Topic: Ratings WMP: Change FooBar to read the Ratings WMP field in the tag (Read 2247 times) previous topic - next topic
This seems to be an issue.  Some suggestions have been made to add a "RATING WMP" field to the standard fields (File/Preferences/Advanced/Display/Properties Dialog/Standard Fields) but this change doesn't give access to the actual field as written by WMP.  Others suggest using MP3 Tag to convert the "Rating WMP" field to a standard "RATING" field that can be picked up by FooBar but this doesn't solve the problem of accessing the same field from both players and is simply a workaround only.
I think you'll find that to the vast majority of the developer (Peter), this "lack of feature" is a non-issue.
