Topic: [File Operations] %date% tag returns as empty? (Read 1425 times) previous topic - next topic
Hey,
I want to re-organise the structure of my collection. Fortunately foobar - as always - does exactly what I need
My plan was to use File Operations to copy all the files to another dir on my HDD and, on the way, rename all the folders with data from the mp3 tags. That's where I ran into a problem:
Here is a screenshot of what I'm trying to do. You can see the string I want to use (or how the directories should look)
Also, the preset name "Milestone" is from when I used File Ops on my Motorola Milestone and can be ignored. Although, oddly enough, it worked just fine back then (the %date% returned the year).
Its the latest version of foobar and the File Ops component, as I'm aware. I can reproduce this on my PC and laptop. OSs are W7 x64 and x86, respectively.
What am I doing wrong here?
no idea from my side, maybe a screenshot of the properties dialog could help... (even if you say they are properly tagged)
fb2k on OSX: flac q8 > rockboxed Sansa e280v1: Vorbis q5.0
is d-a-t-e spelled with weird unicode characters, or anything?
Also, do your mp3 files have id3v1 tags in addition to id3v2?
elevatorladylevitateme
This is a guess, but does it matter if you use forward (/) slashes rather than (\) in your renaming pattern?
C.
Uhh... yea.
I just scrolled down way further in the preview and realised that some years are there. I double checked those who weren't for proper tagging (which they are, as I said) and gave it another go. Now it works.
I made up a phrase for things like this a couple of years ago: "computer voodoo"
