Topic: Necessary WAV headroom to prevent mp3 clipping (Read 9089 times) previous topic - next topic
Hi guys,
I've had a search through the forums but couldn't find an answer. From what I gather, if I encode an mp3 from a WAV at 0.00dB then the encoding process will cause clipping. I was wondering how much headroom would be optimal in the WAV to avoid this? Cheers for any replies.
Merzbow, "I Lead You Towards Glorious Times (live)" + LAME 3.98.4 -V5: track peak = 2.729135 ( = 8,72 dB).
10 dB should be enough, I suppose...
Do not apply it to the wav. Instead encode the unmodified wav and apply mp3gain or replaygain to the mp3. This way there is no guessing.
This depends on what is inside the WAV. Before I had a replay-gain capable MP3 player, I just encoded the files, checked the maximum (album) peak on the encoded files (replay-gain scan in Foobar 2k) and then encoded them a second time (using the WAV sources again) with LAME option of "--scale X" where X is (1/measured peak on encoded files). This worked most of the time (sometimes even this produced peaks over 1.0 in the MP3 files so I had to decrease the scale a bit and encode again). This gets boring pretty quickly, however.
I think it should be demonstrated through double-blind tests that this is actually a problem.  My personal opinion is that reducing the level of a track to accommodate for something people cannot hear is silly.
I think the usual cause of clipping when encoding to lossy, is that the original wav file was already clipped, so like greynol I doubt that the additional clipping is going to be any more obvious than what is already there.
Doesn't LAME do a little attenuation of the signal on its own?
What makes you think that?
It might attenuate the signal sonically (audibly) but it does exactly the opposite WRT signal's wafeform/peak. If you filter out the higher frequencies of a square wave it's likely to result in overshoot.
I just remember something from a while back about multiplying the signal by 0.95 or something like that. Maybe I'm babbling.
How do you do double-blind tests on portable devices that don't have replaygain capability or floating-point decoders able to process files with 1.0+ levels? I'd be interested in the validity of such tests.
Infrasonic Quartet + Sennheiser HD650 + Microlab Solo 2 mk3.
You don't have to if your goal is transparency; and this is where I suggest you start.
Clipping as a result of encoding should be treated the same as any other lossy artifact.
If you're still interested in comparing a decoded mp3 that clips with one that doesn't, here's something I presented a while back.
http://www.hydrogenaudio.org/forums/index....st&p=558514
I've covered this on more than one occasion but always run into static because it seems that some people would rather listen with their eyes than with their ears.
That was like 3.95 or something. It's not being done anymore.
No, LAME still attenuates input signal  in cbr/abr mode (and for bitrate less than 240 kbps).
Interesting.
My test sample indicates that it attenuates by almost 0.5 dB.
That was idiotically presumptuous.  Let me rephrase:  Lame 3.98 with -b128 it attenuated a -9dB 1kHz test tone by almost 0.5dB.
Shouldn't this affect one's ability to ABX?
