Topic: FLAC wish list (Read 3587 times) previous topic - next topic
FLAC wish list
What I would like to do
Encode entire cd from EAC passing to FLAC (or  other lossless format) to encode a singel file that contains all individual track (tag) info with embeded cuesheet
Have a nice GUI that could take this single file and transcode to single tracks of various formats with preservation of track and album info to pass to tags and filenames.
Nero plug in that recognizes embeded cue sheet. or EAC support
Does FLAC metadata support all this, I know there are now cuesheets, but do they incorporate track title info?
Another possibility would be a cuesheet that could be saved in the same folder as seperate track files.
This is where I believe lossles archiving needs to head.  Isn't that the point? Perfect sound, perfect burn, with effortless rip, encoding and format conversion?
Maybee jcoalson and Speek could work to this end?
Oh and hardware support would be nice (Audiotron?)
FLAC wish list
I would like to do this too, and I think the tools to do it are just maturing and getting close to having those abilities.  I don't know the intents and goals of the Xiph organization, but someday I'm hoping for a very integrated set of tools that combine FLAC, cdparanoia, and cdrdao, so we can do something like "flac --archive-cd /dev/cdrom filename.flac" to rip and encode a whole CD to a single file, and from that file you could burn and perfectly recreate the original CD.  There's a lot of detail that I'm sure could be put into such a solution, but the major building blocks are there.
It's things like this that make me wish I had the necessary programming skills to tackle such a project, or had money to donate to the Xiph project so they acquire more resources.  Or both.
FLAC wish list
Can't help much there, EAC is closed source.
I will probably have some time soon to finish my cross-platform transcoding gui that will include this.
Nero API may or may not allow this.
No, CD text was intentionally left out as the spec is too broad.  The tagger/transcoder should support a local or network metadatabase (cddb/cdindex) and calculate the key from the FLAC embedded cuesheet.
Already done, check the FLAC main page for Bery's Samba module.  But look into a Rio Receiver on ebay instead, it's cheaper, can decode FLAC natively with an open source client and has better server software.
Josh
