I have just set up EAC on a new hard drive, but I am having trouble getting it to work.
On my old hard drive it worked fine, but I did not really keep up with recent releases.
The problem seems to be with the destination names.
The error is:
The external compressor returned an error!
Options:-V0 --id3v1-only --ta "Pepper" --tt "The Good Thing" --tg"Alt. Rock" --tl"Kona Town" --ty"2002" --tn"01" "Ptmp1!542.wav" "Ptmp1!542.mp3"
File: C:\Documents and Settings\me\My Documents\My Music\Pepper\Kona Town\Pepper-Kona Town-01-The Good Thing.wav
I have also tried with checking the Add ID3 Tag and letting EAC add with -V0 %s %d and it returns the same error.
The log I have saved looks like this:
Exact Audio Copy V0.99 prebeta 5 from 4. May 2009
EAC extraction logfile from 19. August 2010, 9:00
Pepper / Kona Town
Used drive : SONY CDRWDVD CRX880A Adapter: 1 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 6
Overread into Lead-In and Lead-Out : No
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : Yes
Used interface : Native Win32 interface for Win NT & 2000
Gap handling : Not detected, thus appended to previous track
Used output format : User Defined Encoder
Selected bitrate : 256 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files\Exact Audio Copy\lame3.98.4\lame.exe
Additional command line options : -V0 --id3v1-only --ta "%a" --tt "%t" --tg "%m" --tl "%g" --ty "%y" --tn "%n" %s %d
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 0:26.44 | 0 | 1993
2 | 0:26.44 | 4:14.60 | 1994 | 21103
3 | 4:41.29 | 3:55.24 | 21104 | 38752
4 | 8:36.53 | 3:19.57 | 38753 | 53734
5 | 11:56.35 | 4:16.24 | 53735 | 72958
6 | 16:12.59 | 5:27.37 | 72959 | 97520
7 | 21:40.21 | 3:27.52 | 97521 | 113097
8 | 25:07.73 | 4:08.27 | 113098 | 131724
9 | 29:16.25 | 3:21.37 | 131725 | 146836
10 | 32:37.62 | 3:02.70 | 146837 | 160556
11 | 35:40.57 | 3:24.46 | 160557 | 175902
12 | 39:05.28 | 3:35.60 | 175903 | 192087
13 | 42:41.13 | 3:52.23 | 192088 | 209510
Track 1
Filename C:\Documents and Settings\me\My Documents\My Music\Pepper\Kona Town\Pepper - Kona Town - 01 - The Good Thing.wav
Peak level 98.3 %
Track quality 99.5 %
Copy CRC 35A0DDD1
Accurately ripped (confidence 4) [B8568A42]
Copy OK
Track 2
Filename C:\Documents and Settings\me\My Documents\My Music\Pepper\Kona Town\Pepper - Kona Town - 02 - Stone Love.wav
Copy aborted
I followed the wiki and have LAME bundle downloaded from Rareware.
I have tried setting up the LAME folder in the EAC directory and I have tried with just the LAME file there.
I also have Skip track extraction on read or sync errors unchecked.
EAC extraction logfile from 18. August 2010, 16:11
Pepper / Kona Town
Read mode : Secure
Quality : High
Add ID3 tag : Yes
Command line compressor : C:\Program Files\Exact Audio Copy\lame.exe
Additional command line options : -V0 %s %d
Track 1
Peak level 98.3 %
Copy CRC 35A0DDD1
Copy OK
Track 2
Copy aborted
I am using Windows XP with SP3.
Thanks for the help. I am probably missing some completely obvious step, but I have been unable to figure it out. I tried another cd and it gives the same errors.
