2] (4/6) Accurately ripped
 10    [0385b3ba] (4/6) Accurately ripped
 11    [1cbbd59a] (4/6) Accurately ripped
 12    [e75c9124] (4/6) No match but offset
 13    [404bf08d] (4/6) No match but offset
Offsetted by -2:
 01    [4348db28] (0/4) No match
 02    [639bc9af] (2/6) Accurately ripped
 03    [8928dbc8] (2/6) Accurately ripped
 04    [02cbe4a1] (2/6) Accurately ripped
 05    [d52a37c2] (2/6) Accurately ripped
 06    [9718d0ed] (2/6) Accurately ripped
 07    [3a775d16] (2/6) Accurately ripped
 08    [82a302cb] (2/6) Accurately ripped
 09    [2137dc4a] (2/6) Accurately ripped
 10    [3217b24a] (2/6) Accurately ripped
 11    [852bb35e] (2/6) Accurately ripped
 12    [130a459c] (2/6) No match but offset
 13    [f188d529] (2/6) No match but offset
That is "interesting." Not in a good way, of course.
I've done similar tests with all of the programs you're describing (assuming they are all the same versions as mine.) EAC and dBpoweramp (the newest w/ cue sheet/image codec installed) have always given me the same results. Thought it likely won't matter, you're using CUETools 2.0.9 yes? (EDIT: If I had payed closer attention, I would have seen that you were using the same CUETools but not the latest beta R14 dBpoweramp. I didn't start ripping images with dBp until the beta was introduced.)
I don't think dBpa supported cue sheet generation prior to the beta and the codec. How are you creating your cue sheets for individual tracks? You need the same gap information as the EAC-generated cue for the CD to match the database rips. I believe this would be true even though your CRCs between EAC and dBpa match.
Perhaps I'm mistaken and someone here can hopefully get to the bottom of this for you.
The Loudness War is over. Now it's a hopeless occupation.
EAC log provides information about the data track which is necessary to generate the proper disc ID and this is what CUETools is using.  When you're feeding the files ripped by dBpoweramp, CUETools is apparently unaware that there is a data track.  I thought that the AR disc ID was added as metadata when ripping with dBpa, if it is then for some reason CUETools is not making use of it.
CUE sheets and gaps have absolutely nothing to do with what is going on in this instance.
I just learned something too. Thx.
I forgot about the metadata. Maybe Fenor should check the tags on his dBpa rip and see if they are there? I noticed the Accuraterip tags every time I went to edit the genre or comment.
Hopefully Spoon will see this and weigh in. I'm going to try verifying an individual-track rip with dBpa and EAC with CUETools later today and hopefully see if there's anything I can add to truly help him out. That'd be better than just giving him some lousy info like I did before.
I guess I have nothing.  I just ripped a :wumpscut: Cannibal Anthem CD with EAC...had it archived/ripped with dBpoweramp R14 beta. Everything's the same.
I won't post any of the logs unless you want me to. I'm not certain any of the info would be relevant or helpful to your particular situation. CRCs match and I didn't even have a single re-read in the EAC rip. Accuraterip gives the same info in the CUETools log.
IDK. I guess if you want to continue using dBpoweramp, maybe a reinstallation or update to the latest would fix the problem without identifying it. Did you follow Spoon's guide when you set up dBpa? I take your word that the settings are the same/similar.
Never done the codebox thing before so I may be editing...
Here's the EAC log for the CD:
EAC extraction logfile from 9. September 2010, 11:05
Wumpscut / Cannibal Anthem
Used drive  : TSSTcorpDVD+-RW TS-T633C  Adapter: 0  ID: 1
Read mode              : Secure
Defeat audio cache      : Yes
Make use of C2 pointers : No
Gap handling                                : Appended to previous track
Used output format : Internal WAV Routines
Sample format      : 44.100 Hz; 16 Bit; Stereo
        1  |  0:00.00 |  1:10.44 |        0    |    5293
        2  |  1:10.44 |  4:20.57 |      5294    |    24850
        3  |  5:31.26 |  4:55.20 |    24851    |    46995
        4  | 10:26.46 |  4:23.27 |    46996    |    66747
        5  | 14:49.73 |  3:59.44 |    66748    |    84716
        6  | 18:49.42 |  3:40.05 |    84717    |  101221
        7  | 22:29.47 |  5:11.39 |    101222    |  124585
        8  | 27:41.11 |  3:20.37 |    124586    |  139622
        9  | 31:01.48 |  4:21.66 |    139623    |  159263
      10  | 35:23.39 |  4:12.62 |    159264    |  178225
      11  | 39:36.26 |  6:11.34 |    178226    |  206084
Track  1
    Filename C:\EAC.rips\01 - Herzlich Willkommen .wav
    Pre-gap length  0:00:02.00
    Peak level 100.0 %
    Test CRC 55F6F90D
    Copy CRC 55F6F90D
    Accurately ripped (confidence 15)  [964C16BC]
    Copy OK
Track  2
    Filename C:\EAC.rips\02 - Wir Warten .wav
    Peak level 100.0 %
    Test CRC 22184737
    Copy CRC 22184737
    Accurately ripped (confidence 15)  [A51F9988]
    Copy OK
Track  3
    Filename C:\EAC.rips\03 - Die Liebe .wav
    Peak level 100.0 %
    Test CRC C4ECCBAA
    Copy CRC C4ECCBAA
    Accurately ripped (confidence 15)  [DA8C90A2]
    Copy OK
Track  4
    Filename C:\EAC.rips\04 - Jesus Antichristus .wav
    Peak level 100.0 %
    Test CRC 0E16CB58
    Copy CRC 0E16CB58
    Accurately ripped (confidence 15)  [69DDD142]
    Copy OK
Track  5
    Filename C:\EAC.rips\05 - Cannibal Anthem .wav
    Peak level 100.0 %
    Test CRC 980E849C
    Copy CRC 980E849C
    Accurately ripped (confidence 15)  [D7A91E53]
    Copy OK
Track  6
    Filename C:\EAC.rips\06 - Auf Der Jagd .wav
    Peak level 100.0 %
    Test CRC 77230886
    Copy CRC 77230886
    Accurately ripped (confidence 15)  [058820B3]
    Copy OK
Track  7
    Filename C:\EAC.rips\07 - Pass Auf .wav
    Peak level 100.0 %
    Test CRC C715F7DD
    Copy CRC C715F7DD
    Accurately ripped (confidence 15)  [44229CDC]
    Copy OK
Track  8
    Filename C:\EAC.rips\08 - Jetzt .wav
    Peak level 100.0 %
    Test CRC B2A94A78
    Copy CRC B2A94A78
    Accurately ripped (confidence 15)  [FC954D46]
    Copy OK
Track  9
    Filename C:\EAC.rips\09 - Ohne Dich .wav
    Peak level 100.0 %
    Test CRC 5CF8EEBC
    Copy CRC 5CF8EEBC
    Accurately ripped (confidence 15)  [D50B27FB]
    Copy OK
Track 10
    Filename C:\EAC.rips\10 - Hunger .wav
    Peak level 100.0 %
    Test CRC 946622A8
    Copy CRC 946622A8
    Accurately ripped (confidence 15)  [1DACCDEF]
    Copy OK
Track 11
    Filename C:\EAC.rips\11 - Recht Vor Gnade .wav
    Peak level 100.0 %
    Test CRC 8853BD73
    Copy CRC 8853BD73
    Accurately ripped (confidence 14)  [6558FC4B]
    Copy OK
No errors occurred
Here's the report generated by CUETools:
[CUETools log; Date: 9/9/2010 11:11:47 AM; Version: 2.0.9]
[CTDB TOCID: C0nKPlIyiOePJsZZQtP.wkvW.io-] found.
        [ CTDBID ] Status
        [1a624dfc] (22/22) Accurately ripped
[AccurateRip ID: 00115bcc-009a297b-860abb0b] found.
 01    [964c16bc] (15/24) Accurately ripped
 02    [a51f9988] (15/24) Accurately ripped
 03    [da8c90a2] (15/24) Accurately ripped
 04    [69ddd142] (15/24) Accurately ripped
 05    [d7a91e53] (15/25) Accurately ripped
 06    [058820b3] (15/24) Accurately ripped
 07    [44229cdc] (15/24) Accurately ripped
 08    [fc954d46] (15/24) Accurately ripped
 09    [d50b27fb] (15/25) Accurately ripped
 10    [1daccdef] (15/24) Accurately ripped
 11    [6558fc4b] (14/23) Accurately ripped
Offsetted by -1248:
 01    [bcadb3e7] (02/24) Accurately ripped
 02    [93c9fd4d] (02/24) Accurately ripped
 03    [bc2a0351] (02/24) Accurately ripped
 04    [d39ea74f] (02/24) Accurately ripped
 05    [4c32f257] (02/25) Accurately ripped
 06    [996e7727] (02/24) Accurately ripped
 07    [2043c8c6] (02/24) Accurately ripped
 08    [60068b05] (02/24) Accurately ripped
 09    [b6363e61] (02/25) Accurately ripped
 10    [6de385c8] (02/24) Accurately ripped
 11    [58ff2320] (02/23) Accurately ripped
Offsetted by -584:
 01    [5a712462] (07/24) Accurately ripped
 02    [170772da] (07/24) Accurately ripped
 03    [72a91543] (07/24) Accurately ripped
 04    [987b6b2a] (07/24) Accurately ripped
 05    [a1edca36] (08/25) Accurately ripped
 06    [5fd72b04] (07/24) Accurately ripped
 07    [a50e11ab] (07/24) Accurately ripped
 08    [c79c2cd7] (07/24) Accurately ripped
 09    [9b5c4913] (08/25) Accurately ripped
 10    [e8181bc0] (07/24) Accurately ripped
 11    [68a704f9] (07/23) Accurately ripped
 --  100.0 [90C92E25] [34589A22]
 01  100.0 [55F6F90D] [9084BB30]  CRC32
 02  100.0 [22184737] [0C94EC0D]  CRC32
 03  100.0 [C4ECCBAA] [83E80C78]  CRC32
 04  100.0 [0E16CB58] [0EEE6E75]  CRC32
 05  100.0 [980E849C] [E57B6D92]  CRC32
 06  100.0 [77230886] [E6463B65]  CRC32
 07  100.0 [C715F7DD] [87142A5A]  CRC32
 08  100.0 [B2A94A78] [54EA1ADA]  CRC32
 09  100.0 [5CF8EEBC] [1B736730]  CRC32
 10  100.0 [946622A8] [CDF46F2F]  CRC32
 11  100.0 [8853BD73] [5469A2F0]  CRC32
This is the CUETools log from the dBpoweramp image/cue rip from earlier (below it is the report copy&pasted to txt file from that rip:)
[CUETools log; Date: 9/9/2010 10:53:41 AM; Version: 2.0.9]
        [ CTDBID ] Status
Offsetted by -1248:
Offsetted by -584:
Information ripping to [CUE Sheet Image], 'Track 1' to 'C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 01 - Herzlich Willkommen.IGNORE'
  Track 1:  Ripped LBA 0 to 5294 (1:10) in 0:07. Filename: C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 01 - Herzlich Willkommen.IGNORE
    AccurateRip: Accurate (confidence 15)    [Pass 1]
    CRC32: 55F6F90D    AccurateRip CRC: 964C16BC    [DiscID: 011-00115bcc-009a297b-860abb0b-1]
Information ripping to [CUE Sheet Image], 'Track 2' to 'C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 02 - Wir Warten.IGNORE'
  Track 2:  Ripped LBA 5294 to 24851 (4:20) in 0:24. Filename: C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 02 - Wir Warten.IGNORE
    CRC32: 22184737    AccurateRip CRC: A51F9988    [DiscID: 011-00115bcc-009a297b-860abb0b-2]
Information ripping to [CUE Sheet Image], 'Track 3' to 'C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 03 - Die Liebe.IGNORE'
  Track 3:  Ripped LBA 24851 to 46996 (4:55) in 0:24. Filename: C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 03 - Die Liebe.IGNORE
    CRC32: C4ECCBAA    AccurateRip CRC: DA8C90A2    [DiscID: 011-00115bcc-009a297b-860abb0b-3]
Information ripping to [CUE Sheet Image], 'Track 4' to 'C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 04 - Jesus Antichristus.IGNORE'
  Track 4:  Ripped LBA 46996 to 66748 (4:23) in 0:20. Filename: C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 04 - Jesus Antichristus.IGNORE
    CRC32: 0E16CB58    AccurateRip CRC: 69DDD142    [DiscID: 011-00115bcc-009a297b-860abb0b-4]
Information ripping to [CUE Sheet Image], 'Track 5' to 'C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 05 - Cannibal Anthem.IGNORE'
  Track 5:  Ripped LBA 66748 to 84717 (3:59) in 0:17. Filename: C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 05 - Cannibal Anthem.IGNORE
    CRC32: 980E849C    AccurateRip CRC: D7A91E53    [DiscID: 011-00115bcc-009a297b-860abb0b-5]
Information ripping to [CUE Sheet Image], 'Track 6' to 'C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 06 - Auf der Jagd.IGNORE'
  Track 6:  Ripped LBA 84717 to 101222 (3:40) in 0:14. Filename: C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 06 - Auf der Jagd.IGNORE
    CRC32: 77230886    AccurateRip CRC: 058820B3    [DiscID: 011-00115bcc-009a297b-860abb0b-6]
Information ripping to [CUE Sheet Image], 'Track 7' to 'C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 07 - Pass Auf.IGNORE'
  Track 7:  Ripped LBA 101222 to 124586 (5:11) in 0:19. Filename: C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 07 - Pass Auf.IGNORE
    CRC32: C715F7DD    AccurateRip CRC: 44229CDC    [DiscID: 011-00115bcc-009a297b-860abb0b-7]
Information ripping to [CUE Sheet Image], 'Track 8' to 'C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 08 - Jetzt.IGNORE'
  Track 8:  Ripped LBA 124586 to 139623 (3:20) in 0:12. Filename: C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 08 - Jetzt.IGNORE
    CRC32: B2A94A78    AccurateRip CRC: FC954D46    [DiscID: 011-00115bcc-009a297b-860abb0b-8]
Information ripping to [CUE Sheet Image], 'Track 9' to 'C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 09 - Ohne Dich.IGNORE'
  Track 9:  Ripped LBA 139623 to 159264 (4:21) in 0:15. Filename: C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 09 - Ohne Dich.IGNORE
    CRC32: 5CF8EEBC    AccurateRip CRC: D50B27FB    [DiscID: 011-00115bcc-009a297b-860abb0b-9]
Information ripping to [CUE Sheet Image], 'Track 10' to 'C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 10 - Hunger.IGNORE'
  Track 10:  Ripped LBA 159264 to 178226 (4:12) in 0:14. Filename: C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 10 - Hunger.IGNORE
    CRC32: 946622A8    AccurateRip CRC: 1DACCDEF    [DiscID: 011-00115bcc-009a297b-860abb0b-10]
Information ripping to [CUE Sheet Image], 'Track 11' to 'C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 11 - Recht vor Gnade.IGNORE'
  Track 11:  Ripped LBA 178226 to 206085 (6:11) in 0:19. Filename: C:\dBpoweramp\;wumpscut;\Cannibal Anthem\;wumpscut; - 11 - Recht vor Gnade.IGNORE
    AccurateRip: Accurate (confidence 14)    [Pass 1]
    CRC32: 8853BD73    AccurateRip CRC: 6558FC4B    [DiscID: 011-00115bcc-009a297b-860abb0b-11]
Compare the number of tracks listed in the TOC in the EAC log against the number of tracks you ripped.  Now look at the EAC log in the initial post.  Your disc has no data track.  This is the key difference and the entire reason that this question was raised.
I was in two different branches of the military. I wonder why I still have no attention to detail!
I guess I could try it again a bit later with a CD that contains a data track. You know what really irks me? The latest :wumpscut: CD DOES have one. I could well have used that.
The DBPoweramp rip I originally tested was ripped from version 13.4 a while ago... after noticing the inconsistencies in cuetools I re-ripped the CD yesterday with DBPA 13.5, but still got the same results in cuetools. The metadata is all there, the songs play fine, they all have the same gap handling and track length, and I do believe that DBPA is ripping the CD accurately. But as greynol has noticed there must be something going on with the way DBPA is handling the data track.
I see it now. The AR disc ID is not the same between EAC cuetools log(00167af6-00e6e950-c60e0e0e) and the DBPA cuetools log(001566ca-00d7cee8-b30a5f0d). In DBPA there is an option to write the AR disc ID to the file; I had this option turned off. I have just turned it on and re-ripped the CD. DBPA is indeed detecting the proper ripID, and the metadeta shows the AR disc ID as 00167af6-00e6e950-c60e0e0e. However, even with these tags still in the file, I have run a cuetools 'verify' on this new rip and it is still reporting a result and log identical to the one I already posted, where it is still incorrectly reading the disc ID as 001566ca-00d7cee8-b30a5f0d and giving me a rip not accurate result.
So either CUETools doesn't recognize the way the data is written, CUETools isn't configured to read the metadata, or CUETools simply doesn't use metadata.
Maybe someone who knows more about CUETools can help.  I only use it with CUE Sheets and EAC-generated logs.  I do not allow it to create files (besides the results log) or alter the metadata of my tracks.
I just ripped a CD-EP with a data-track. I had the same results now as Fenor. I never noticed this before as I just never felt the need to verify my own rips with CUETools.
...but now I'm curious. I looked around in dBpa's forums and haven't yet found it discussed. I'm sure it's there and perhaps I'm just a bit impatient and pressed for time.
EAC LOG:
EAC extraction logfile from 9. September 2010, 18:48
Staubkind / Ausgebrannt
Read mode              : Secure
Selected bitrate                : 1024 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Program Files (x86)\Exact Audio Copy\Flac\flac.exe
Additional command line options : -V -8 -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" %s
        1  |  0:00.00 |  4:06.45 |        0    |    18494
        2  |  4:06.45 |  3:47.06 |    18495    |    35525
        3  |  7:53.51 |  4:21.67 |    35526    |    55167
        4  | 12:15.43 |  4:52.20 |    55168    |    77087
        5  | 17:07.63 |  4:29.06 |    77088    |    97268
        6  | 24:08.69 | 20:49.40 |    108669    |  202383
Track  1
    Filename C:\EAC.rips\01 - ausgebrannt .wav
    Peak level 97.5 %
    Test CRC 735048BD
    Copy CRC 735048BD
    Accurately ripped (confidence 2)  [2DDEE4AB]
    Copy OK
Track  2
    Filename C:\EAC.rips\02 - deine nacht .wav
    Peak level 97.4 %
    Test CRC 9A8B10D8
    Copy CRC 9A8B10D8
    Accurately ripped (confidence 2)  [D00F8A6E]
    Copy OK
Track  3
    Filename C:\EAC.rips\03 - frei (wie du fühlst) .wav
    Peak level 97.5 %
    Test CRC 06703A68
    Copy CRC 06703A68
    Accurately ripped (confidence 2)  [DDEA1C22]
    Copy OK
Track  4
    Filename C:\EAC.rips\04 - mein herz - LIVE .wav
    Pre-gap length  0:00:05.00
    Peak level 97.5 %
    Test CRC 0905E8EE
    Copy CRC 0905E8EE
    Accurately ripped (confidence 1)  [B58F4A43]
    Copy OK
Track  5
    Filename C:\EAC.rips\05 - knie nieder (rmx) - LIVE .wav
    Pre-gap length  0:00:01.00
    Peak level 97.4 %
    Test CRC 77B60AEB
    Copy CRC 77B60AEB
    Accurately ripped (confidence 1)  [567FBDB4]
    Copy OK
No errors occurred
dBpa LOG:
Information ripping to [CUE Sheet Image], 'Track 1' to 'C:\dBpoweramp\Staubkind\Ausgebrannt\Staubkind - 01 - Ausgebrannt.IGNORE'
  Track 1:  Ripped LBA 0 to 18495 (4:06) in 0:23. Filename: C:\dBpoweramp\Staubkind\Ausgebrannt\Staubkind - 01 - Ausgebrannt.IGNORE
    AccurateRip: Accurate (confidence 2)    [Pass 1]
    CRC32: 735048BD    AccurateRip CRC: 2DDEE4AB    [DiscID: 005-0005ee35-001df7d1-470a8a06-1]
Information ripping to [CUE Sheet Image], 'Track 2' to 'C:\dBpoweramp\Staubkind\Ausgebrannt\Staubkind - 02 - Deine Nacht.IGNORE'
  Track 2:  Ripped LBA 18495 to 35526 (3:47) in 0:19. Filename: C:\dBpoweramp\Staubkind\Ausgebrannt\Staubkind - 02 - Deine Nacht.IGNORE
    CRC32: 9A8B10D8    AccurateRip CRC: D00F8A6E    [DiscID: 005-0005ee35-001df7d1-470a8a06-2]
Information ripping to [CUE Sheet Image], 'Track 3' to 'C:\dBpoweramp\Staubkind\Ausgebrannt\Staubkind - 03 - Frei (Wie du Fühlst).IGNORE'
  Track 3:  Ripped LBA 35526 to 55168 (4:21) in 0:20. Filename: C:\dBpoweramp\Staubkind\Ausgebrannt\Staubkind - 03 - Frei (Wie du Fühlst).IGNORE
    CRC32: 06703A68    AccurateRip CRC: DDEA1C22    [DiscID: 005-0005ee35-001df7d1-470a8a06-3]
Information ripping to [CUE Sheet Image], 'Track 4' to 'C:\dBpoweramp\Staubkind\Ausgebrannt\Staubkind - 04 - Mein Herz (Live - 14. Wgt).IGNORE'
  Track 4:  Ripped LBA 55168 to 77088 (4:52) in 0:21. Filename: C:\dBpoweramp\Staubkind\Ausgebrannt\Staubkind - 04 - Mein Herz (Live - 14. Wgt).IGNORE
    AccurateRip: Accurate (confidence 1)    [Pass 1]
    CRC32: 0905E8EE    AccurateRip CRC: B58F4A43    [DiscID: 005-0005ee35-001df7d1-470a8a06-4]
Information ripping to [CUE Sheet Image], 'Track 5' to 'C:\dBpoweramp\Staubkind\Ausgebrannt\Staubkind - 05 - Knie Nieder Rmx (Live - 14. Wgt).IGNORE'
  Track 5:  Ripped LBA 77088 to 97269 (4:29) in 0:18. Filename: C:\dBpoweramp\Staubkind\Ausgebrannt\Staubkind - 05 - Knie Nieder Rmx (Live - 14. Wgt).IGNORE
    CRC32: 77B60AEB    AccurateRip CRC: 567FBDB4    [DiscID: 005-0005ee35-001df7d1-470a8a06-5]
CUETOOLS/EAC:
[CUETools log; Date: 9/10/2010 1:18:15 AM; Version: 2.0.9]
CD-Extra data track length 20:49:40.
[CTDB TOCID: E7qCmPq.fjpFKgvfAbIoHMsV7lE-] disk not present in database.
[AccurateRip ID: 0005ee35-001df7d1-470a8a06] found.
 01    [2ddee4ab] (2/2) Accurately ripped
 02    [d00f8a6e] (2/2) Accurately ripped
 03    [ddea1c22] (2/2) Accurately ripped
 04    [b58f4a43] (1/1) Accurately ripped
 05    [567fbdb4] (1/1) Accurately ripped
 --  97.5 [25500484] [16AC4AE0]
 01  97.5 [735048BD] [70C9C519]  CRC32
 02  97.4 [9A8B10D8] [0A863136]  CRC32
 03  97.5 [06703A68] [A8164ABE]  CRC32
 04  97.5 [0905E8EE] [46390820]  CRC32
 05  97.4 [77B60AEB] [2DFE5AA4]  CRC32
CUETools/dBpa:
[CUETools log; Date: 9/10/2010 1:15:31 AM; Version: 2.0.9]
[AccurateRip ID: 0004539a-0014582f-3d051005] disk not present in database.
I am using R14 Beta (which should be finished soon if not already.
