Topic: unable to use more then 16bit fixed-point (Read 4107 times) previous topic - next topic
Hello all.
i have tried everything i could but still have this problem
and here are some log from console....
-- now use 16bit fixed-point mode
INFO (CORE) : startup time: 581 ms
INFO (CORE) : opening file for playback : file://D:\MP3\Linkin Park - [Hybrid Theory]\08 - In The End.mp3
INFO (foo_output_std) : attempting to create DirectSound buffer : 44100hz 16bps 2ch fixed-point
INFO (foo_output_std) : DirectSound initialized successfully, using software mixing
INFO (CORE) : opening file for playback : file://D:\_mnt\Download\2003-03-29 聯合公園樂團 Linkin Park - Meteora\Linkin_Park_-_Meteora_-_05_-_Hit_THe_Floor.mp3
-- now change to 8bit fixed-point mode
INFO (foo_output_std) : attempting to create DirectSound buffer : 44100hz 8bps 2ch fixed-point
-- now change to 24bit fixed-point mode
INFO (foo_output_std) : attempting to create DirectSound buffer : 44100hz 24bps 2ch fixed-point
ERROR (foo_output_std) : error creating DirectSound buffer
and all the other mode get failed,all error messages are the same.
i'm using winxp sp1+directx9+sb live!+foobar2000 0.6 beta 7
what am I doing wrong or any extra setting i should modify?
sorry for my poor english.
Does your soundcard support greater than 16bits?
I do not think SB live is a  "true 24-bit" audio card.
sorry..
Sound Blaster Live! does *NOT* support playback resolutions over 16 bit.
End of story.
Oddly enough, I can feed my Santa Cruz 32-bit data (float or fixed-point) with no problem.  I don't think the Santa Cruz is supposed to support anything above 20-bit, though.  Meh, I just leave it on 16.
Despite it uses 20-bit DACs, Santa Cruz can't handle data size larger than 16 bits. I suppose it's WDM drivers in Win2K and WinXP that accept 32-bit data and convert internally to 16 bit before sending to the card harware. This is not optimum, better set ouput resolution to 16 bit and let FB2K do the conversion.
I can't seem to go above 16bit either. I'm using  a Revo.
32-bit fixed-point works fine on mine with KS (it doesn't like 24-bit, though).
Upgrade your Revo drivers. It will work then.
