Topic: Huffman Decoding (Read 4623 times) previous topic - next topic
Huffman Decoding
In the FAAD code he has used two methods for Huffman decoding the spectral values (2-step and binary) are there any other methods better than these two ? If no are these the only type of implementation possible ?
Huffman Decoding
Can you kindly refer some faster algorithms as well as some algorithms which require lesser memory(size of the tables)
Huffman Decoding
If using a 3-step method instead of binary for some codebook. It maybe faster than binary and the table size is smaller than 2-step method.
Huffman Decoding
I'm thinking about replacing the binary tables with 3 step tables, I'm not sure if it will be a lot faster and the rewriting of the tables takes a lot of time.
The least memory consuming method is probably the one used in the aac reference code, but it is quite slow.
Menno
Huffman Decoding
Menno
im still struggling to understand the 2-step algorithm implemented in faad... can u direct me to a reference which describes the algorithm and explains the concept?
