Topic: No HDCD Playback with Monkey's Audio? (Read 3561 times) previous topic - next topic
Is it possible there is no HDCD playback with Monkey's Audio Format?
I play the ape-file and there is no HDCD indication.
The same File as wav-Format it was reporting HDCD detected in the status bar.
Currently, the only inputs which use the new decode postprocessor service are CDDA, WAV, FLAC, and WavPack. Others will follow.
If I decompress the APE back to WAV, would the HDCD information be lost? (lost when WAV -> APE ?)
If you have foo_hdcd 1.5 installed, converting from WAV to anything else will decode the HDCD information and it will be plain 24 bit sample data instead. If you convert externally, or without foo_hdcd, it will be retained.
Currently, converting APE back to WAV, or to any other lossless format, will retain the HDCD information, since the Monkey's Audio component does not support the decoder yet.
So, can you add the option to enable/disable HDCD decoder?
I suppose I will have to, as well as a switch for disabling the DTS decoder that follows the same design. Until such time as the caller can specify whether inputs should use these decoders or not, which would make sense for the converter.
Yes, I think the Converter needs a setting to turn on/off or skip the decoder postprocessing. That way it will work for all (future) postprocessors as well. That setting should be stored in the Converter presets as well IMO.
Good that someone is already working on the converter for the next release
Sorry, all my files are Monkey's Audio. It's horrible to convert all Audio-Files to another Format.
Is it possible you let follow the Monkey's Audio Format use the new decode postprocessor service?
Are is topic dead? Please, make somthing with .APE format and HDCD trouble!
PEACE, Me.
