Topic: wavpack.exe VBR Settings (Read 5029 times) previous topic - next topic
Hello))
I want to ask a question about the settings wavpack.exe
Why can raise only a nominal bitrate mode hybrid, why is not quality mode?
I need to encode the set of wav files with different bit depth and sampling rate. I need to set settings for each sample?
Thank you
MPC --quality 10 --tmn 20 --nmt 20 - %d || WV -miqhnb5x3 - %d
You can still use BPS instead of bitrate:  -b  2.0 to 23.9 bits/sample . The bitrate will then adjust automatically and even work for mono. It wont measure the audibility of noise though as VBR isn't yet implemented . For 44.1khz of more i think you can use the same BPS rate for cd audio. For low rez, you have to be more conservative as there is less masking .
Example :
-b4x = 350k for 44.1khz 16bit or 760k for 96khz 24bit
wavpack hybrid 256k -hx4
Thank shadowking, you helped me a lot)))
-miqhhb4.5j1 --use-dns
This parameters gives me normal quality?
It will give high transparent quality for almost any situation. You can drop -j1 as it is already default. It may be good idea to include at least -x(1) for high-rez audio. For something much lighter to decode or transcode consider the normal or fast mode in conjunction with -x :
-b384hh >> -b415fx3
I would agree with shadowking that -hh is probably overkill at that bitrate, and is slower to decode. I would drop it to -h and add at least -x. I generally recommend the highest -x argument that you are willing to wait for (up to -x6) because it does not affect decode speed.
Note that --use-dns is also enabled by default at normal sampling rates (under 64 KHz). At high sampling rates the default is for the noise to be shaped up into inaudible frequencies (-s1) which I think is better than the dynamic shaping (which tries to put the noise under the music).
David
