Topic: ADTS AAC -> RTP payload (Read 13787 times) previous topic - next topic
Hello!
I have an ADTS AAC stream and I want to packetize it into RTP,
but I don't know a structure of payload (payload-type = 96) for AAC (I want to packetize it into RTP to play via RTSP client,
which supports only "AAC-hbr" mode).
RFC-3640 tells that the structure of RTP (for AAC-hbr) MUST contain RTP-header (12 bytes),
AU-header (2 bytes: 13 bits = length of frame, 3 bits = AU-Index(-delta)) preceeded by AU-header-length (2 bytes),
and RTP payload (data section).
I used AAC frame without ADTS-header (skipping 7 (in case of protection is absent) or 9 (in other case) bytes of header) as payload,
but player didn't play it.
And my question: How to pack AAC-frame from ADTS into RTP to play it?
Please help me.
Thank you.
P.S.
SDP:
v=0
o=StreamingServer 12345678 1122971361000 IN IP4 <ip>
s=/file.3gp
u=http:///
e=admin@
c=IN IP4 0.0.0.0
t=0 0
m=audio 0 RTP/AVP 96
a=rtpmap:96 mpeg4-generic/44100/2
a=fmtp:96 streamtype=5;profile-level-id=1;mode=AAC-hbr;sizelength=13;indexlength=3;indexdeltalength=3; config=<config>; constantDuration=1024
a=control:trackID=2
And, is payload format I used correct?
Thank you.
Hello.
I've found an answer to my question.
Payload I used was correct, I've found an error in my code)).
Thanx.
        I am looking for aac RTP packetization source code or document, any help is appreciated.
Thanks in advance.
Regards,
Raghu.
Can you share the source code or any document which you prepared for this AAC RTP packetization. I am using mpeg4-generic mime type in my code.
I hope some useful info you share.
Thanks in advance.
i know this has been a while but does anyone have any AAC depacketization code ?
